  4. Creating POI lists with MRA
17 Posts 9 Posters 4.1k Views
    @Martin-W
    You can create your own POI list. It is laborious.
    Open a new route - go to <Points of interest> in the left column and choose the middle tab <Manage> - Click "Add" and place your POI, name it. Repeat with all the POIs you want to create.
    Then go to the menu at the top of the screen and choose <Save as>. There you will find the option for POI.
    Then go to <Routlab> and choose <Upload> and in the next window "POI". Follow the clue.
    Your POI list is now listed under the "Library" tab
    martin-phogel.deundefined Offline
    martin-phogel.de
    @Jack-van-Tilburg
    wow - all thumbs up!
    I hadn't discovered that yet - a good way to define your own POIs. Thanks for the tip!
    The option to save the result as POIs and upload works well, but is indeed complicated.
    In the meantime, I like the way via a "dummy route" as a copy template a bit. One advantage is that POIs contained in a route (tab <manage>) are always visible on the map, regardless of the zoom level. This is different for POIs from an existing collection (<Search>, <Library>).
    • Don Staufferundefined Offline
      Don Stauffer
      @Jack-van-Tilburg @Jack-van-Tilburg I have been following this with interest. I opened a route that had POI's that I created. I followed the procedure as described.
      I then created a new route, and I was able to upload my POI file (CSV), and see the POI group listed in POI Library.
      However, I do not see the saved POIs on my new, empty route. I set the check mark in the Library tab, but I see nothing on the map, and the Manage tab is empty.
      I was expecting a reusable library of user POIs that could be used on any route.
      Perhaps I am misunderstanding the use of the POI library, or perhaps I am missing a step.
      I would appreciate clarification on the POI Library feature.
      Thank You!
      • Don Staufferundefined Don Stauffer
        Thank You!
        martin-phogel.de
        @Don-Stauffer
        My understanding so far:
        1. POI collections in <Search> are available for all users in all new (and existing) routes.
        2. POIs in <Library> are also available in all routes, but only for the user who added the collection with upload.
        3. POIs in <Manage>, on the other hand, are bound to exactly this route.
        So when you create a new route, you can access the POIs in 1. and 2. but not in 3. (from other routes)
        Therefore my idea: I create a route as a template for a trip and add all POIs there that I want to visit and that are not included in 1. or 2. When I then plan individual routes, I do not create new routes but always copy the template.
        The way you described should work and the POIs in <Library> should be visible. Maybe you have to zoom in a bit more.
        • martin-phogel.deundefined martin-phogel.de
          @Don-Stauffer
          Jack van Tilburg
          @Martin-W
          In general you are right.
          Additional information can be found in this support article.
          Manual POI's
          I don't think my description to make your own POI list is included
            When I plan a motorbike trip, I first make a list of POIs that I (probably) want to visit.
            In the second step, I plan individual routes in which I add the corresponding POIs as Viapoints. In the process, of course, I sometimes discover more POIs that I want to add to my list.
            However, I cannot create a POI list within MRA Route Planner.
            The only way I can think of is to plan a dummy route in which I collect the various POIs together. If a certain point is already included in an existing POI collection (either the lists included in MRA or one of my own uploaded list), I can add it as a POI to the route. I can then split or copy the dummy route into individual routes to plan my day trips.
            If I want to add POIs that are not already in a collection, I have to create favourites instead - which I don't want to do because I use favourites for a different purpose.
            All in all, it's not really a smooth way.
            Alternatively, I could create my POI list with another app and then load it into MRA. That works fine - but of course I would like to do everything with MRA ๐Ÿ™‚
            Any ideas for a better workflow?
            Drabslabundefined Offline
            @Martin-W
            I think that the whole POI/Favorites aspect in the routeplanner could use a serious update. And now that we have Next, the limitations of other GPS devices are less important.
            In myview, POI and Favorites are largely the same.
            Maybe I write a "suggestion" on this topic
            • Drabslabundefined Drabslab
              @Martin-W
              martin-phogel.de
              @Drabslab said in Creating POI lists with MRA:
              This can lead to long and endless discussions ๐Ÿ™‚
              But I agree. If I had a way to manage "my own POIs" well, I would not need "favorites".
              After all, the topic is already on the MRA Routeplanner roadmap. I am a new user, so my question is: Is there typically information available in advance about a planned new or changed feature, so that users can contribute their ideas?
                Jack van Tilburg
                @Martin-W said in Creating POI lists with MRA:
                You can take a look at the The road to MRA Routeplanner point 1.9
                  @Martin-W
                  Nigel Ralphsonundefined Offline
                  Nigel Ralphson
                  @Jack-van-Tilburg said in Creating POI lists with MRA:
                  Hi, this may sound stupid but I cant find <Points of interest> in the left column. In fact, I cant see a left column on my screen.
                  • Nigel Ralphsonundefined Nigel Ralphson
                    @Nigel-Ralphson, click this arrow:
                    Nigel Ralphsonundefined 1 Reply Last reply
                      Nigel Ralphson
                      @Con-Hennekens Aaahhhh thank you!! Told you I was stupid!! ๐Ÿ™„
                        Nick Carthewundefined Online
                        @Nigel-Ralphson said in Creating POI lists with MRA:
                        No, youโ€™re not stupid, a stupid person wouldnโ€™t ask for help ๐Ÿ˜‰
                          @Nick-Carthew said in Creating POI lists with MRA:
                          Exactly!
                          @Nigel-Ralphson, I wish all questions were this easy to answer ๐Ÿ˜‰
                            Ruud den Blankenundefined Offline
                            Ruud den Blanken
                            @Martin-Wilcke I browsed the forum to see if others already suggested enabling a more natural way in MRA for planning multiday trips. You suggestion comes close to my wish:
                            I create a new folder and would like it to contain the POI's and routes for a series of days. I first want to enter all overnight stays as POI's, so I can use them as endpoint for a day trip and use it again as a starting point the next day.
                            A workaround is to define all trip POI's as Favourites but this means various multiday trips share alle POI's, unless you remove them from the list again afterwards.
                            I read here that new POI functionality is coming. My suggestion is enable POI's for a series of routes to be put in a folder just like the routes itself.
                            Don Stauffer
                            martin-phogel.de
                            Jack van Tilburg
                            Nigel Ralphson
                            Drabslabundefined
                            Ruud den Blanken
                            • Carpuride scherm vast
                              De Ploey Georgesundefined
                              De Ploey Georges
                              197
                            • I just want to browse the map!
                              white.mouseundefined
                            • Three new scenic routes in southern England
                              richtea999undefined
                              Nick Dawsonundefined
                              Nick Dawson
                            • Move blocks of routepoints
                              Yannick_van_Vugtundefined
                              Yannick_van_Vugt
                            • Roundabout Symbol and Exit Number
                            • Export To My Nav 5 Fails
                              Brian Dingsdale 0undefined
                              Brian Dingsdale 0
                              Kirsten De Weerdundefined
                              Kirsten De Weerd
                              489
