  4. Problem Routeplanner between 2 points
21 Posts 8 Posters 9.0k Views 3 Watching
  • nomko
    Banned
    wrote on last edited by nomko
    This would be the problem.
    Between waypoints 1 and 2 there are no more waypoints. Best is to place some extra waypoints before/after the Cardenal Samoré pass so you pass the border at that point (yellow marked part of the route).
    Waypoint 2 is placed far beyond the Cardenal Samoré pass giving MRA the opportunity to come up with a route you don't like.
    As you can see in my screenshot(s) i placed a waypoint before and after the border at Cardenal Samoré. This forces MRA to pass the border at this location. You don't have to do it like this, but placing 1 waypoint before the border should do the trick. And also change the map from OpenStreetMap to HERE. That will fix this issue also.
    • DAVID PUEYO TORRES
      DAVID PUEYO TORRES
      DAVID PUEYO TORRES
      Thank you.
      I've done what you're telling me, but it still doesn't work. I don't understand.
      Check again please: https://www.myrouteapp.com/route/open/12312848
      Even though I pay a monthly fee, I don't have HERE.
      What's strange is that it's always been this way, and a few weeks ago, I didn't get this error.
      Thank you for your help!!
        DAVID PUEYO TORRES
        DAVID PUEYO TORRES
          DAVID PUEYO TORRES
          DAVID PUEYO TORRES
          As you can see, the app was correctly generating the route before.
          • nomko
            Banned
            Do you have the Silver membership? Of so, then i understand this situation even better. With the Silver membership you don't have the HERE map. This comes with the Gold membership.
            And why pay per month? You can also have a life-time membership. You only pay once and enjoy the rest of your life of MRA!
            You get the Gold membership that comes with all the options and features of the Silver membership shipped with a lot of extra options and features!
            • Alex reds
              Alex reds
              Alex reds
              I actually tried it myself, just like Nomko said, and it works. With the OpenStreetMap map, even though you can see the road, it makes you take a huge detour, while with the Here map it follows the route you’d expect.
              • Alex reds
                Alex reds
                Alex reds
                wrote on last edited by Alex reds
                map here
                • Alex reds
                  Alex reds
                  Alex reds
                  Anyway, even if the planning shows that detour, once you reach point 4 you just continue on the road, and when you get to point 5 you’ll carry on toward point 6 without any effect on the rest of the route.
                  • Alex reds
                    Alex reds
                    Alex reds
                    Not sure about this one… can we actually pass through here?
                    • Rob Veerman
                      Rob Veerman
                      Rob Veerman
                      Transitable con cadenas=passable with snow chains (depending on the time of the year, I suppose).
                        DAVID PUEYO TORRES
                        DAVID PUEYO TORRES
                        @Nomko-Nomden
                        I pay for the silver membership (2,95€/month).
                        Until now, I've been able to do that route without any problems. I don't understand why it won't let me now.
                        Do you know if they've changed something in the subscription that's why it doesn't include that now?
                        Thank you very much!
                        BMcG 1 Reply Last reply
                        • Alex reds
                          Alex reds
                          Alex reds
                          I’m not sure if they’ve changed it, but as far as I can see, with the Silver plan you can’t use the Here map — only with the Gold plan or with the MRA Navigation app.
                          • nomko nomko
                            @Nomko-Nomden not completely true. With a silver abo you for have the Here map but you can't compaire the route with TT and OSM
                              @Marinus-van-Deudekom said in Problem Routeplanner between 2 points:
                              Not correct. A Silver subscription only gives you access to the planning map from OpenStreetMap.
                              • DAVID PUEYO TORRES DAVID PUEYO TORRES
                                @Nomko-Nomden
                                BMcG
                                BMcG
                                BMcG
                                Hi @DAVID-PUEYO-TORRES I don't think it is anything to do with subscriptions
                                To me the problem appears to be with the MRA version of the OpenStreetMap map data
                                On MRA using OpenStreetMap to calculate the route the path refuses to pass through the border post
                                On the OpenStreetMap website the routing passes through the border post with no problem
                                The normal way of getting around routing issues like this is to use the "offroad / skip" function,
                                it is very often used to enable routes over rivers / ferry crossings
                                add two points (4 & 5 ) similar to what I have shown either side of the border crossing
                                then click point 5 & select the "offroad / skip" icon to route straight between 4&5
                                MRA has their own version of the OpenStreetMap data & it is not always the same as that on the OSM site
                                Its possible that the MRA version is out of date or that the snapshot that MRA took had some bad edits for the border post
                                  Yes, please don't blame any licensing changes, since there are none. Like @Brian-McG explained, there is likely a difference in versions of the OSM map between the one MRA uses, and OSM has online.
                                  @Nick-Carthew said in Problem Routeplanner between 2 points:
                                  With the exception of having a Navigation License too.
                                  Rob Veerman
                                  Rob Veerman
                                  BMcG
                                  BMcG
                                  Alex reds
                                  Alex reds
                                  DAVID PUEYO TORRES
                                  DAVID PUEYO TORRES
                                  • reis in concept kopieren
                                  • Suggestion: Route Auto Name
                                  • Trips, interaction with Clubs
                                    Andy Nicholson
                                    Andy Nicholson
                                  • Globale inhoud van een update en mogelijk wijzigingen.
                                    Peter 12m
                                    Peter 12m
                                  • Move Google Maps up the list
                                    JP d
                                    JP d
                                  • Measurement units setting is global and not according to the country why the route is planned.
