  4. Some routes opening slow and some fast
16 Posts 6 Posters 2.1k Views 3 Watching
  • ConiKost
    ConiKost
    ConiKost
    I have a couple of routes in MRA. All contains some Via point and more shaping points. Route length about 250-300km. IMHO nothing special.
    My issue is, that I noticed in MRA on smartphone (tried my DMD T665 and iPhone 17 Pro Max, so not hardware related), when opening a route from my account, some just load in a few seconds while others can load 15-20 seconds on every opening.
    Why is that?
    Shiny!
    • Marinus van Deudekom
      You state different routes, do they all start from the same point. That could a diference
      • ConiKost
        ConiKost
        ConiKost
        Yes, the start all from the same point basically, but differ a little bit. Still, I don't see any common between them.
        Shiny!
        nomko 1 Reply Last reply
        • ConiKost ConiKost
          Banned
          @ConiKost said in Some routes opening slow and some fast:
          Diifers as in..... longer route? More waypoints/viapoints/shaping points? More POI's? Different map to be loaded?
          It could also be a bad recipient between your phone and the nearest transmission tower(s).
          Please provide more clarity.
          ConiKost 1 Reply Last reply
          • nomko nomko
            ConiKost
            ConiKost
            ConiKost
            @Nomko-Nomden said in Some routes opening slow and some fast:
            Lets take those two routes as example.
            Route1: 272,68km, 5 Via points (including start and end), 91 shaping points.
            -> Loads about 2-3 seconds when opening in app
            Image: clickme
            Route2: 250.57km, 5 Via points (including start and end), 35 shaping points.
            -> Loads about 15 seconds when opening in app
            Image: clickme
            Both routes go into the same direction.
            Surely not, since this happens on WiFi too. And WiFi speedtests are > 600mbps.
            Shiny!
            • ConiKost ConiKost
              Image: clickme
              Image: clickme
              @ConiKost do you have the link to the route of image 2?
              I see POIs displayed, do you by any chance have a massive POI library selected to load / display on the map?
              • Hubert Thoring
                @ConiKost
                What Corjan writes can be found here in the POI settings.
                If too much is selected, everything is always loaded and transferred, limited to 2000 POI ..
                iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
                  ConiKost
                  ConiKost
                  ConiKost
                  @Corjan-Meijerink said in Some routes opening slow and some fast:
                  See PN.
                  I have multiple POIs library uploaded, but only one is active on the route, which opens slow. The active one contains about ~80-120 POIs at max, that shouldn't be the cause?
                  Shiny!
                  • ConiKost ConiKost
                    See PN.
                    @ConiKost Sounds like something you can test yourself quite easily! 🙂
                    If you turn the POIs off, does it load quickly?
                    • ConiKost
                      ConiKost
                      ConiKost
                      @Corjan-Meijerink I did give a try and indeed it's faster. I this correct, that I need always to disable those POIs in web planer, as app does not seem to have an option for this per route? Or am I just blind and don't see it? Because that would be already very helpful, when you want to disable it.
                      Regarding the number, I had it wrong in mind. My POI category has ~270 points in it. Still I would not expect that much slow down? I mean, those are not relevant when loading the route initially? Maybe they could be just loaded later in the process?
                      Shiny!
                        Thanks for confirming the POI's being a factor.
                        I will investigate this later but definitely not soon.
                        See this manual for showing / hiding certain POI groups for your entire profile / route: https://support.myrouteapp.com/en/support/solutions/articles/12000103938-manual-pois-
                          ConiKost
                          ConiKost
                          ConiKost
                          Thanks! 👍
                          I am confused. This is the procedere, how to do it website aka MRA webplanner, which I also did. I meant the Android/iOS navigation app. Or I am missunderstand here?
                          Shiny!
                          • Hubert Thoring
                            Switching on and off is only possible in the route lab, there is no function in the app
                            In the route lab:
                            • ConiKost
                              ConiKost
                              ConiKost
                              #14
                              Thanks for confirming. That was my question, that I need to use the web planner and cannot use the app for that, to switch it on or off. So an option in app would be very handy 🙂
                              Shiny!
                              • ConiKost ConiKost
                                There is an option in app. Tap Route lab from the mobile app to access the website.
                                  ConiKost
                                  ConiKost
                                  ConiKost
                                  @Nick-Carthew said in Some routes opening slow and some fast:
                                  Sure, but it's still the website, not a native app function 😉
                                  Shiny!
                                  ConiKost
                                  ConiKost
                                    98
                                  • Route exporteren uit beta
                                    Rob Veerman
                                    Rob Veerman
                                    74
                                  • Startpunt wijzigen
                                    BMcG
                                    BMcG
                                  • V6 - Track Navigation
                                  • Add the last visited folder to "Routes and Tracklogs"
                                    Thomas Schäfer
                                    Thomas Schäfer
                                    1.7k
