  3. Routes can not be uploaded
38 Posts 13 Posters 17.3k Views 5 Watching
  • Michel van Hagen MRA-Founder
    Administrator
    Probleem opgelost!
    Met de nodige zweetdruppels is het gelukt om de database te repareren. Alles werkt weer zoals het hoort!
    Problem solved!
    With the necessary drops of sweat we managed to repair the database. Everything works as it should again!
    Problem gelöst!
    Mit den nötigen Schweißtropfen ist es uns gelungen, die Datenbank zu reparieren. Alles funktioniert wieder wie es sollte!
    Paulette Silvius 1 Reply Last reply
    • Michael Janker Michael Janker
      Re: Problem editing routes.
      Does the BD problem affect this as well? Routes are not beeing recognized when uploaded, either ITN nor GPX.
      Best regards, Michael
      @Michael-Janker
      Problem is solved
      Kudee 1 Reply Last reply
        Probleem opgelost!
        Problem solved!
        Problem gelöst!
        Paulette Silvius
        Paulette Silvius
        Paulette Silvius
        @Michel-van-Hagen-MRA-Founder In mra-navigation routes niet te loaden. Foutmelding: verbinding met server niet mogelijk.
        M.vr.gr.
        Paulette Silvius
        • Reinhard-32
          @Matt-Flaming Try to move one waypoint along the route for some meters. That will initiate an new calculation. Maybe it helps.
          Kindly regards
          Reinhard
          Montana 700i and Mac
          • Reinhard-32
            @Matt-Flaming Sometimes ist helps to reinstall the navigation app.
            Kindly regards
            Reinhard
            • Reinhard-32
              @Matt-Flaming Ok. It seems to me some database elements from the affected routes are damaged.
              Wether they can be repaired ? I don’t know. On your computer copy one of the routes for testing. The copy should create new database entries. Otherwise export the route under „save as“ in the gpx format and then import again.
              Hopefully it helps.
              Kindly regards
              Reinhard
              • Paulette Silvius
                Paulette Silvius
                Paulette Silvius
                wrote on last edited by Paulette Silvius
                @Matt-Flaming I have the same problem!
                I can only delete a route, not open, copy or download a route in Navigation.
                A route made in Navigation does work once and then gives the problem.
                  @Michael-Janker
                  Problem is solved
                  Kudee
                  Kudee
                  Kudee
                  wrote on last edited by Kudee
                  @Hans-van-de-Ven-MRA-Master Thats realy bad! Can't download Routes I planed and App is blocked!!!Blocked.jpg Restarting the Mobile makes the trick but still no download.
                  • Kudee Kudee
                    @Kudee
                    No problem here, can save the routes both via the MRA Planner and via the MRA Modile app, MRA Navigation also works normally (Iphone 7s)
                    Kudee Paulette Silvius 2 Replies Last reply
                      @Kudee
                      Kudee
                      Kudee
                      Kudee
                      @Hans-van-de-Ven-MRA-Master Can't open all the Routes I have been working, touched yesterday. Old ones are ok. Using Android. Just Uploaded the Route above giving a new Name: 3. Kosice - Mizhhiria 317km TMP, can't open it. Restarted Mobile, getting Message "No connection to Server" Internet is fine. Changed Route to Public, so someone can check please
                      daz 2 1 Reply Last reply
                        @Kudee
                        Paulette Silvius
                        Paulette Silvius
                        Paulette Silvius
                        @Hans-van-de-Ven-MRA-Master Hier hetzelfde probleem: Gisteren MRA-Navigation aangeschaft, waarschijnlijk in de tijd dat er problemen waren bij MRA betreffende de server. Zo'n beetje alles al geprobeerd. Mijn partner gebruikt MRA(-Navigation) al vanaf het eerste uur...
                        Helpt het als ik het MRA-account geheel verwijder? De routes zijn daar wel te laden en te veranderen. Alleen in Navigation geeft het laden een server-foutmelding.
                        • Paulette Silvius Paulette Silvius
                          M.vr.gr.
                          Paulette Silvius
                          Kudee
                          Kudee
                          Kudee
                          @Paulette-Silvius IOS or Anroid?
                          • Kudee Kudee
                            Paulette Silvius
                            Paulette Silvius
                            Paulette Silvius
                            @Kudee Android, but not related to Samsung of an other brand of phone...
                              Kudee
                              Kudee
                              Kudee
                              @Paulette-Silvius Seems only Anroid Phone are effected, Hope Hans will replay soon
                              Paulette Silvius Reinhard-32 2 Replies Last reply
                              • Kudee Kudee
                                Paulette Silvius
                                Paulette Silvius
                                Paulette Silvius
                                @Kudee It is not a phone-problem. I also can't open the routes on my partner's phone when I login with my data.
                                Did you already try to delete the MRA-account? We didn"t try yet...
                                  Kudee
                                  Kudee
                                  Kudee
                                  @Paulette-Silvius No, hope thats not nessesary otherwise I have to download all the maps again I assume
                                  • Kudee Kudee
                                    Paulette Silvius
                                    Paulette Silvius
                                    Paulette Silvius
                                    @Kudee Then I am gonna try ...
                                    I have understood that I"ll loose the access to my MRA-Navigation (and no refund possible) if I delete the MRA-account. So I will not do that of course...
                                    • Kudee Kudee
                                      #19
                                      @Kudee Yes, android phones are affected. I created a test route with the web frontend today. On my IPHONE the test route can be opened but with my outdoor android phone I got an error message.
                                      Android app version 1.6.2 and android 8.1
                                      Kindly regards
                                      Reinhard
                                      • Reinhard-32 Reinhard-32
                                        Kudee
                                        Kudee
                                        Kudee
                                        @Reinhard-32 Thanks for testing, maybe helpfull for Hans
                                        • Kudee Kudee
                                          daz 2
                                          daz 2
                                          daz 2
                                          @Kudee Yes also having the same issue, even deleted the routes I made yesterday and created a new short test route today and cannot view on the navigation app. The error message "cannot communicate with the server" show on screen.
                                          Kudee
                                          Kudee
                                          Spili
                                          Spili
                                          daz 2
                                          daz 2
                                          Stelios Poulman
                                          Stelios Poulman
                                          Catalina
                                          Catalina
                                          Virtua
                                          Virtua
                                          Paulette Silvius
                                          Paulette Silvius
                                          Michael Janker
                                          Michael Janker
                                          • MRA Studio export speed
                                          • Hiya from UK
                                            Russ Nattrass 1
                                            Russ Nattrass 1
                                          • geeft routepunt niet weer
