  4. Saving to Tom Tom mydrive
14 Posts 6 Posters 5.0k Views 2 Watching
  • Tony 13
    Tony 13
    Tony 13
    Saving a route to Tom Tom MyDrive is accessed from the "save as" menu when a route is displayed.
    Quite often I am saving 7-14 routes at time and it gets a bit labourious.
    Couple of suggestions:
    Include your Tom Tom account email address in Profile details so this box just populates.
    Add access from the 3 dot menu in your list of routes. There is a "save as" function here but it does not include saving to MyDrive
    regards
    Tony
    Drabslab 1 Reply Last reply
    • Tony 13 Tony 13
      regards
      Tony
      Drabslab
      Drabslab
      Drabslab
      @Tony-13
      Which TomTom device are you using?
      Two weeks ago I downloaded 13 routes from the Myroute planner to a TomTom rider 400 in less than 2 minutes using a simple USB cable.
      Hence, I am a bit puzzled why you need TomTOm mydrive?
      Dave J 0 Mike Simpson 2 Replies Last reply
      • Drabslab Drabslab
        @Tony-13
        @Drabslab if you are using the mobile apps then you need to load routes into My drive and enable sync to see these routes under 'My Routes'. I would support @Tony-13 having the MyDrive login details stored for when I need to load to My drive. I use the TomTom mobile app as a back up to Next.
        Ducati Multistrada V4 Rally
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        • Drabslab Drabslab
          @Tony-13
          Mike Simpson
          Mike Simpson
          Mike Simpson
          @Drabslab I find saving to TomTom Mydrive useful as it shows if my planned route is affected by road closures or is going to be delayed due to roadworks.
          • Tony 13
            Tony 13
            Tony 13
            Sorry been away
            I am using a Rider 550. This does not allow a direct conncection like the Rider 400. You have to go through mydrive
            • Tony 13 Tony 13
              Sorry been away
              @Tony-13 said in Saving to Tom Tom mydrive:
              Sorry been away
              You can have a direct connection to your PC via the supplied TomTom USB cable.
              First of all save all of the routes that you want to transfer to your 550 to your PC, save them using the top option GPX 1.1 (Route, track, POI)
              Connect your 550 to your PC with the supplied cable, TomToms can be fussy about the cable that is used.
              When your TomTom fires up, touch the Import routes option on the TomTom screen. This makes your TT visible in Windows Explorer as a separate drive.
              Now find your routes (highlight them all) and drag and drop them into your TomTom.
              There is no need to use TT MyDrive.
              • Tony 13
                Tony 13
                Tony 13
                I really did not expect that import over a USB cable to work, thought i had tried before but probably gave up too soon. Yes I had to go and find the original cable, and it had to be plugged in directly to my laptop (not a USB-C multiport)
                It has given me two versions of each file, one suffixed track and the other not, but both identical tracks when i open them
                • Tony 13 Tony 13
                  @Tony-13 If you want a route with visible route points, save the route as an .itn file and upload it to your TT the same way.
                  Stanisław 1 Reply Last reply
                    Stanisław
                    Stanisław
                    Stanisław
                    @Nick-Carthew IMHO you can simply use connector app and export function, it works correctly via USB to TT550, I don't have to save routes on the disk first.
                    Regards
                    Staszek
                    • Stanisław Stanisław
                      @Stanisław said in Saving to Tom Tom mydrive:
                      Correct, but the original question for this topic was about loading several routes and saving time, with the connector you can only load one route at a time.
                        Stanisław
                        Stanisław
                        Stanisław
                        @Nick-Carthew I see, anyway saving as GPX is also possible only one by one, so the same time needed, right?
                        Regards
                        Staszek
                          No, you can save multiple .gpx files by dragging and dropping them to your TomTom too.
                            Stanisław
                            Stanisław
                            Stanisław
                            @Nick-Carthew Dragging from your local disc, agree, but first you have to save them to the disc from MRA planner one by one. For me it is easier to export them to TT directly one by one but any way is good 🙂
                            Regards
                            Staszek
                            • Tony 13
                              Tony 13
                              Tony 13
                              this is turning out even more useful
                              Thanks for the tip on.itn files. Thought I would never see a way point on my Tom Tom again.
                              Also that the connector app actually does work! Again I guess I stupidly never tried it using the TT supplied USB cable. My techy knowledge stops at - "its digital, how can a cable make a difference"
                              Tony 13
                              Tony 13
                              Stanisław
                              Stanisław
                              Drabslab
                              Drabslab
                              Mike Simpson
                              Mike Simpson
                              • Help please, new user
                                Bull Tahr
                                Bull Tahr
                              • My Routeapp Stays questions
                                802
                              • MRA 6.0.0 (515) Live Tracking - What exactly is shared?
