  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
    In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
    Banned
    @Corjan-Meijerink said in Audio cuttet via Bluetooth:
    where can we configure this?
    • nomko nomko
      @Nomko-Nomden Navigation settings > Audio
        I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
        Haug
        Haug
        Haug
        @Aiello-antonino
        Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
        • Haug
          Haug
          Haug
          Any new experience about this problem?
          • Haug
            Haug
            Haug
            @Corjan-Meijerink:
            Hello Corjan, today I tested several things regarding Audio via Bluetooth.
            1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
            2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
            3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
            now the interesting thing!
            1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
            Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
            I really have the feeling, that the delay slider is not working at all in MRA.
            Could you pleas check again?
            Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
            Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
            Many Thanks in Advance and Regards
            Günter
            • Haug
              Haug
              Haug
              @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                Yes, I read your test! Indeed interesting.
                I will check the audio delay setting in the upcoming 5.1 update 🙂
                  I've made some changes in 5.0.4! 😃
                  Haug 1 Reply Last reply
                    Haug
                    Haug
                    Haug
                    @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
                    Many thanks for your support.
                    Günter
                    • Haug Haug
                      Günter
                      @Haug Glad to read my changes seem to work! 🙂
                        #52
                        I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                        My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                        I did hear differences but not what i expected.
                        I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                        The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                        B.t.w I have a Sena SRL 3 headset.
                        • Haug
                          Haug
                          Haug
                          Hallo everybody,
                          since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
                          Did you change anything? Can you check please?
                          Thanks
                          Günter
                          • Haug
                            Haug
                            Haug
                            @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                              The same issue with current final and previous final release. The slider doesn't work as it should.
                              When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                              • Haug
                                Haug
                                Haug
                                For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                                • Haug
                                  Haug
                                  Haug
                                  @corjan-meijerink : any News about this Problem?
                                  • Haug
                                    Haug
                                    Haug
                                    @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                                    • Haug
                                      Haug
                                      Haug
                                      Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                                      Also no response from you @corjan-meijerink
                                      This is not very friendly!
                                        Haug
                                        Haug
                                        Haug
                                        @M.-Schrijver
                                        Hello M.
                                        have you still the Audio Problem like me?
                                        First second of the Audio command is missing.
                                        Thanks and regards
                                        Günter
                                          With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                                          during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
