  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
    I've this problem also. Already for a while. It was introcduced in one of the latest 4.** version.
    My headset did not change. The software of the headset did not change. The settings of my headset did not change.
    The android auto setup did not change (built-in Honda Goldwing). The software of the Goldwing did not change.
    The Android phone did not change.
    But...
    Offcourse there where severall software updates on my phone. MRA, Android Auto app, others apps.
    When i play Spotify or other media, the audio of MRA is not cut of at the front. But if MRA is only source of audio. Then the first word or words (about 0.5-1 sec of text) is cut off.
    This behaviour is in my situation very stable.
      In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
      nomko 1 Reply Last reply
      • Haug
        Haug
        Haug
        One remark: it has nothing to do with AA oder CarPlay, it’s even if you connect your iPhone directly via bluetooth without any CarPlay or android auto.
        • Haug Haug
          @Haug, Probably, but only when your head unit is doing the audio ducking of music playing from the head unit itself.
          Haug 1 Reply Last reply
            Haug
            Haug
            Haug
            @Con-Hennekens I never hear Musik during motorcycling, I just listen to my boxer 😉
            • Haug Haug
              @Haug, Sometimes I do, only when driving alone. But that is not the point. I don't use AA on the bike. I do in my car. No boxer sounds te prefer there 😉
                Haug
                Haug
                Haug
                I use chigee with CarPlay but as I wrote, it has nothing to do with CP because the sound goes not via CarPlay and the cut of the voice is there, when contacted via Bluetooth to a headset or even to my Autoradio
                • Haug Haug
                  @Haug, Yes, same thing... It happens not AA specifically indeed, but when an audio headend has its own failing logic for when to lower its music channel in favor of instructions from your phone, instead of trusting the priority commands of the connected equipment. So you are correct, it also happens with other then AA connections.
                  Most important thing: has it been solved for your specific setup?
                  • Haug Haug
                    Hello MRA User,
                    I have the Problem, that Audio commands via bluetooth a cuttet at beginning. When I use Audio Output via the iPhone speaker, everything works fine.
                    For sure it has to do with Delay to the Bluetooth device.
                    On other Apps you can set up a Delay for Bluetooth Audio.
                    Anybody Else with this Problem?
                    Thanks
                    Günter
                    Robert Laudensack
                    Robert Laudensack
                    Robert Laudensack
                    @Haug Yes I also noticed cut voice prompts. It starts saying something, but the cuts of in the middle of it
                    • Haug
                      Haug
                      Haug
                      I set now a delay of 2 sec but the beginning of the speech is still cuttet.
                      • Haug Haug
                        @Haug, can you please check the version of the app?
                        Main screen, tap the account icon top right, scroll completely down.
                        What's the number there?
                          @Con-Hennekens We all know what number it says 🙂
                          This setting has only been available since the last update!
                          @Haug If the delay does not work could you share the following info?
                          • What phone are you using?
                          • What version of the above?
                          • Does the delay setting actually add a delay (disregard that you still have the issue but is there a noticeable different between 0 and 2 seconds)
                            #25
                            @Corjan-Meijerink, yes of course, but I wanted him to find out for himself 😉
                            The pre-public beta had this setting already without the wanted effect, didn't it?
                              Haug
                              Haug
                              Haug
                              Good evening,
                              App version is 5.0.1 - 433
                              I use iPhone 15 with iOS 26.1
                              There is a delay but even at 2 sec it’s not enough
                              • Haug Haug
                                Good evening,
                                Haug
                                Haug
                                Haug
                                Hello Corjan,
                                Today I did some Tests in the car, connected via Bluetooth to my Autoradio. It doesn’t matter, what delay you adjust, the cut at the beginning is always the same length.
                                So I assume,
                                the slider is just fake.
                                Günter
                                • Haug Haug
                                  Hello Corjan,
                                  So I assume,
                                  Günter
                                  @Haug Thanks for your reply!
                                  I can guarantee you, the slider isn't fake 🙂
                                  Your audio system not respecting it, is another thing.
                                  I haven't yet seen any iOS device with these issues.
                                  It's always Android to be honest 😉
                                  I'll test some different configurations to see if I can reproduce this.
                                  Just to be sure, you are not using CarPlay but simply the car radio as bluetooth audio device?
                                    Haug
                                    Haug
                                    Haug
                                    Exactly, my car has no CarPlay.
                                    The same happens, if I just connect a headphone.
                                    Can even try another apple device
                                    Haug MotoCon 2 Replies Last reply
                                    • Haug Haug
                                      Haug
                                      Haug
                                      Haug
                                      Ok, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
                                      The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
                                      I even tried to change to English language.
                                      Every time the same.
                                      • Haug Haug
                                        @Haug said in Audio cuttet via Bluetooth:
                                        Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
                                        Haug 2 Replies Last reply
                                          Haug
                                          Haug
                                          Haug
                                          @Con-Hennekens it’s a Bluetooth headset
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
