  4. Creating POI lists with MRA
17 Posts 9 Posters 4.7k Views
    When I plan a motorbike trip, I first make a list of POIs that I (probably) want to visit.
    In the second step, I plan individual routes in which I add the corresponding POIs as Viapoints. In the process, of course, I sometimes discover more POIs that I want to add to my list.
    However, I cannot create a POI list within MRA Route Planner.
    The only way I can think of is to plan a dummy route in which I collect the various POIs together. If a certain point is already included in an existing POI collection (either the lists included in MRA or one of my own uploaded list), I can add it as a POI to the route. I can then split or copy the dummy route into individual routes to plan my day trips.
    If I want to add POIs that are not already in a collection, I have to create favourites instead - which I don't want to do because I use favourites for a different purpose.
    All in all, it's not really a smooth way.
    Alternatively, I could create my POI list with another app and then load it into MRA. That works fine - but of course I would like to do everything with MRA 🙂
    Any ideas for a better workflow?
    Marinus van Deudekom Offline
    @Martin-W or add the poi after you created a route
      martin-phogel.de Online
      martin-phogel.de
      @Marinus-van-Deudekom
      I would like to create a POI list and have these POIs displayed on the map so that I can plan my routes along the POIs and set Viapoints (as close as possible to a POI but always on the road).
      To be able to transfer the POIs together with the route as waypoints to my Garmin Zumo XT would be a nice add-on, but not my main goal.
        TorqueRider Offline
        TorqueRider Offline
        @Martin-W
        You can create your own POI list. It is laborious.
        Open a new route - go to <Points of interest> in the left column and choose the middle tab <Manage> - Click "Add" and place your POI, name it. Repeat with all the POIs you want to create.
        Then go to the menu at the top of the screen and choose <Save as>. There you will find the option for POI.
        Then go to <Routlab> and choose <Upload> and in the next window "POI". Follow the clue.
        Your POI list is now listed under the "Library" tab
        martin-phogel.de Nigel Ralphson 2 Replies Last reply
        • TorqueRider TorqueRider
          @Martin-W
          martin-phogel.de
          @Jack-van-Tilburg
          wow - all thumbs up!
          I hadn't discovered that yet - a good way to define your own POIs. Thanks for the tip!
          The option to save the result as POIs and upload works well, but is indeed complicated.
          In the meantime, I like the way via a "dummy route" as a copy template a bit. One advantage is that POIs contained in a route (tab <manage>) are always visible on the map, regardless of the zoom level. This is different for POIs from an existing collection (<Search>, <Library>).
          • Don Stauffer Offline
            Don Stauffer
            @Jack-van-Tilburg @Jack-van-Tilburg I have been following this with interest. I opened a route that had POI's that I created. I followed the procedure as described.
            I then created a new route, and I was able to upload my POI file (CSV), and see the POI group listed in POI Library.
            However, I do not see the saved POIs on my new, empty route. I set the check mark in the Library tab, but I see nothing on the map, and the Manage tab is empty.
            I was expecting a reusable library of user POIs that could be used on any route.
            Perhaps I am misunderstanding the use of the POI library, or perhaps I am missing a step.
            I would appreciate clarification on the POI Library feature.
            Thank You!
            • Don Stauffer Don Stauffer
              Thank You!
              martin-phogel.de
              @Don-Stauffer
              My understanding so far:
              1. POI collections in <Search> are available for all users in all new (and existing) routes.
              2. POIs in <Library> are also available in all routes, but only for the user who added the collection with upload.
              3. POIs in <Manage>, on the other hand, are bound to exactly this route.
              So when you create a new route, you can access the POIs in 1. and 2. but not in 3. (from other routes)
              Therefore my idea: I create a route as a template for a trip and add all POIs there that I want to visit and that are not included in 1. or 2. When I then plan individual routes, I do not create new routes but always copy the template.
              The way you described should work and the POIs in <Library> should be visible. Maybe you have to zoom in a bit more.
                @Don-Stauffer
                TorqueRider Offline
                TorqueRider Offline
                @Martin-W
                In general you are right.
                Additional information can be found in this support article.
                Manual POI's
                I don't think my description to make your own POI list is included
                  Drabslab Offline
                  Drabslab Offline
                  @Martin-W
                  I think that the whole POI/Favorites aspect in the routeplanner could use a serious update. And now that we have Next, the limitations of other GPS devices are less important.
                  In myview, POI and Favorites are largely the same.
                  Maybe I write a "suggestion" on this topic
                  • Drabslab Drabslab
                    @Martin-W
                    martin-phogel.de
                    @Drabslab said in Creating POI lists with MRA:
                    This can lead to long and endless discussions 🙂
                    But I agree. If I had a way to manage "my own POIs" well, I would not need "favorites".
                    After all, the topic is already on the MRA Routeplanner roadmap. I am a new user, so my question is: Is there typically information available in advance about a planned new or changed feature, so that users can contribute their ideas?
                      TorqueRider Offline
                      TorqueRider Offline
                      @Martin-W said in Creating POI lists with MRA:
                      You can take a look at the The road to MRA Routeplanner point 1.9
                        @Martin-W
                        Nigel Ralphson Offline
                        Nigel Ralphson
                        @Jack-van-Tilburg said in Creating POI lists with MRA:
                        Hi, this may sound stupid but I cant find <Points of interest> in the left column. In fact, I cant see a left column on my screen.
                        • Nigel Ralphson Nigel Ralphson
                          @Nigel-Ralphson, click this arrow:
                          Nigel Ralphson 1 Reply Last reply
                            Nigel Ralphson
                            @Con-Hennekens Aaahhhh thank you!! Told you I was stupid!! 🙄
                              Nick Carthew Offline
                              @Nigel-Ralphson said in Creating POI lists with MRA:
                              No, you’re not stupid, a stupid person wouldn’t ask for help 😉
                                @Nick-Carthew said in Creating POI lists with MRA:
                                Exactly!
                                @Nigel-Ralphson, I wish all questions were this easy to answer 😉
                                  Ruud den Blanken Offline
                                  Ruud den Blanken
                                  @Martin-Wilcke I browsed the forum to see if others already suggested enabling a more natural way in MRA for planning multiday trips. You suggestion comes close to my wish:
                                  I create a new folder and would like it to contain the POI's and routes for a series of days. I first want to enter all overnight stays as POI's, so I can use them as endpoint for a day trip and use it again as a starting point the next day.
                                  A workaround is to define all trip POI's as Favourites but this means various multiday trips share alle POI's, unless you remove them from the list again afterwards.
                                  I read here that new POI functionality is coming. My suggestion is enable POI's for a series of routes to be put in a folder just like the routes itself.
                                  Don Stauffer
                                  Don Stauffer
                                  martin-phogel.de
                                  martin-phogel.de
                                  Nigel Ralphson
                                  Nigel Ralphson
                                  Ruud den Blanken
                                  Ruud den Blanken
                                  • New Zealand Routes
                                    Bull Tahr
                                    Bull Tahr
                                  • Saludo
                                    Bull Tahr
                                    Bull Tahr
                                  • Routenplaner on iPad
                                  • The slow death of Zumo...
                                    Bull Tahr
                                    Bull Tahr
                                    Tom Grzelinski
                                    Tom Grzelinski
                                    827
                                    Tom Grzelinski
                                    Tom Grzelinski
