  4. Is there a file format that is fully compatible with MRA?
47 Posts 11 Posters 29.4k Views 1 Watching
  • Hans Kremers Hans Kremers
    @Albert-van-den-Elsen
    I can understand Maicro's question.
    Accidents or desasters do happen. Either of technical nature or others. Using something as a service makes one dependent on the provider of this service that they will not lose the data, and with the data all the work that has been put into it.
    And one is dependent on the provider continuing the service. Webservices get discontinued more often then you might know. Even with the big players (Google etc) you are never certain.
    So having a method the pull out all the data you have in a platform, is reassuring..
    Regards,
    Hans
    @Hans-Kremers, GPX is the most universal method of transferring routes from one to another program, and if it were me, for that purpose I would use route AND tracks, since only those reassure you of being able to rebuilt a route unchanged.
    Explicitly for transferring routes, to other platforms, any closed source MRA specific file export would be senseless, because others can't import it. The only reassurance you get with that, is that you can reupload your routes completely intact to MRA, in case they lose your data. Also, with it you would be able to take old routes out of the platform to keep it plain and uncomplicated, while keeping the option to reupload them. And in itself that is a worthwhile idea.
      @Maicro thanks for the proposal! 🙂
      Maicro
      Maicro
      Maicro
      @Corjan-Meijerink said in Is there a file format that is fully compatible with MRA?: > thanks for the proposal!
      My thanks goes to you. I enjoy planning routes and I enjoy navigating them. One of the few applications that satisfies all needs in a simple way because it is made by passionate people. congratulations!
      • Maicro
        Maicro
        Maicro
        @Hans-Kremers said in Is there a file format that is fully compatible with MRA?: > @Albert-van-den-Elsen > > I can understand Maicro's question. > > Accidents or disasters happen. Either technical in nature or other. When you use something as a service, you are dependent on the provider of that service not to lose the data, and with the data all the work you put into it. > > And you depend on the provider to continue the service. Web services are discontinued more often than you might know. Even with the big providers (Google, etc.) you can never be sure. > > So it is reassuring to have a method to pull out all the data you have on a platform. > > Greetings, > > Hans
        Thanks a lot! 🙂
        Drabslab 1 Reply Last reply
        • Maicro Maicro
          @Drabslab said in Is there a file format that is fully compatible with MRA?:
          just download them from wikiloc (in gpx format) and upload them to MRA routeplanner.
          Or do i understand you wrongly?
          I am sorry. I speak English very poorly. I meant to imply a rhetorical question. An unanswered question. Sorry for the inconvenience. Thank you very much for your interest. What I wanted to imply is the advantage for users to have a MRA file system that allows us to exchange routes by file exchange.
          Drabslab
          Drabslab
          Drabslab
          @Maicro said in Is there a file format that is fully compatible with MRA?:
          I think your english is excellent. Butmisunderstandings do happen 😉😉
          Maicro 1 Reply Last reply
          • Maicro Maicro
            Thanks a lot! 🙂
            Drabslab
            Drabslab
            Drabslab
            Thanks a lot! 🙂
            For instance, take photobucket as example.
            • Drabslab Drabslab
              Thanks a lot! 🙂
              Yes, but that fileformat does not help much in such a case, if it is a closed source one that cannot be imported anywhere else. The raw data (being the waypoints and a track) is already exportable.
              • Drabslab Drabslab
                Maicro
                Maicro
                Maicro
                My English is very poor. DeppL does a great job 😅
                Hans Kremers
                Hans Kremers
                Albert van den Elsen
                Drabslab
                Drabslab
                Herko ter Horst
                Herko ter Horst
                Lynchy67
                Lynchy67
                Maicro
                Maicro
                • Log in
                  Rod Sydenham
                  Rod Sydenham
                  44
                • Snelmenu / Quick menu
                • AI pricing is too high
                • Segment function with the HERE map
                  Emanuele 5
                  Emanuele 5
                • Library Structure
                  John Matthews 0
                  John Matthews 0
                • Nieuw start punt maar krijg de route niet hernummerd in logische volgorde
                  Juudje39
                  Juudje39
                • Adding default break times for viapoint icons
                • Feature request: Het aanmaken en kopiëren van routes in een gedeelde bibliotheek
                  ValléeDesFées
                  ValléeDesFées
