  4. Problem Routeplanner between 2 points
21 Posts 8 Posters 9.0k Views 3 Watching
  • DAVID PUEYO TORRES
    DAVID PUEYO TORRES
    DAVID PUEYO TORRES
    As you can see, the app was correctly generating the route before.
    • nomko
      Banned
      Do you have the Silver membership? Of so, then i understand this situation even better. With the Silver membership you don't have the HERE map. This comes with the Gold membership.
      And why pay per month? You can also have a life-time membership. You only pay once and enjoy the rest of your life of MRA!
      You get the Gold membership that comes with all the options and features of the Silver membership shipped with a lot of extra options and features!
      • Alex reds
        Alex reds
        Alex reds
        I actually tried it myself, just like Nomko said, and it works. With the OpenStreetMap map, even though you can see the road, it makes you take a huge detour, while with the Here map it follows the route you’d expect.
        • Alex reds
          Alex reds
          Alex reds
          wrote on last edited by Alex reds
          map here
          • Alex reds
            Alex reds
            Alex reds
            Anyway, even if the planning shows that detour, once you reach point 4 you just continue on the road, and when you get to point 5 you’ll carry on toward point 6 without any effect on the rest of the route.
            • Alex reds
              Alex reds
              Alex reds
              Not sure about this one… can we actually pass through here?
              • Rob Veerman
                Rob Veerman
                Rob Veerman
                Transitable con cadenas=passable with snow chains (depending on the time of the year, I suppose).
                  DAVID PUEYO TORRES
                  DAVID PUEYO TORRES
                  @Nomko-Nomden
                  I pay for the silver membership (2,95€/month).
                  Until now, I've been able to do that route without any problems. I don't understand why it won't let me now.
                  Do you know if they've changed something in the subscription that's why it doesn't include that now?
                  Thank you very much!
                  BMcG 1 Reply Last reply
                  • Alex reds
                    Alex reds
                    Alex reds
                    I’m not sure if they’ve changed it, but as far as I can see, with the Silver plan you can’t use the Here map — only with the Gold plan or with the MRA Navigation app.
                    • nomko nomko
                      @Nomko-Nomden not completely true. With a silver abo you for have the Here map but you can't compaire the route with TT and OSM
                        @Marinus-van-Deudekom said in Problem Routeplanner between 2 points:
                        Not correct. A Silver subscription only gives you access to the planning map from OpenStreetMap.
                        • DAVID PUEYO TORRES DAVID PUEYO TORRES
                          @Nomko-Nomden
                          BMcG
                          BMcG
                          BMcG
                          Hi @DAVID-PUEYO-TORRES I don't think it is anything to do with subscriptions
                          To me the problem appears to be with the MRA version of the OpenStreetMap map data
                          On MRA using OpenStreetMap to calculate the route the path refuses to pass through the border post
                          On the OpenStreetMap website the routing passes through the border post with no problem
                          The normal way of getting around routing issues like this is to use the "offroad / skip" function,
                          it is very often used to enable routes over rivers / ferry crossings
                          add two points (4 & 5 ) similar to what I have shown either side of the border crossing
                          then click point 5 & select the "offroad / skip" icon to route straight between 4&5
                          MRA has their own version of the OpenStreetMap data & it is not always the same as that on the OSM site
                          Its possible that the MRA version is out of date or that the snapshot that MRA took had some bad edits for the border post
                            Yes, please don't blame any licensing changes, since there are none. Like @Brian-McG explained, there is likely a difference in versions of the OSM map between the one MRA uses, and OSM has online.
                            @Nick-Carthew said in Problem Routeplanner between 2 points:
                            With the exception of having a Navigation License too.
                            Rob Veerman
                            Rob Veerman
                            BMcG
                            BMcG
                            Alex reds
                            Alex reds
                            DAVID PUEYO TORRES
                            DAVID PUEYO TORRES
                            • reis in concept kopieren
                            • Suggestion: Route Auto Name
                            • Trips, interaction with Clubs
                              Andy Nicholson
                              Andy Nicholson
                            • Globale inhoud van een update en mogelijk wijzigingen.
                              Peter 12m
                              Peter 12m
                            • Move Google Maps up the list
                              JP d
                              JP d
                            • Measurement units setting is global and not according to the country why the route is planned.
