  4. Expand
Expand
33 Posts 7 Posters 4.9k Views 2 Watching
  • Martin Woodford
    Martin Woodford
    Martin Woodford
    Absolutely not. This is my original 14 point route
    https://www.myrouteapp.com/route/open/13569227
    • Martin Woodford
      Martin Woodford
      Martin Woodford
      The new point number 8 can be identified as an MRA expand point because it's labelled "waypoint" the ones I manually placed have road numbers
      • Martin Woodford
        Martin Woodford
        Martin Woodford
        I don't see how "expanding a route in witch a tunnel or Ferry plays a roll, you"ll get strange results. So no mistake by MRA" can be the case. Why should a tunnel or ferry mean the results are strange ? I'm in Norway at the moment, there are hundreds of tunnels and ferries should I expect strange results everytime one is on my route ?
        BMcG 1 Reply Last reply
        • Marinus van Deudekom
          The problem occurs when you expansie the route.
          In your original route you can see that the order of the shapingpoints is not logical. See my screenshot.
          • Martin Woodford
            Martin Woodford
            Martin Woodford
            Hi @marinus-van-deudekom
            Thanks for your comments. The screenshot you show is from the expanded route. This is my original 14 point, 377.32 mile route. In a moment I'll expand it in MRA and screenshot it again (MRA makes the changes in realtime and I don't know how to save versions of the original and expanded route)
            • Martin Woodford
              Martin Woodford
              Martin Woodford
              This is the expanded version. Please note the location of the new waypoint 8 and it's description.
              • Martin Woodford
                Martin Woodford
                Martin Woodford
                I will now reset the original in MRA
                • Martin Woodford Martin Woodford
                  BMcG
                  BMcG
                  BMcG
                  @Martin-Woodford the web site planner is pretty long in the tooth, you can holler at the moon for what it is worth but nothing is going to be updated with the current version
                  there are plans for a complete revamp of the web site planner, what the time line is I have no clue
                  MRA is only a small team & they do not have the resources to fix all the old issues like this & also produce a new revamped planner
                  till the new site update, I am sorry but you will just have to learn to keep an eye on the mileage
                  • Martin Woodford
                    Martin Woodford
                    Martin Woodford
                    Did you find a problem with my original 14 point route ?
                    If you expand it to 15 points do you get the same problem with the new waypoint 8 ?
                    Thanks
                      Thanks
                      @Martin-Woodford Yes I did because points 6, 7 and 8 were not in a logical order. In my screenshot you'll see the dark black line
                      • Don Stauffer
                        Don Stauffer
                        Don Stauffer
                        In my case, the original route was fine, and I double checked it using the ''simulation" feature. The problem occurred only after expanding. There was, however, a ferry involved in the route. Apparently the 'expand' feature does not like water!
                        • Martin Woodford
                          Martin Woodford
                          Martin Woodford
                          Hi @don-stauffer
                          My original was fine as well (see posts #21 and #22 above).
                          In the absence of anything from MRA it looks like the very useful and helpful tips from @brian-mcg are the way to go.
                            Unless you have us the wrong route to start with you seem to be unable to notice your own mistake
                            • Martin Woodford
                              Martin Woodford
                              Martin Woodford
                              I tried, but clearly failed, to explain the situation in posts #21 and #22 above. As I said in post #23 the route is now set to my original 14 waypoints (including start and end), 377.32 miles.
                              For your own satisfaction maybe you'd like to try opening it and using expand increase the number of waypoints to 15. See what happens.
                                The expand function is not much more than placing new route points at calculated intervals. There is no AI or human logic incorporated. Logic you will need to apply yourself afterwards. I doubt that that will ever change. Therefore I always place my own route points. The expand function adds too many anyway. As far as I am concerned, it does not return on the new web planner at all.
                                  BMcG
                                  BMcG
                                  BMcG
                                  In another thread you asked why I would worry about the baby being thrown out with the bath water with the new web planner
                                  The omission of the expand function would be the sort of thing that for me would be not an upgrade/update but a downgrade, the baby going out 😂
                                  The expand function is not perfect but it does have it's uses & people do use it
                                  An smarter cleverer expand function is what the new planner should have if the new planner is to be an improvement
                                  • Stevedo 6 0
                                    Stevedo 6 0
                                    Stevedo 6 0
                                    I also find the Expand feature to be extremely frustrating at times. Here's an example where I created a 293.63km route with 8 waypoints. I currently export my routes to my Garmin 595 so want to Expand the route to include some extra shaping points. I Expand the route to 15 points total and the new route goes from 293.63km to 553.54km!!!! Note that my original points are all in the correct order.
                                    I sure hope that this feature can both be retained and improved in the new planner as when it works it can be very useful.
                                    Don Stauffer
                                    Don Stauffer
                                    BMcG
                                    BMcG
                                    Stevedo 6 0
                                    Stevedo 6 0
                                    Martin Woodford
                                    Martin Woodford
                                    • tracklog not created during navigate
                                    • Road book printen
                                    • Navigating on NEX
                                    • Add waypoints to favorites and management of favorites with Next
                                      Parantapa
                                      Parantapa
