  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 27.4k Views 7 Watching
  • Haug Haug
    Exactly, my car has no CarPlay.
    The same happens, if I just connect a headphone.
    Can even try another apple device
    Haug Offline
    Haug Offline
    Haug
    Ok, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
    The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
    I even tried to change to English language.
    Every time the same.
    • Haug Haug
      @Haug said in Audio cuttet via Bluetooth:
      Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
      Haug 2 Replies Last reply
        Haug Offline
        Haug Offline
        Haug
        @Con-Hennekens it’s a Bluetooth headset
          Haug Offline
          Haug Offline
          Haug
          Directly via speaker in the phone, there is no problem
          Haug 1 Reply Last reply
          • Haug Haug
            Haug Offline
            Haug Offline
            Haug
            Ok, could you reproduce this error?
            • Haug Haug
              @Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
              richard 3v Haug 2 Replies Last reply
                richard 3v Offline
                richard 3v Offline
                richard 3v
                @Con-Hennekens said in Audio cuttet via Bluetooth:
                That's an interesting concept !
                  Haug Offline
                  Haug Offline
                  Haug
                  I do use Intercom on my bike but I repeat: the same Problem exist with my carradio (Bluetooth Connection) and with a jabra Bluetooth headphone.
                  • Haug Offline
                    Haug Offline
                    Haug
                    Did something change about this issue in the latest update?
                    • Aiello antonino Offline
                      #39
                      I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
                      • Hubert Thoring Online
                        @Aiello-antonino
                        I would switch to iOS 26.2..
                        iPad 9. Gen iOS 26.6.1/ iPhone 16e iOS 26.6.1 / Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                          #41
                          Honestly, I think I'll wait any longer, I still read about a lot of problems...
                            In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                            nomko Online
                            nomko Online
                            Banned
                            @Corjan-Meijerink said in Audio cuttet via Bluetooth:
                            where can we configure this?
                            • nomko nomko
                              Nick Carthew Online
                              Nick Carthew Online
                              @Nomko-Nomden Navigation settings > Audio
                                Haug Offline
                                Haug Offline
                                Haug
                                @Aiello-antonino
                                Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
                                • Haug Offline
                                  Haug Offline
                                  Haug
                                  Any new experience about this problem?
                                  • Haug Offline
                                    Haug Offline
                                    Haug
                                    @Corjan-Meijerink:
                                    Hello Corjan, today I tested several things regarding Audio via Bluetooth.
                                    1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                      1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                    2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                    3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                    now the interesting thing!
                                    1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
                                    Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
                                    I really have the feeling, that the delay slider is not working at all in MRA.
                                    Could you pleas check again?
                                    Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
                                    Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
                                    Many Thanks in Advance and Regards
                                    Günter
                                    • Haug Offline
                                      Haug Offline
                                      Haug
                                      @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                                      • Corjan Meijerink Offline
                                        Yes, I read your test! Indeed interesting.
                                        I will check the audio delay setting in the upcoming 5.1 update 🙂
                                          I've made some changes in 5.0.4! 😃
                                          • 4
                                          Haug
                                          Haug
                                          richard 3v
                                          richard 3v
                                          Jan Weerheim
                                          Jan Weerheim
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Update 5.2.2 - Quick fix
                                            ginogino
                                            ginogino
                                            1.3k
                                          • Waypoint list for a long route ( ~50 t0 100 routing points) will not be show on the Android auto ridernav screen
                                            Stevedo 6 0
                                            Stevedo 6 0
                                          • scherm bevrirzing
                                          • Position Arrow
                                          • Carpuride W702 icm Carplay
                                            17.5k
                                            335
                                            Ioan Dragulescu
                                            Ioan Dragulescu
                                            10.3k
