  4. Saving to Tom Tom mydrive
14 Posts 6 Posters 5.2k Views 2 Watching
  • Drabslab Drabslab
    @Tony-13
    Which TomTom device are you using?
    Two weeks ago I downloaded 13 routes from the Myroute planner to a TomTom rider 400 in less than 2 minutes using a simple USB cable.
    Hence, I am a bit puzzled why you need TomTOm mydrive?
    @Drabslab if you are using the mobile apps then you need to load routes into My drive and enable sync to see these routes under 'My Routes'. I would support @Tony-13 having the MyDrive login details stored for when I need to load to My drive. I use the TomTom mobile app as a back up to Next.
    iPhone 18 Pro
    • Drabslab Drabslab
      @Tony-13
      Mike Simpson
      Mike Simpson
      Mike Simpson
      @Drabslab I find saving to TomTom Mydrive useful as it shows if my planned route is affected by road closures or is going to be delayed due to roadworks.
      • Tony 13
        Tony 13
        Tony 13
        Sorry been away
        I am using a Rider 550. This does not allow a direct conncection like the Rider 400. You have to go through mydrive
        • Tony 13 Tony 13
          Sorry been away
          @Tony-13 said in Saving to Tom Tom mydrive:
          Sorry been away
          You can have a direct connection to your PC via the supplied TomTom USB cable.
          First of all save all of the routes that you want to transfer to your 550 to your PC, save them using the top option GPX 1.1 (Route, track, POI)
          Connect your 550 to your PC with the supplied cable, TomToms can be fussy about the cable that is used.
          When your TomTom fires up, touch the Import routes option on the TomTom screen. This makes your TT visible in Windows Explorer as a separate drive.
          Now find your routes (highlight them all) and drag and drop them into your TomTom.
          There is no need to use TT MyDrive.
          • Tony 13
            Tony 13
            Tony 13
            I really did not expect that import over a USB cable to work, thought i had tried before but probably gave up too soon. Yes I had to go and find the original cable, and it had to be plugged in directly to my laptop (not a USB-C multiport)
            It has given me two versions of each file, one suffixed track and the other not, but both identical tracks when i open them
            • Tony 13 Tony 13
              @Tony-13 If you want a route with visible route points, save the route as an .itn file and upload it to your TT the same way.
              Stanisław 1 Reply Last reply
                Stanisław
                Stanisław
                Stanisław
                @Nick-Carthew IMHO you can simply use connector app and export function, it works correctly via USB to TT550, I don't have to save routes on the disk first.
                Staszek
                • Stanisław Stanisław
                  @Stanisław said in Saving to Tom Tom mydrive:
                  Correct, but the original question for this topic was about loading several routes and saving time, with the connector you can only load one route at a time.
                    Stanisław
                    Stanisław
                    Stanisław
                    @Nick-Carthew I see, anyway saving as GPX is also possible only one by one, so the same time needed, right?
                    Staszek
                      No, you can save multiple .gpx files by dragging and dropping them to your TomTom too.
                        Stanisław
                        Stanisław
                        Stanisław
                        @Nick-Carthew Dragging from your local disc, agree, but first you have to save them to the disc from MRA planner one by one. For me it is easier to export them to TT directly one by one but any way is good 🙂
                        Staszek
                        • Tony 13
                          Tony 13
                          Tony 13
                          this is turning out even more useful
                          Thanks for the tip on.itn files. Thought I would never see a way point on my Tom Tom again.
                          Also that the connector app actually does work! Again I guess I stupidly never tried it using the TT supplied USB cable. My techy knowledge stops at - "its digital, how can a cable make a difference"
                          Stanisław
                          Stanisław
                          Tony 13
                          Tony 13
                          Mike Simpson
                          Mike Simpson
                          • Audio cuttet via Bluetooth
                            Haug
                            Haug
                            35.5k
                          • One crash today
                          • Download club route folders
                            135
                            peha
                            peha
                            Mosimann
                            Mosimann
                          • Elektrisch rijden
                            John mq
                            John mq
