  4. Some routes opening slow and some fast
16 Posts 6 Posters 2.1k Views 3 Watching
  • ConiKost ConiKost
    Yes, the start all from the same point basically, but differ a little bit. Still, I don't see any common between them.
    Banned
    @ConiKost said in Some routes opening slow and some fast:
    Diifers as in..... longer route? More waypoints/viapoints/shaping points? More POI's? Different map to be loaded?
    It could also be a bad recipient between your phone and the nearest transmission tower(s).
    Please provide more clarity.
    ConiKost 1 Reply Last reply
    • nomko nomko
      ConiKost
      ConiKost
      ConiKost
      @Nomko-Nomden said in Some routes opening slow and some fast:
      Lets take those two routes as example.
      Route1: 272,68km, 5 Via points (including start and end), 91 shaping points.
      -> Loads about 2-3 seconds when opening in app
      Image: clickme
      Route2: 250.57km, 5 Via points (including start and end), 35 shaping points.
      -> Loads about 15 seconds when opening in app
      Image: clickme
      Both routes go into the same direction.
      Surely not, since this happens on WiFi too. And WiFi speedtests are > 600mbps.
      Shiny!
      • ConiKost ConiKost
        Image: clickme
        Image: clickme
        @ConiKost do you have the link to the route of image 2?
        I see POIs displayed, do you by any chance have a massive POI library selected to load / display on the map?
        • Hubert Thoring
          @ConiKost
          What Corjan writes can be found here in the POI settings.
          If too much is selected, everything is always loaded and transferred, limited to 2000 POI ..
          iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
            ConiKost
            ConiKost
            ConiKost
            @Corjan-Meijerink said in Some routes opening slow and some fast:
            See PN.
            I have multiple POIs library uploaded, but only one is active on the route, which opens slow. The active one contains about ~80-120 POIs at max, that shouldn't be the cause?
            Shiny!
            • ConiKost ConiKost
              See PN.
              @ConiKost Sounds like something you can test yourself quite easily! 🙂
              If you turn the POIs off, does it load quickly?
              • ConiKost
                ConiKost
                ConiKost
                @Corjan-Meijerink I did give a try and indeed it's faster. I this correct, that I need always to disable those POIs in web planer, as app does not seem to have an option for this per route? Or am I just blind and don't see it? Because that would be already very helpful, when you want to disable it.
                Regarding the number, I had it wrong in mind. My POI category has ~270 points in it. Still I would not expect that much slow down? I mean, those are not relevant when loading the route initially? Maybe they could be just loaded later in the process?
                Shiny!
                  Thanks for confirming the POI's being a factor.
                  I will investigate this later but definitely not soon.
                  See this manual for showing / hiding certain POI groups for your entire profile / route: https://support.myrouteapp.com/en/support/solutions/articles/12000103938-manual-pois-
                    ConiKost
                    ConiKost
                    ConiKost
                    Thanks! 👍
                    I am confused. This is the procedere, how to do it website aka MRA webplanner, which I also did. I meant the Android/iOS navigation app. Or I am missunderstand here?
                    Shiny!
                    • Hubert Thoring
                      Switching on and off is only possible in the route lab, there is no function in the app
                      In the route lab:
                      • ConiKost
                        ConiKost
                        ConiKost
                        #14
                        Thanks for confirming. That was my question, that I need to use the web planner and cannot use the app for that, to switch it on or off. So an option in app would be very handy 🙂
                        Shiny!
                        • ConiKost ConiKost
                          There is an option in app. Tap Route lab from the mobile app to access the website.
                            ConiKost
                            ConiKost
                            ConiKost
                            @Nick-Carthew said in Some routes opening slow and some fast:
                            Sure, but it's still the website, not a native app function 😉
                            Shiny!
                            ConiKost
                            ConiKost
                              98
                            • Route exporteren uit beta
                              Rob Veerman
                              Rob Veerman
                              70
                            • Startpunt wijzigen
                              BMcG
                              BMcG
                            • V6 - Track Navigation
                              Thomas Schäfer
                              Thomas Schäfer
                              1.7k
                            • Info on MyRoute-app's POI
