Can't change language settings
Just like Nick showed above.
From the app itself to My account > Manage account.
As you can see I had set it to Dutch already, but the language of the app doesn't switch to Dutch.
@Floris-J you did everything ok.
Maybe shut down the app and clear the cache -
Maybe shut down the app and clear the cache@Marinus-van-Deudekom Tried that and also an uninstall / install, but it stays English.
@Floris-J witch phone do you use
@Marinus-van-Deudekom Samsung Galaxy S23.
When I set my phone in Android settings to Dutch, the app is also in Dutch.
Back to English it's in English again. -
Back to English it's in English again.@Floris-J beats me Floris.maybe contact @Corjan-Meijerink for help. Ik weet het echt niet meer
@Nick-Carthew @Marinus-van-Deudekom No that's not what I meant for sure!
This is what I meant: https://support.google.com/android/answer/12395118?hl=en
@Corjan-Meijerink thnkx for that cristal clear answer
Good morning in the morning
here the same Problem, some settings (language, units of measurement, travel mode) are not taken into account in the app.
Not important for me as I only tested it.On Web Ok
In App not Ok
In App not Ok
@Dirk-Kevin-K initially when logging in, the settings are synced. TravelMode / distance notation can be altered in the app regardless of the website.
Language of the app can be changed on the OS itself
@Corjan-Meijerink said in Can't change language settings:
Language indeed not - that is determined by the OS.
I'll see if I can add a settings for that. -
@Corjan-Meijerink Daar had ik ook al gekeken, maar de MyRouteApp ondersteunt dit niet want hij staat niet in het lijstje.
@Floris-J
If you haven't found the voice prompt setting yet.
@Floris-J
@Dirk-Kevin-K thanks. Had ik al wel gevonden, maar die passen zich ook automatisch aan naar de taal van Android.
@Floris-J
You can change this manually, red circle, after that i can hardly understand anything.
@Floris-J
@Dirk-Kevin-K Hahaha, ja dat klopt, maar dan gaan ze dus bijvoorbeeld Engels praten met een Nederlandse stem of Duits praten met een Engelse stem enzo
Ik wil gewoon m'n telefoon op Engels laten staan en alles in de app op Nederlands in kunnen stellen, maar dat kan dus blijkbaar momenteel niet.
Klusje voor de ontwikkelaars
I'll see if I can add a settings for that.@Corjan-Meijerink Adding a language setting in the app would be great, thanks
@Floris-J done
4.3.1 will have it. Supported from Android 13 and higher. -
@Floris-J done
4.3.1 will have it. Supported from Android 13 and higher.@Corjan-Meijerink Wow, dat is snel. Kan ik mss alvast helpen met testen?
@Floris-J zal eind deze week gereleased worden.
Begin vd week beta
