  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
  • Haug Haug
    I use chigee with CarPlay but as I wrote, it has nothing to do with CP because the sound goes not via CarPlay and the cut of the voice is there, when contacted via Bluetooth to a headset or even to my Autoradio
    @Haug, Yes, same thing... It happens not AA specifically indeed, but when an audio headend has its own failing logic for when to lower its music channel in favor of instructions from your phone, instead of trusting the priority commands of the connected equipment. So you are correct, it also happens with other then AA connections.
    Most important thing: has it been solved for your specific setup?
    • Haug Haug
      Hello MRA User,
      I have the Problem, that Audio commands via bluetooth a cuttet at beginning. When I use Audio Output via the iPhone speaker, everything works fine.
      For sure it has to do with Delay to the Bluetooth device.
      On other Apps you can set up a Delay for Bluetooth Audio.
      Anybody Else with this Problem?
      Thanks
      Günter
      Robert Laudensack
      Robert Laudensack
      Robert Laudensack
      @Haug Yes I also noticed cut voice prompts. It starts saying something, but the cuts of in the middle of it
      • Haug
        Haug
        Haug
        I set now a delay of 2 sec but the beginning of the speech is still cuttet.
        • Haug Haug
          @Haug, can you please check the version of the app?
          Main screen, tap the account icon top right, scroll completely down.
          What's the number there?
            @Con-Hennekens We all know what number it says 🙂
            This setting has only been available since the last update!
            @Haug If the delay does not work could you share the following info?
            • What phone are you using?
            • What version of the above?
            • Does the delay setting actually add a delay (disregard that you still have the issue but is there a noticeable different between 0 and 2 seconds)
            Haug 1 Reply Last reply
              #25
              @Corjan-Meijerink, yes of course, but I wanted him to find out for himself 😉
              The pre-public beta had this setting already without the wanted effect, didn't it?
                Haug
                Haug
                Haug
                Good evening,
                App version is 5.0.1 - 433
                I use iPhone 15 with iOS 26.1
                There is a delay but even at 2 sec it’s not enough
                • Haug Haug
                  Good evening,
                  Haug
                  Haug
                  Haug
                  Hello Corjan,
                  Today I did some Tests in the car, connected via Bluetooth to my Autoradio. It doesn’t matter, what delay you adjust, the cut at the beginning is always the same length.
                  So I assume,
                  the slider is just fake.
                  Günter
                  • Haug Haug
                    Hello Corjan,
                    So I assume,
                    Günter
                    @Haug Thanks for your reply!
                    I can guarantee you, the slider isn't fake 🙂
                    Your audio system not respecting it, is another thing.
                    I haven't yet seen any iOS device with these issues.
                    It's always Android to be honest 😉
                    I'll test some different configurations to see if I can reproduce this.
                    Just to be sure, you are not using CarPlay but simply the car radio as bluetooth audio device?
                      Haug
                      Haug
                      Haug
                      Exactly, my car has no CarPlay.
                      The same happens, if I just connect a headphone.
                      Can even try another apple device
                      Haug MotoCon 2 Replies Last reply
                      • Haug Haug
                        Haug
                        Haug
                        Haug
                        Ok, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
                        The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
                        I even tried to change to English language.
                        Every time the same.
                        • Haug Haug
                          @Haug said in Audio cuttet via Bluetooth:
                          Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
                          Haug 2 Replies Last reply
                            Haug
                            Haug
                            Haug
                            @Con-Hennekens it’s a Bluetooth headset
                              Haug
                              Haug
                              Haug
                              Directly via speaker in the phone, there is no problem
                              • Haug Haug
                                Haug
                                Haug
                                Haug
                                Ok, could you reproduce this error?
                                • Haug Haug
                                  @Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
                                  richard 3v Haug 2 Replies Last reply
                                    richard 3v
                                    richard 3v
                                    richard 3v
                                    @Con-Hennekens said in Audio cuttet via Bluetooth:
                                    That's an interesting concept !
                                      Haug
                                      Haug
                                      Haug
                                      I do use Intercom on my bike but I repeat: the same Problem exist with my carradio (Bluetooth Connection) and with a jabra Bluetooth headphone.
                                      • Haug
                                        Haug
                                        Haug
                                        Did something change about this issue in the latest update?
                                        • Aiello antonino
                                          #39
                                          I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
