  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 30.3k Views 7 Watching
  • Haug
    Haug
    Haug
    Any new experience about this problem?
    • Haug
      Haug
      Haug
      @Corjan-Meijerink:
      Hello Corjan, today I tested several things regarding Audio via Bluetooth.
      1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
        1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
      2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
      3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
      now the interesting thing!
      1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
      Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
      I really have the feeling, that the delay slider is not working at all in MRA.
      Could you pleas check again?
      Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
      Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
      Many Thanks in Advance and Regards
      Günter
      • Haug
        Haug
        Haug
        @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
          Yes, I read your test! Indeed interesting.
          I will check the audio delay setting in the upcoming 5.1 update 🙂
            I've made some changes in 5.0.4! 😃
            Haug 1 Reply Last reply
              Haug
              Haug
              Haug
              @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
              Many thanks for your support.
              Günter
              • Haug Haug
                Günter
                @Haug Glad to read my changes seem to work! 🙂
                  #52
                  I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                  My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                  I did hear differences but not what i expected.
                  I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                  The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                  B.t.w I have a Sena SRL 3 headset.
                  • Haug
                    Haug
                    Haug
                    Hallo everybody,
                    since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
                    Did you change anything? Can you check please?
                    Thanks
                    Günter
                    • Haug
                      Haug
                      Haug
                      @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                        The same issue with current final and previous final release. The slider doesn't work as it should.
                        When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                        • Haug
                          Haug
                          Haug
                          For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                          • Haug
                            Haug
                            Haug
                            @corjan-meijerink : any News about this Problem?
                            • Haug
                              Haug
                              Haug
                              @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                              • Haug
                                Haug
                                Haug
                                Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                                Also no response from you @corjan-meijerink
                                This is not very friendly!
                                  Haug
                                  Haug
                                  Haug
                                  @M.-Schrijver
                                  Hello M.
                                  have you still the Audio Problem like me?
                                  First second of the Audio command is missing.
                                  Thanks and regards
                                  Günter
                                    With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                                    during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                                    • Haug
                                      Haug
                                      Haug
                                      If you have a Media playing during Navigation with MRA, the Audio commands work without any Problem. This is due to an open bluetooth Connection with music. But I have normally during motorcycle ride no music playing.
                                      • Haug Haug
                                        It's still a public forum and this is not a support ticket 🙂
                                        Pushing me definitely won't help me finding motivation for looking into an issue one users reports.
                                        From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
                                        • Haug
                                          Haug
                                          Haug
                                          Ok clear, but it seems, I am not the only one with this problem.
                                          For me it means, that the MRA is not useable anymore.
                                          • 4
                                          Haug
                                          Haug
                                          richard 3v
                                          richard 3v
                                          Jan Weerheim
                                          Jan Weerheim
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            133
                                            Jörg Neudert
                                            Jörg Neudert
                                            4.7k
                                            4.8k
                                          • Hallo, wéér een nieuwe gebruiker !
                                          • MRA Shop für Merchandise geschlossen ?
