  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
  • Haug Haug
    I set now a delay of 2 sec but the beginning of the speech is still cuttet.
    @Haug, can you please check the version of the app?
    Main screen, tap the account icon top right, scroll completely down.
    What's the number there?
      @Con-Hennekens We all know what number it says 🙂
      This setting has only been available since the last update!
      @Haug If the delay does not work could you share the following info?
      • What phone are you using?
      • What version of the above?
      • Does the delay setting actually add a delay (disregard that you still have the issue but is there a noticeable different between 0 and 2 seconds)
      Haug 1 Reply Last reply
        #25
        @Corjan-Meijerink, yes of course, but I wanted him to find out for himself 😉
        The pre-public beta had this setting already without the wanted effect, didn't it?
          Haug
          Haug
          Haug
          Good evening,
          App version is 5.0.1 - 433
          I use iPhone 15 with iOS 26.1
          There is a delay but even at 2 sec it’s not enough
          • Haug Haug
            Good evening,
            Haug
            Haug
            Haug
            Hello Corjan,
            Today I did some Tests in the car, connected via Bluetooth to my Autoradio. It doesn’t matter, what delay you adjust, the cut at the beginning is always the same length.
            So I assume,
            the slider is just fake.
            Günter
            • Haug Haug
              Hello Corjan,
              So I assume,
              Günter
              @Haug Thanks for your reply!
              I can guarantee you, the slider isn't fake 🙂
              Your audio system not respecting it, is another thing.
              I haven't yet seen any iOS device with these issues.
              It's always Android to be honest 😉
              I'll test some different configurations to see if I can reproduce this.
              Just to be sure, you are not using CarPlay but simply the car radio as bluetooth audio device?
                Haug
                Haug
                Haug
                Exactly, my car has no CarPlay.
                The same happens, if I just connect a headphone.
                Can even try another apple device
                Haug MotoCon 2 Replies Last reply
                • Haug Haug
                  Haug
                  Haug
                  Haug
                  Ok, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
                  The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
                  I even tried to change to English language.
                  Every time the same.
                  • Haug Haug
                    @Haug said in Audio cuttet via Bluetooth:
                    Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
                    Haug 2 Replies Last reply
                      Haug
                      Haug
                      Haug
                      @Con-Hennekens it’s a Bluetooth headset
                        Haug
                        Haug
                        Haug
                        Directly via speaker in the phone, there is no problem
                        • Haug Haug
                          Haug
                          Haug
                          Haug
                          Ok, could you reproduce this error?
                          • Haug Haug
                            @Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
                            richard 3v Haug 2 Replies Last reply
                              richard 3v
                              richard 3v
                              richard 3v
                              @Con-Hennekens said in Audio cuttet via Bluetooth:
                              That's an interesting concept !
                                Haug
                                Haug
                                Haug
                                I do use Intercom on my bike but I repeat: the same Problem exist with my carradio (Bluetooth Connection) and with a jabra Bluetooth headphone.
                                • Haug
                                  Haug
                                  Haug
                                  Did something change about this issue in the latest update?
                                  • Aiello antonino
                                    #39
                                    I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
                                    • Hubert Thoring
                                      @Aiello-antonino
                                      I would switch to iOS 26.2..
                                      • Aiello antonino
                                        #41
                                        Honestly, I think I'll wait any longer, I still read about a lot of problems...
                                          In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                                          Banned
                                          @Corjan-Meijerink said in Audio cuttet via Bluetooth:
                                          where can we configure this?
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
