  4. Saving to Tom Tom mydrive
14 Posts 6 Posters 5.2k Views 2 Watching
  • Tony 13
    Tony 13
    Tony 13
    Sorry been away
    I am using a Rider 550. This does not allow a direct conncection like the Rider 400. You have to go through mydrive
    • Tony 13 Tony 13
      Sorry been away
      @Tony-13 said in Saving to Tom Tom mydrive:
      Sorry been away
      You can have a direct connection to your PC via the supplied TomTom USB cable.
      First of all save all of the routes that you want to transfer to your 550 to your PC, save them using the top option GPX 1.1 (Route, track, POI)
      Connect your 550 to your PC with the supplied cable, TomToms can be fussy about the cable that is used.
      When your TomTom fires up, touch the Import routes option on the TomTom screen. This makes your TT visible in Windows Explorer as a separate drive.
      Now find your routes (highlight them all) and drag and drop them into your TomTom.
      There is no need to use TT MyDrive.
      • Tony 13
        Tony 13
        Tony 13
        I really did not expect that import over a USB cable to work, thought i had tried before but probably gave up too soon. Yes I had to go and find the original cable, and it had to be plugged in directly to my laptop (not a USB-C multiport)
        It has given me two versions of each file, one suffixed track and the other not, but both identical tracks when i open them
        • Tony 13 Tony 13
          @Tony-13 If you want a route with visible route points, save the route as an .itn file and upload it to your TT the same way.
          Stanisław 1 Reply Last reply
            Stanisław
            Stanisław
            Stanisław
            @Nick-Carthew IMHO you can simply use connector app and export function, it works correctly via USB to TT550, I don't have to save routes on the disk first.
            Staszek
            • Stanisław Stanisław
              @Stanisław said in Saving to Tom Tom mydrive:
              Correct, but the original question for this topic was about loading several routes and saving time, with the connector you can only load one route at a time.
                Stanisław
                Stanisław
                Stanisław
                @Nick-Carthew I see, anyway saving as GPX is also possible only one by one, so the same time needed, right?
                Staszek
                  No, you can save multiple .gpx files by dragging and dropping them to your TomTom too.
                    Stanisław
                    Stanisław
                    Stanisław
                    @Nick-Carthew Dragging from your local disc, agree, but first you have to save them to the disc from MRA planner one by one. For me it is easier to export them to TT directly one by one but any way is good 🙂
                    Staszek
                    • Tony 13
                      Tony 13
                      Tony 13
                      this is turning out even more useful
                      Thanks for the tip on.itn files. Thought I would never see a way point on my Tom Tom again.
                      Also that the connector app actually does work! Again I guess I stupidly never tried it using the TT supplied USB cable. My techy knowledge stops at - "its digital, how can a cable make a difference"
                      Stanisław
                      Stanisław
                      Tony 13
                      Tony 13
                      Mike Simpson
                      Mike Simpson
                      • Audio cuttet via Bluetooth
                        Haug
                        Haug
                        35.5k
                      • One crash today
                      • Download club route folders
                        135
                        peha
                        peha
                        Mosimann
                        Mosimann
                      • Elektrisch rijden
                        John mq
                        John mq
