  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
    It's a frustrating issue indeed.
    We verified that we do everything correctly (in theory) 😉
    I've delayed the start of the audio instructions by 1 second if you are connected to Android Auto but Android Auto almost seems to ignore this.
    As users also indicate, the behavior differs depending on if you are listening to the car radio or to spotify. But we don't know what you are listening to.
    We simply communicate to Android:
    • MyRoute-app wants priority
    • Please "duck" (lower the volume of) other apps
    • Wait 1 second (if connected to Android Auto) otherwise we don't add an extra wait
    • Speak the instruction
    • Tell the OS we are finished so other audio can gain priority again
    This is how it should work and how it works well for a lot of users.
    The whole ecosystem of Android, the amount of different (bluetooth) configurations, Flutter as development platform and our priorities simply don't help in getting this solved 🙂
      @Corjan-Meijerink, Indeed, the 1 second pause did seem to help, but it is just not enough, for my specific case I mean. You absolutely cannot introduce a longer pause everyone not having this problem 😉 My theory, not being held back by any knowledge, is that some AA devices simply do not honour the "wants priority" command, but listen to audio (voice) itself and decide (too late) to duck for themselves.
      Yes, but that is quite logical. When playing spotify (or anything else) from your phone, the media channel is continuously open. The phone ducks spotify, and not AA.
      • Haug
        Haug
        Haug
        In scenic for instance, I have 2 seconds audio delay and it works perfect.
        • Haug
          Haug
          Haug
          Remark: this happens even, if the iPhone is directly connected to Bluetooth headphones without CP or AA
          • Haug Haug
            @Haug, thanks for this. This proves that not only MRA is struggling with this problem...
            @Corjan-Meijerink, what do you think about this?
              I've this problem also. Already for a while. It was introcduced in one of the latest 4.** version.
              My headset did not change. The software of the headset did not change. The settings of my headset did not change.
              The android auto setup did not change (built-in Honda Goldwing). The software of the Goldwing did not change.
              The Android phone did not change.
              But...
              Offcourse there where severall software updates on my phone. MRA, Android Auto app, others apps.
              When i play Spotify or other media, the audio of MRA is not cut of at the front. But if MRA is only source of audio. Then the first word or words (about 0.5-1 sec of text) is cut off.
              This behaviour is in my situation very stable.
                In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                nomko 1 Reply Last reply
                • Haug
                  Haug
                  Haug
                  One remark: it has nothing to do with AA oder CarPlay, it’s even if you connect your iPhone directly via bluetooth without any CarPlay or android auto.
                  • Haug Haug
                    @Haug, Probably, but only when your head unit is doing the audio ducking of music playing from the head unit itself.
                    Haug 1 Reply Last reply
                      Haug
                      Haug
                      Haug
                      @Con-Hennekens I never hear Musik during motorcycling, I just listen to my boxer 😉
                      • Haug Haug
                        @Haug, Sometimes I do, only when driving alone. But that is not the point. I don't use AA on the bike. I do in my car. No boxer sounds te prefer there 😉
                          Haug
                          Haug
                          Haug
                          I use chigee with CarPlay but as I wrote, it has nothing to do with CP because the sound goes not via CarPlay and the cut of the voice is there, when contacted via Bluetooth to a headset or even to my Autoradio
                          • Haug Haug
                            @Haug, Yes, same thing... It happens not AA specifically indeed, but when an audio headend has its own failing logic for when to lower its music channel in favor of instructions from your phone, instead of trusting the priority commands of the connected equipment. So you are correct, it also happens with other then AA connections.
                            Most important thing: has it been solved for your specific setup?
                            • Haug Haug
                              Hello MRA User,
                              I have the Problem, that Audio commands via bluetooth a cuttet at beginning. When I use Audio Output via the iPhone speaker, everything works fine.
                              For sure it has to do with Delay to the Bluetooth device.
                              On other Apps you can set up a Delay for Bluetooth Audio.
                              Anybody Else with this Problem?
                              Thanks
                              Günter
                              Robert Laudensack
                              Robert Laudensack
                              Robert Laudensack
                              @Haug Yes I also noticed cut voice prompts. It starts saying something, but the cuts of in the middle of it
                              • Haug
                                Haug
                                Haug
                                I set now a delay of 2 sec but the beginning of the speech is still cuttet.
                                • Haug Haug
                                  @Haug, can you please check the version of the app?
                                  Main screen, tap the account icon top right, scroll completely down.
                                  What's the number there?
                                    @Con-Hennekens We all know what number it says 🙂
                                    This setting has only been available since the last update!
                                    @Haug If the delay does not work could you share the following info?
                                    • What phone are you using?
                                    • What version of the above?
                                    • Does the delay setting actually add a delay (disregard that you still have the issue but is there a noticeable different between 0 and 2 seconds)
                                      #25
                                      @Corjan-Meijerink, yes of course, but I wanted him to find out for himself 😉
                                      The pre-public beta had this setting already without the wanted effect, didn't it?
                                        Haug
                                        Haug
                                        Haug
                                        Good evening,
                                        App version is 5.0.1 - 433
                                        I use iPhone 15 with iOS 26.1
                                        There is a delay but even at 2 sec it’s not enough
                                        • Haug Haug
                                          Good evening,
                                          Haug
                                          Haug
                                          Haug
                                          Hello Corjan,
                                          Today I did some Tests in the car, connected via Bluetooth to my Autoradio. It doesn’t matter, what delay you adjust, the cut at the beginning is always the same length.
                                          So I assume,
                                          the slider is just fake.
                                          Günter
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
