  2. Announcements
  3. Other standard map
Other standard map
25 Posts 11 Posters 8.0k Views 1 Watching
  • Michel van Hagen MRA-Founderundefined Offline
    Administrator
    wrote on last edited by Michel van Hagen MRA-Founder
    Due to unforeseen problems with the map supplier, we replaced the standard free map and map layers with the OpenStreetMap. We actually think this one is more detailed and nicer...
    Door onvoorziene problemen met de kaartleverancier hebben we de standaard kaart en kaartlagen vervangen door de OpenStreetMap. Deze vinden wij eigenlijk ook gedetailleerder en mooier...
    • Michel van Hagen MRA-Founderundefined Michel van Hagen MRA-Founder pinned this topic on
    • John Robertsundefined Offline
      John Roberts
      Good evening, having created a new route today on MRA I note that you now use Openstreetmap. I tried to download the map as usual to my Garmin sat nav but it would not download?
      Can you please advise is this due to your new map source, if so what do I need to do to download my latest route?
      John Roberts
      Nick Carthewundefined Steve Lynchundefined Con Hennekensundefined 3 Replies Last reply
      • John Robertsundefined John Roberts
        John Roberts
        Nick Carthewundefined Offline
        @John-Roberts I’m not an expert with Garmin but for others to help it would be useful to know what Garmin model you have.
          John Roberts
          Steve Lynchundefined Offline
          Steve Lynch
          @John-Roberts
          In an ideal world you should use the HERE Map for Garmin Devices as slight differences between OSM and HERE maps could cause some minor issues on the Garmin.
          Here maps do require a Gold account however.
          Things to clarify as Nick mentioned:
          Which Garmin Device do you have?
          And also are you using a PC, Mac or MyRoute-App Mobile (iOS or Android) or even going directly to Routelab in a Browser, to transfer routes?
            John Roberts
            @John-Roberts said in Other standard map:
            I assume you mean "route" here, instead om "map". I cannot think of the download of a gpx to be dependent on the chosen map, especially since the OpenStreetMap was present already. Can you show a screenshot of what goes wrong exactly?
            Andries Mulderundefined John Robertsundefined 2 Replies Last reply
              Andries Mulderundefined Offline
              Andries Mulder
              @Michel van Hagen
              I am very un-happy with this, because now I can get differences between the map that MRA is using and the map that my Zumo XT is using.
              It might be better that you resolve your problems with the card supplier as soon as possible, or I am forced to move to another route planner.
              • Andries Mulderundefined Andries Mulder
                @Michel van Hagen
                Jack van Tilburg
                @Andries-Mulder
                Your Zumo XT is using de Here map.
                You can select the Here map in the Menu <Default> to use this always for new routes?
                Does that help you?
                  @Andries-Mulder
                  Does that help you?
                  Drabslabundefined Offline
                  @Jack-van-Tilburg said in Other standard map:
                  Those that help you
                  • Drabslabundefined Drabslab
                    Those that help you
                    Jack van Tilburg
                    @Drabslab said in Other standard map:
                    Those that help you
                    Whaha. Corrected.
                    Sorry
                    • Andries Mulderundefined Offline
                      Andries Mulder
                      @Jack-van-Tilburg
                      It doesn't help me, because thats exactly what is no longer there.
                      It has been changed and that whole menu item is gone, so only one map is there now, which is OSM.
                      Andries Mulderundefined 1 Reply Last reply
                        @Jack-van-Tilburg
                        Andries Mulder
                        @Andries-Mulder
                        Wrong. Its there again or it was always there.
                        So MRA is very good (again)
                        My apologies for my mistake.
                          @Andries-Mulder
                          @Andries-Mulder said in Other standard map:
                          @Andries-Mulder
                          Now we have written evidence that you make mistakes 😊 😀 😇
                          • Baltusundefined Offline
                            Baltus
                            Dear Michel. When will it be possible to make use of the OSM in the navigation app?
                            I bought the app to use aspecially for my bike tours. In MRA it is possible to make very nice bike routes with the OSM. But in the navigation app it is impossible to play them.
                            Best regards, Baltus.
