  4. Problem Routeplanner between 2 points
21 Posts 8 Posters 9.0k Views 3 Watching
  • DAVID PUEYO TORRES
    DAVID PUEYO TORRES
    DAVID PUEYO TORRES
    Hello!
    I'm having trouble creating a direct route between two major cities. The route goes through a border crossing that is open, but the planner keeps sending me on a huge detour.
    It’s between the cities of Osorno (Chile) and Bariloche (Argentina), crossing at the Cardenal Samoré border. I used to be able to plan this route without any issues, but for some time now, it’s been impossible.
    Can anyone help?
    Thank you very much!
    • nomko
      Banned
      wrote on last edited by nomko
      @DAVID-PUEYO-TORRES
      Hi David,
      Can you place a link to that route here zso we can check it also?
      At first glance, it sounds like that you have selected the wrong transport modus and have the route optimization set to Fastest instead of shortest. But this can only be done when the map is set to HERE.
      Another thing which could causing the problem is seasonal closure. Turning it off will give you also another route compared to turning it on.
      Which map are you using?
      I just made a route by myself, using HERE and set the route optimization to Shortest and the transport modus to Car.
      As you can see, waypoints 5 and 6 are passing the border without any issues (screenshot 1). Even removing some waypoints does have no effect (screenshot 2).
      So that is the reason why i asked you to place a link to that route of yours. Make sure top set it to public.
      Screenshot 1
      Screenshot 2
        DAVID PUEYO TORRES
        DAVID PUEYO TORRES
        Hi Nomko.
        I attach the link:
        https://www.myrouteapp.com/route/open/12077792
        If you can help me I would be very grateful.
        • DAVID PUEYO TORRES DAVID PUEYO TORRES
          Hi Nomko.
          I attach the link:
          Rob Veerman
          Rob Veerman
          Rob Veerman
          wrote on last edited by Rob Veerman
          @DAVID-PUEYO-TORRES For others to be able to open the route, It has to be set to public.
            DAVID PUEYO TORRES
            DAVID PUEYO TORRES
            Sorry!
            https://www.myrouteapp.com/route/open/12312848
            • nomko
              Banned
              This would be the problem.
              Between waypoints 1 and 2 there are no more waypoints. Best is to place some extra waypoints before/after the Cardenal Samoré pass so you pass the border at that point (yellow marked part of the route).
              Waypoint 2 is placed far beyond the Cardenal Samoré pass giving MRA the opportunity to come up with a route you don't like.
              As you can see in my screenshot(s) i placed a waypoint before and after the border at Cardenal Samoré. This forces MRA to pass the border at this location. You don't have to do it like this, but placing 1 waypoint before the border should do the trick. And also change the map from OpenStreetMap to HERE. That will fix this issue also.
                DAVID PUEYO TORRES
                DAVID PUEYO TORRES
                Thank you.
                I've done what you're telling me, but it still doesn't work. I don't understand.
                Check again please: https://www.myrouteapp.com/route/open/12312848
                Even though I pay a monthly fee, I don't have HERE.
                What's strange is that it's always been this way, and a few weeks ago, I didn't get this error.
                Thank you for your help!!
                  DAVID PUEYO TORRES
                  DAVID PUEYO TORRES
                    DAVID PUEYO TORRES
                    DAVID PUEYO TORRES
                    As you can see, the app was correctly generating the route before.
                    • nomko
                      Banned
                      Do you have the Silver membership? Of so, then i understand this situation even better. With the Silver membership you don't have the HERE map. This comes with the Gold membership.
                      And why pay per month? You can also have a life-time membership. You only pay once and enjoy the rest of your life of MRA!
                      You get the Gold membership that comes with all the options and features of the Silver membership shipped with a lot of extra options and features!
                      • Alex reds
                        Alex reds
                        Alex reds
                        I actually tried it myself, just like Nomko said, and it works. With the OpenStreetMap map, even though you can see the road, it makes you take a huge detour, while with the Here map it follows the route you’d expect.
                        • Alex reds
                          Alex reds
                          Alex reds
                          wrote on last edited by Alex reds
                          map here
                          • Alex reds
                            Alex reds
                            Alex reds
                            Anyway, even if the planning shows that detour, once you reach point 4 you just continue on the road, and when you get to point 5 you’ll carry on toward point 6 without any effect on the rest of the route.
                            • Alex reds
                              Alex reds
                              Alex reds
                              Not sure about this one… can we actually pass through here?
                              • Rob Veerman
                                Rob Veerman
                                Rob Veerman
                                Transitable con cadenas=passable with snow chains (depending on the time of the year, I suppose).
                                  DAVID PUEYO TORRES
                                  DAVID PUEYO TORRES
                                  @Nomko-Nomden
                                  I pay for the silver membership (2,95€/month).
                                  Until now, I've been able to do that route without any problems. I don't understand why it won't let me now.
                                  Do you know if they've changed something in the subscription that's why it doesn't include that now?
                                  BMcG 1 Reply Last reply
                                  • Alex reds
                                    Alex reds
                                    Alex reds
                                    I’m not sure if they’ve changed it, but as far as I can see, with the Silver plan you can’t use the Here map — only with the Gold plan or with the MRA Navigation app.
                                    • nomko nomko
                                      @Nomko-Nomden not completely true. With a silver abo you for have the Here map but you can't compaire the route with TT and OSM
                                        @Marinus-van-Deudekom said in Problem Routeplanner between 2 points:
                                        Not correct. A Silver subscription only gives you access to the planning map from OpenStreetMap.
                                          @Nomko-Nomden
                                          BMcG
                                          BMcG
                                          BMcG
                                          Hi @DAVID-PUEYO-TORRES I don't think it is anything to do with subscriptions
                                          To me the problem appears to be with the MRA version of the OpenStreetMap map data
                                          On MRA using OpenStreetMap to calculate the route the path refuses to pass through the border post
                                          On the OpenStreetMap website the routing passes through the border post with no problem
                                          The normal way of getting around routing issues like this is to use the "offroad / skip" function,
                                          it is very often used to enable routes over rivers / ferry crossings
                                          add two points (4 & 5 ) similar to what I have shown either side of the border crossing
                                          then click point 5 & select the "offroad / skip" icon to route straight between 4&5
                                          MRA has their own version of the OpenStreetMap data & it is not always the same as that on the OSM site
                                          Its possible that the MRA version is out of date or that the snapshot that MRA took had some bad edits for the border post
                                          Rob Veerman
                                          Rob Veerman
                                          BMcG
                                          BMcG
                                          Alex reds
                                          Alex reds
                                          DAVID PUEYO TORRES
                                          DAVID PUEYO TORRES
                                          • reis in concept kopieren
                                          • Suggestion: Route Auto Name
                                          • Trips, interaction with Clubs
                                            Andy Nicholson
                                            Andy Nicholson
                                          • Globale inhoud van een update en mogelijk wijzigingen.
                                            Peter 12m
                                            Peter 12m
                                          • Move Google Maps up the list
                                            JP d
                                            JP d
                                          • Measurement units setting is global and not according to the country why the route is planned.
