  4. Some routes opening slow and some fast
16 Posts 6 Posters 1.4k Views 3 Watching
    @ConiKost
    What Corjan writes can be found here in the POI settings.
    If too much is selected, everything is always loaded and transferred, limited to 2000 POI ..
      @ConiKost do you have the link to the route of image 2?
      I see POIs displayed, do you by any chance have a massive POI library selected to load / display on the map?
      ConiKostundefined Offline
      ConiKost
      @Corjan-Meijerink said in Some routes opening slow and some fast:
      See PN.
      I have multiple POIs library uploaded, but only one is active on the route, which opens slow. The active one contains about ~80-120 POIs at max, that shouldn't be the cause?
      Shiny!
      • ConiKostundefined ConiKost
        See PN.
        @ConiKost Sounds like something you can test yourself quite easily! 🙂
        If you turn the POIs off, does it load quickly?
        • ConiKostundefined Offline
          ConiKost
          @Corjan-Meijerink I did give a try and indeed it's faster. I this correct, that I need always to disable those POIs in web planer, as app does not seem to have an option for this per route? Or am I just blind and don't see it? Because that would be already very helpful, when you want to disable it.
          Regarding the number, I had it wrong in mind. My POI category has ~270 points in it. Still I would not expect that much slow down? I mean, those are not relevant when loading the route initially? Maybe they could be just loaded later in the process?
          Shiny!
            Thanks for confirming the POI's being a factor.
            I will investigate this later but definitely not soon.
            See this manual for showing / hiding certain POI groups for your entire profile / route: https://support.myrouteapp.com/en/support/solutions/articles/12000103938-manual-pois-
            ConiKostundefined 1 Reply Last reply
              ConiKost
              Thanks! 👍
              I am confused. This is the procedere, how to do it website aka MRA webplanner, which I also did. I meant the Android/iOS navigation app. Or I am missunderstand here?
              Shiny!
                Switching on and off is only possible in the route lab, there is no function in the app
                In the route lab:
                  ConiKost
                  #14
                  Thanks for confirming. That was my question, that I need to use the web planner and cannot use the app for that, to switch it on or off. So an option in app would be very handy 🙂
                  Shiny!
                    Nick Carthewundefined Offline
                    @ConiKost said in Some routes opening slow and some fast:
                    There is an option in app. Tap Route lab from the mobile app to access the website.
                      ConiKost
                      @Nick-Carthew said in Some routes opening slow and some fast:
                      Sure, but it's still the website, not a native app function 😉
                      Shiny!
                      nomkoundefined
                      ConiKostundefined
                      ConiKost
                      • Round trip problem sending me down gravel
                      • Sharing Routes and Tracklogs
                      • Expand
                      • Allow Roadbook PDF Attachments for MRA Routes
                        Meesterundefined
                        Meester
                        Peter Zehentreiterundefined
                        26
                        31
                        1.4k
                      • Volume te zacht.
                        Massimo Cardoneundefined
                        Massimo Cardone
                      • How to share a route with someone that only has the free app
                      • Question regarding how road closures are handled in MRA NN version 5.2