                            Hans van de Ven MR.MRAundefined Steve Lynchundefined sudoleaundefined 3 Replies Last reply
                            • Baltusundefined Baltus
                              @Baltus
                              Hi Baltus, no it is not possible. Navigation uses the Here-map.
                              Con Hennekensundefined Baltusundefined 2 Replies Last reply
                                Steve Lynch
                                @Baltus
                                I am no Cyclist as I have skinny chicken legs, but in theory it would be possible to do this with MyRoute-App Mobile which is free.
                                You would not get turn by turn notifications but a route-track to visually follow.
                                In the screenshot below I have presumed that Purple is a Cycle Route on Wimbledon Common. (I may be wrong but it makes no difference, as you will know the Legend for cycles routes.)
                                Create the Waypoints on the OpenCycleMap Overlay.
                                Then save the file to your Computer/Mobile as gpx 1.0 (route, track, POI).
                                Then import the gpx file as a route-track.
                                Then open the route on your mobile phone in the new MyRoute-App Mobile.
                                  @Baltus
                                  @Hans-van-de-Ven-MRA-Master said in Other standard map:
                                  @Baltus
                                  Where there is a will, there is a way 😉
                                  I think the cycling community is big enough for a serious effort to be made in this regard. Maybe there is room for a specific cycle Navigation app, that DOES use the OSM map? It would make the MRA ecosystem more complete.
                                    @Baltus
                                    @Con-Hennekens said in Other standard map:
                                    @Baltus
                                    The MRA Mobile app is perfect for navigating because of the OSM Cycling map.
                                    Baltusundefined 1 Reply Last reply
                                      @Baltus
                                      Baltus
                                      @Nick-Carthew
                                      Nick, thanks for your reply. Ofcourse you can make bike routes with the MRA- mobile app. That is the same as MRA on the pc. But you can not use the app to navigate. Therefore you need the navigation app. But...... the navigation app only works with Here maps. If you load your OSM bike route.gpx into the navigation app than it rebuild your complete route, because the Here map does not have bikepaths. The new route sends you to the moon and even further.
                                        @Baltus
                                        Baltus
                                        wrote on last edited by Baltus
                                        #19
                                        Hi Hans, thank you for your reply. Unforetunately it is not an answer on my question.
                                        My question was not "If" but "when" will it be possible to make use of OSM maps in the Navigation-app.
                                        I had already a liftime membership on MRA. So I knew already how to make routes for my motortours and how to make biketours.
                                        For my motortours i use my Garmin GPS. But i had no device to ride my bike tours. Later on, when the Navigation-app was introduced, there was mentioned that you do not need a gps device anymore. Simply use your phone or a ruggedized tablet.
                                        But no warning about a ristriction for only Here maps. Also nowedays there is no warning. I think it is a missed opportunity if it stays so.
                                        I think there are enough cyclists to make a special effort for that group
                                        So Hans, please an answer on my question 🙂
                                          @Nick-Carthew
                                          @Baltus said in Other standard map:
                                          @Nick-Carthew
                                          The MRA Mobile app does have a navigation function and is perfect for cycling. Design a route on the OSM planning map (use the OpenCyclemap overlay) and choose cycling as the form of transport. Then open that route in the MRA Mobile app and click the arrow in the bottom right of the screen twice, you will see that the position cursor changes to a blue arrow, you are now in navigation mode. Navigation is only follow the line with no spoken instructions but it does have auto zoom that changes the zoom level with speed.
                                          Jack van Tilburg
                                          Baltusundefined
                                          Baltus
                                          Drabslabundefined
                                          Steve Lynch
                                          sudoleaundefined
                                          sudolea
                                          John Roberts
                                          Andries Mulder
                                          • vraagje over route uit bibliotheek
                                            white.mouseundefined
                                          • route overbrengen naar BMW Navigator 5
                                            1.9k
                                          • ik zoek het goede adres bij soesterberg entree 4 van park vliegbasis
                                            Ralph Janssenundefined
                                            Ralph Janssen
                                          • Start route bij dichtstbijzijnde routepunt werkt niet
                                          • Zoom functie in carplay werkt niet ondanks goede settings
                                          • XT3 File Transfer
                                            David Ficklingundefined
                                            David Fickling
                                          • Multiple users to edit route
                                            Martin Garandundefined
                                            Martin Garand
                                            3.0k
