  4. Creating POI lists with MRA
17 Posts 9 Posters 4.7k Views
  • martin-phogel.de Online
    martin-phogel.de
    When I plan a motorbike trip, I first make a list of POIs that I (probably) want to visit.
    In the second step, I plan individual routes in which I add the corresponding POIs as Viapoints. In the process, of course, I sometimes discover more POIs that I want to add to my list.
    However, I cannot create a POI list within MRA Route Planner.
    The only way I can think of is to plan a dummy route in which I collect the various POIs together. If a certain point is already included in an existing POI collection (either the lists included in MRA or one of my own uploaded list), I can add it as a POI to the route. I can then split or copy the dummy route into individual routes to plan my day trips.
    If I want to add POIs that are not already in a collection, I have to create favourites instead - which I don't want to do because I use favourites for a different purpose.
    All in all, it's not really a smooth way.
    Alternatively, I could create my POI list with another app and then load it into MRA. That works fine - but of course I would like to do everything with MRA ๐Ÿ™‚
    Any ideas for a better workflow?
    Marinus van Deudekom TorqueRider Drabslab Ruud den Blanken 4 Replies Last reply
      Marinus van Deudekom Offline
      @Martin-W or add the poi after you created a route
        martin-phogel.de
        @Marinus-van-Deudekom
        I would like to create a POI list and have these POIs displayed on the map so that I can plan my routes along the POIs and set Viapoints (as close as possible to a POI but always on the road).
        To be able to transfer the POIs together with the route as waypoints to my Garmin Zumo XT would be a nice add-on, but not my main goal.
          TorqueRider Offline
          TorqueRider Offline
          @Martin-W
          You can create your own POI list. It is laborious.
          Open a new route - go to <Points of interest> in the left column and choose the middle tab <Manage> - Click "Add" and place your POI, name it. Repeat with all the POIs you want to create.
          Then go to the menu at the top of the screen and choose <Save as>. There you will find the option for POI.
          Then go to <Routlab> and choose <Upload> and in the next window "POI". Follow the clue.
          Your POI list is now listed under the "Library" tab
          martin-phogel.de Nigel Ralphson 2 Replies Last reply
          • TorqueRider TorqueRider
            @Martin-W
            martin-phogel.de
            @Jack-van-Tilburg
            wow - all thumbs up!
            I hadn't discovered that yet - a good way to define your own POIs. Thanks for the tip!
            The option to save the result as POIs and upload works well, but is indeed complicated.
            In the meantime, I like the way via a "dummy route" as a copy template a bit. One advantage is that POIs contained in a route (tab <manage>) are always visible on the map, regardless of the zoom level. This is different for POIs from an existing collection (<Search>, <Library>).
            • Don Stauffer Offline
              Don Stauffer
              @Jack-van-Tilburg @Jack-van-Tilburg I have been following this with interest. I opened a route that had POI's that I created. I followed the procedure as described.
              I then created a new route, and I was able to upload my POI file (CSV), and see the POI group listed in POI Library.
              However, I do not see the saved POIs on my new, empty route. I set the check mark in the Library tab, but I see nothing on the map, and the Manage tab is empty.
              I was expecting a reusable library of user POIs that could be used on any route.
              Perhaps I am misunderstanding the use of the POI library, or perhaps I am missing a step.
              I would appreciate clarification on the POI Library feature.
              Thank You!
              • Don Stauffer Don Stauffer
                Thank You!
                martin-phogel.de
                @Don-Stauffer
                My understanding so far:
                1. POI collections in <Search> are available for all users in all new (and existing) routes.
                2. POIs in <Library> are also available in all routes, but only for the user who added the collection with upload.
                3. POIs in <Manage>, on the other hand, are bound to exactly this route.
                So when you create a new route, you can access the POIs in 1. and 2. but not in 3. (from other routes)
                Therefore my idea: I create a route as a template for a trip and add all POIs there that I want to visit and that are not included in 1. or 2. When I then plan individual routes, I do not create new routes but always copy the template.
