  4. Many problems navigating my route
23 Posts 9 Posters 3.2k Views 3 Watching
  • Christian Feurstein
    Christian Feurstein
    Christian Feurstein
    @gianluca-0
    wondering which setting you have used during your route planning? Standard or TomTom or HERE?
    • Gianluca 0
      Gianluca 0
      Gianluca 0
      Tom tom or Here, I don't remember.
      I can't reply quickly 'cause I have to wait one hour between a post and another. How can I earn reputation points? Do it depends by number of posts?
      You can check out anytime you like, but you can never leave.
      Currently BMW R1200 RS "Gertrud", TomTom Ride, Carpuride 602BS, Vivo V50 5G.
      • Marinus van Deudekom
        Of the export gpx worked well with Osmand its probably the case that you've planned the route using the OSM map. Could you check that. And like already stated please the route's url here and make shure it's set to public so we can help you
        • Leike Lodiers
          wrote on last edited by Leike Lodiers
          Do you use the free version of MRA or the gold version?? When using the free version you only have access to the OSM card. When i lock at you're route lots of waypoints are not placed on the road but next to the road or even further. When planning check you're waypoint if they are placed correct. Don't put you're start and finish point so close together. Put you're starting point further up the road so you ride to you're starting point and the gps makes no mistakes in seeing the wrong point or missing it and keeps sending you back.
          Gianluca 0 1 Reply Last reply
          • Hubert Thoring
            @gianluca-0
            What @leike-lodiers writes is very important and should definitely be taken into account.
            The route is planned in TomTom algorithms, the window s. Image comes when starting the navigation on my mobile phone, so it leads to the fact that it is actively navigated as a route track, traffic data is also missing.
            Please switch to Here algorithm, then it will be navigated correctly.
            And please do not let the route navigate over such a long distance, divide it into 3-4 sections.
            From experience, I would basically divide such a long route. I think on 3-4 sections especially in the mountains 300km a day is enough.
            • In my planning, the routes at 300km have approx. 50 -70 waypoints (WP) or Sharping Point (SP)
            • It helps to always set a point safely in the direction of travel at certain turns
            • Check WP on the Here map, should always be on a road !!
            • Leike Lodiers Leike Lodiers
              Gianluca 0
              Gianluca 0
              Gianluca 0
              @Leike-Lodiers thank you for answer.
              I have gold subscription.
              The problems I had were far away from start/finish point. The fact is that te route planned at a certain point, became different from the one saved, with some deviations kilometers away and then back on the same (wrong) road. Sorry, I didn't screenshot them. Yesterday I tried again to put in navigation mode and the problem did't appear.
              Next time I will look at with attention where waypoint are placed, surely. And i will be sure to use Here maps in planning.
              PS: what about Cheegee on your BMW bike?
              Leike Lodiers 1 Reply Last reply
                @gianluca-0
                Gianluca 0
                Gianluca 0
                Gianluca 0
                Hi, thanks for answering.
                "And please do not let the route navigate over such a long distance, divide it into 3-4 sections." -> ok, I will do this way. But may I know the technical reason? Is it lighter to elaborate for the phone?
                "Please switch to Here algorithm, then it will be navigated correctly." -> you mean when I plan or also navigating? When I open "Route Lab" to plan, I receive the message that the route creation mode works only with Tomtom or Here maps, maybe I choosed Tomtom this time. On the phone I can't choose the map on which navigate, just the theme of it, is it right?
                I never used shaping points, I didn't ever know them existence... I have to search something about.
                Thank you again
                • Gianluca 0 Gianluca 0
                  Thank you again
                  @Gianluca-0
                  It is important to use the correct planning map for your navigation device.
                  Each planning map comes with its own set of algorithms embedded within the map data to calculate which roads to use.
                  The algorithms are unique to each planning map.
                  So if you use MRA Navigation Next you should use the HERE planning map.
                  After choosing the HERE planning map you can also click Always use this map for new routes to set the HERE map as your default planning map.
                  From now on all new routes will be created using the HERE planning map.
