  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 30.3k Views 7 Watching
    I've made some changes in 5.0.4! 😃
    Haug
    Haug
    Haug
    @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
    Many thanks for your support.
    Günter
    • Haug Haug
      Günter
      @Haug Glad to read my changes seem to work! 🙂
        #52
        I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
        My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
        I did hear differences but not what i expected.
        I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
        The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
        B.t.w I have a Sena SRL 3 headset.
        Haug 1 Reply Last reply
        • Haug
          Haug
          Haug
          Hallo everybody,
          since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
          Did you change anything? Can you check please?
          Thanks
          Günter
          • Haug
            Haug
            Haug
            @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
              The same issue with current final and previous final release. The slider doesn't work as it should.
              When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
              • Haug
                Haug
                Haug
                For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                • Haug
                  Haug
                  Haug
                  @corjan-meijerink : any News about this Problem?
                  • Haug
                    Haug
                    Haug
                    @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                    • Haug
                      Haug
                      Haug
                      Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                      Also no response from you @corjan-meijerink
                      This is not very friendly!
                        Haug
                        Haug
                        Haug
                        @M.-Schrijver
                        Hello M.
                        have you still the Audio Problem like me?
                        First second of the Audio command is missing.
                        Thanks and regards
                        Günter
                          With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                          during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                          • Haug
                            Haug
                            Haug
                            If you have a Media playing during Navigation with MRA, the Audio commands work without any Problem. This is due to an open bluetooth Connection with music. But I have normally during motorcycle ride no music playing.
                            • Haug Haug
                              It's still a public forum and this is not a support ticket 🙂
                              Pushing me definitely won't help me finding motivation for looking into an issue one users reports.
                              From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
                              • Haug
                                Haug
                                Haug
                                Ok clear, but it seems, I am not the only one with this problem.
                                For me it means, that the MRA is not useable anymore.
                                  To be fair, I don't really see many complaints about this.
                                  The biggest issue with the Android Auto audio channels has been solved.
                                  • Haug
                                    Haug
                                    Haug
                                    wrote on last edited by Haug
                                    #66
                                    Strange, that it was working with 5.0.4. But if it’s not an issue for you, I will leave MRA.
                                      We take all feedback serious but please, create a support ticket.
                                      Then we have an official way to communicate.
                                      Obviously audio is critical.
                                      • 4
                                      Haug
                                      Haug
                                      richard 3v
                                      richard 3v
                                      Jan Weerheim
                                      Jan Weerheim
                                      Marco Strani
                                      Marco Strani
                                      Robert Laudensack
                                      Robert Laudensack
                                        Jörg Neudert
                                        Jörg Neudert
                                        130
                                        4.7k
                                        4.7k
                                      • Points of interest
                                        Lluís Casals
                                        Lluís Casals
                                      • Hallo, wéér een nieuwe gebruiker !
