Audio cuttet via Bluetooth
@Haug Thanks for your reply!
I can guarantee you, the slider isn't fake
Your audio system not respecting it, is another thing.I haven't yet seen any iOS device with these issues.
It's always Android to be honest
I'll test some different configurations to see if I can reproduce this.
Just to be sure, you are not using CarPlay but simply the car radio as bluetooth audio device?@Corjan-Meijerink
Exactly, my car has no CarPlay.
The same happens, if I just connect a headphone.
Can even try another apple device -
Can even try another apple deviceOk, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
I even tried to change to English language.
Every time the same. -
Can even try another apple device@Haug said in Audio cuttet via Bluetooth:
Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
Directly via speaker in the phone, there is no problem -
Ok, could you reproduce this error?
@Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
@Con-Hennekens said in Audio cuttet via Bluetooth:
That's an interesting concept !
I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
@Aiello-antonino
I would switch to iOS 26.2.. -
Honestly, I think I'll wait any longer, I still read about a lot of problems...
In the 5.0.1 update coming week it will be possible to configure your own audio delay
@Corjan-Meijerink said in Audio cuttet via Bluetooth:
where can we configure this?
@Nomko-Nomden Navigation settings > Audio
@Aiello-antonino
Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset -
@Corjan-Meijerink:
Hello Corjan, today I tested several things regarding Audio via Bluetooth.-
Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
- Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
now the interesting thing!
- Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
I really have the feeling, that the delay slider is not working at all in MRA.
Could you pleas check again?Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
Many Thanks in Advance and Regards
Günter
@Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
Yes, I read your test! Indeed interesting.
I will check the audio delay setting in the upcoming 5.1 update