                  My screenshot below shows the planning map from HERE is selected and also the option to Always use this map for new routes.
                  The overlay maps are separate to the planning maps and have no effect on route calculations.
                  Think of them as clear sheets with extra information that you place over the top of the planning map.
                  The planning map underneath does all of the route calculations.
                  So with the HERE planning map selected you can then use any of the overlay maps.
                  If you do not see the same blue menu bar with the planning maps that is shown in my screenshot, click Page menu first and then all of the same options will be available to you.
                    @Gianluca-0
                    Gianluca 0
                    Gianluca 0
                    Gianluca 0
                    wrote on last edited by Gianluca 0
                    @Nick-Carthew sooooo clear!
                    Thank you!
                    I imagine that "Tomtom" option is to be used if you are going to export the route to a tomtom navigator.
                      @Gianluca-0 what about chigee? Works fine for me until now. Have it about 1000km now. Have to get used to handle the bmw wheel for operating chigee.
                        Thank you!
                        @Gianluca-0 [said](/post/
                        Correct, also some BMW navigation devices use the TomTom map.
                        • Mzokk
                          The MRA route planner and OSMand do indeed work very well together. I use MyRoute app most of the time for navigation, but do occasionally use OSMand for motorcycle navigation using Android Auto on my Africa Twin. OSMand follows the track of the route not the route itself so rarely goes "wrong". However, the track does not include "Via Points" on a route designed using MRA and provides no option to skip a portion of the route automatically or otherwise as it is following the track not a series of waypoints. I'd imagine you've maybe gone astray in your route planning somewhere or there are specific issues with the mix of hardware in use? I've been using the navigation app with AA on my Africa twin for over a year now in preference to my Garmin Zumo XT with very few navigation issues.
                          • paul69
                            hi @gianluca-0
                            this looks like a very nice route, albeit very long for single route.
                            as a small example I looked at the Trieste area of your map and if you look at the screen shot you will observe the many different routes available with Here, OSM and Tom Tom,
                            when I plan a long route I always use the compare tool to see of there are any other possible ways I could be routed. I would then add more shaping points to force the route to the way I want, some will say this is excessive, but it works for me and I very rarely if at all stray from my original planned route, except for the dreaded umleitung of course.
                            K1600 GTL
                            iPhone 13 Pro, carpuride 702b
                            • LennyO
                              And do no forget to test "disable seasonal closures" to see if it changes the route mileage and takes a different pass...
                              • paul69 paul69
                                hi @gianluca-0
                                Gianluca 0
                                Gianluca 0
                                Gianluca 0
                                #19
                                @paul69 I never userd before shaping points, I hava to try.
                                What's the issue about too long tracks?
                                Good advice, thank you
                                paul69 1 Reply Last reply
                                • LennyO LennyO
                                  Gianluca 0
                                  Gianluca 0
                                  Gianluca 0
                                  @Lenny-O Uh... I'll sure give a try to this feature
                                  Thank you
                                  • Gianluca 0
                                    Gianluca 0
                                    Gianluca 0
                                    Well, raeading your precious indications, I have replicated the issue and understand why it happened.
                                    The track was made with Tomtom map and reading it with MRA navigator gave this crazy result.
                                    Many of you understood the snag.
                                    Thank you all a lot, my next trip (last August week, about 2500 km in Romania) will be smooth ! I'll cut it in daily tracks of 3/400 km and use the correct map to plan !
                                      hi,
                                      there is nothing wrong with long routes, if I were to ride this route it would be split into 2/3 separate routes and start and finish at the hotels✌️
                                      K1600 GTL
                                      • Gianluca 0
                                        Gianluca 0
                                        Gianluca 0
                                        Christian Feurstein
                                        Christian Feurstein
                                        Gianluca 0
                                        Gianluca 0
                                        • Newsletter optimisation
                                        • How can I change colours in the route overview?
                                          Kudee
                                          Kudee
                                        • Next: Ich brauche Hilfe zu POI und Favoriten!
                                        • MRA AI Routeplanner - Improvement
                                        • route aanklikken in overzichtskaart
                                        • Walking route options
