  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
  • Haug
    Haug
    Haug
    Did something change about this issue in the latest update?
    • Aiello antonino
      #39
      I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
      Haug 1 Reply Last reply
      • Hubert Thoring
        @Aiello-antonino
        I would switch to iOS 26.2..
        • Aiello antonino
          #41
          Honestly, I think I'll wait any longer, I still read about a lot of problems...
            In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
            Banned
            @Corjan-Meijerink said in Audio cuttet via Bluetooth:
            where can we configure this?
            • nomko nomko
              @Nomko-Nomden Navigation settings > Audio
                Haug
                Haug
                Haug
                @Aiello-antonino
                Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
                • Haug
                  Haug
                  Haug
                  Any new experience about this problem?
                  • Haug
                    Haug
                    Haug
                    @Corjan-Meijerink:
                    Hello Corjan, today I tested several things regarding Audio via Bluetooth.
                    1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                      1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                    2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                    3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                    now the interesting thing!
                    1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
                    Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
                    I really have the feeling, that the delay slider is not working at all in MRA.
                    Could you pleas check again?
                    Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
                    Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
                    Many Thanks in Advance and Regards
                    Günter
                    • Haug
                      Haug
                      Haug
                      @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                        Yes, I read your test! Indeed interesting.
                        I will check the audio delay setting in the upcoming 5.1 update 🙂
                          I've made some changes in 5.0.4! 😃
                            Haug
                            Haug
                            Haug
                            @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
                            Many thanks for your support.
                            Günter
                            • Haug Haug
                              Günter
                              @Haug Glad to read my changes seem to work! 🙂
                                #52
                                I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                                My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                                I did hear differences but not what i expected.
                                I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                                The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                                B.t.w I have a Sena SRL 3 headset.
                                • Haug
                                  Haug
                                  Haug
                                  Hallo everybody,
                                  since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
                                  Did you change anything? Can you check please?
                                  Thanks
                                  Günter
                                  • Haug
                                    Haug
                                    Haug
                                    @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                                      The same issue with current final and previous final release. The slider doesn't work as it should.
                                      When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                                      • Haug
                                        Haug
                                        Haug
                                        For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                                        • Haug
                                          Haug
                                          Haug
                                          @corjan-meijerink : any News about this Problem?
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