                The way you described should work and the POIs in <Library> should be visible. Maybe you have to zoom in a bit more.
                  @Don-Stauffer
                  TorqueRider Offline
                  TorqueRider Offline
                  @Martin-W
                  In general you are right.
                  Additional information can be found in this support article.
                  Manual POI's
                  I don't think my description to make your own POI list is included
                    Drabslab Offline
                    Drabslab Offline
                    @Martin-W
                    I think that the whole POI/Favorites aspect in the routeplanner could use a serious update. And now that we have Next, the limitations of other GPS devices are less important.
                    In myview, POI and Favorites are largely the same.
                    Maybe I write a "suggestion" on this topic
                    • Drabslab Drabslab
                      @Martin-W
                      martin-phogel.de
                      @Drabslab said in Creating POI lists with MRA:
                      This can lead to long and endless discussions ๐Ÿ™‚
                      But I agree. If I had a way to manage "my own POIs" well, I would not need "favorites".
                      After all, the topic is already on the MRA Routeplanner roadmap. I am a new user, so my question is: Is there typically information available in advance about a planned new or changed feature, so that users can contribute their ideas?
                        TorqueRider Offline
                        TorqueRider Offline
                        @Martin-W said in Creating POI lists with MRA:
                        You can take a look at the The road to MRA Routeplanner point 1.9
                          @Martin-W
                          Nigel Ralphson Offline
                          Nigel Ralphson
                          @Jack-van-Tilburg said in Creating POI lists with MRA:
                          Hi, this may sound stupid but I cant find <Points of interest> in the left column. In fact, I cant see a left column on my screen.
                          • Nigel Ralphson Nigel Ralphson
                            @Nigel-Ralphson, click this arrow:
                            Nigel Ralphson 1 Reply Last reply
                              Nigel Ralphson
                              @Con-Hennekens Aaahhhh thank you!! Told you I was stupid!! ๐Ÿ™„
                                Nick Carthew Offline
                                @Nigel-Ralphson said in Creating POI lists with MRA:
                                No, youโ€™re not stupid, a stupid person wouldnโ€™t ask for help ๐Ÿ˜‰
                                  @Nick-Carthew said in Creating POI lists with MRA:
                                  Exactly!
                                  @Nigel-Ralphson, I wish all questions were this easy to answer ๐Ÿ˜‰
                                    Ruud den Blanken Offline
                                    Ruud den Blanken
                                    @Martin-Wilcke I browsed the forum to see if others already suggested enabling a more natural way in MRA for planning multiday trips. You suggestion comes close to my wish:
                                    I create a new folder and would like it to contain the POI's and routes for a series of days. I first want to enter all overnight stays as POI's, so I can use them as endpoint for a day trip and use it again as a starting point the next day.
                                    A workaround is to define all trip POI's as Favourites but this means various multiday trips share alle POI's, unless you remove them from the list again afterwards.
                                    I read here that new POI functionality is coming. My suggestion is enable POI's for a series of routes to be put in a folder just like the routes itself.
                                    Don Stauffer
                                    Don Stauffer
                                    martin-phogel.de
                                    martin-phogel.de
                                    Nigel Ralphson
                                    Nigel Ralphson
                                    Ruud den Blanken
                                    Ruud den Blanken
                                    • New Zealand Routes
                                      Bull Tahr
                                      Bull Tahr
                                    • Saludo
                                      Bull Tahr
                                      Bull Tahr
                                    • Routenplaner on iPad
                                    • Feature Request: Map Contrast & Road Visibility in Navigationโ
                                    • The slow death of Zumo...
                                      Bull Tahr
                                      Bull Tahr
                                      Tom Grzelinski
                                      Tom Grzelinski
                                      827
                                      Tom Grzelinski
                                      Tom Grzelinski
