  4. Can't change language settings
38 Posts 6 Posters 17.4k Views 3 Watching
  • Dirk Kevin K. Dirk Kevin K.
    Good morning in the morning 😊
    here the same Problem, some settings (language, units of measurement, travel mode) are not taken into account in the app.
    Not important for me as I only tested it.
    On Web Ok
    In App not Ok
    @Dirk-Kevin-K initially when logging in, the settings are synced. TravelMode / distance notation can be altered in the app regardless of the website.
    Language of the app can be changed on the OS itself
    Dirk Kevin K. Corjan Meijerink 2 Replies Last reply
      Dirk Kevin K.
      Dirk Kevin K.
      Dirk Kevin K.
      @Corjan-Meijerink Sure?
      Measurement Yes
      Language No 😧
      Logout / Reboot / App Start / LogIn . . .
      iPhone 15 Pro (iOS 18.4.1)
      iPad Pro (iPadOS 18.4.1)
      MyRoute-APP (5.1.0 - 462), All-Lifetime)
      Honda NC750S DCT / Carpuride W502 / Garmin XT
      BMW F800R / Carpuride W702B / Navigator VI
      SENA 50S / Cardo Packtalk Edge
        @Corjan-Meijerink said in Can't change language settings:
        Language indeed not - that is determined by the OS.
        I'll see if I can add a settings for that.
        Floris J 1 Reply Last reply
          @Nick-Carthew @Marinus-van-Deudekom No that's not what I meant for sure!
          This is what I meant: https://support.google.com/android/answer/12395118?hl=en
          Floris J
          Floris J
          Floris J
          @Corjan-Meijerink Daar had ik ook al gekeken, maar de MyRouteApp ondersteunt dit niet want hij staat niet in het lijstje.
          Dirk Kevin K. 1 Reply Last reply
          • Floris J Floris J
            Dirk Kevin K.
            Dirk Kevin K.
            Dirk Kevin K.
            @Floris-J
            If you haven't found the voice prompt setting yet. 😌
              @Floris-J
              Floris J
              Floris J
              Floris J
              @Dirk-Kevin-K thanks. Had ik al wel gevonden, maar die passen zich ook automatisch aan naar de taal van Android.
              • Floris J Floris J
                Dirk Kevin K.
                Dirk Kevin K.
                Dirk Kevin K.
                wrote on last edited by Dirk Kevin K.
                #23
                @Floris-J
                You can change this manually, red circle, after that i can hardly understand anything. 😂
                  @Floris-J
                  Floris J
                  Floris J
                  Floris J
                  @Dirk-Kevin-K Hahaha, ja dat klopt, maar dan gaan ze dus bijvoorbeeld Engels praten met een Nederlandse stem of Duits praten met een Engelse stem enzo 😄
                  Ik wil gewoon m'n telefoon op Engels laten staan en alles in de app op Nederlands in kunnen stellen, maar dat kan dus blijkbaar momenteel niet.
                  Klusje voor de ontwikkelaars 😉
                    Floris J
                    Floris J
                    Floris J
                    wrote on last edited by Floris J
                    #25
                    @Corjan-Meijerink Adding a language setting in the app would be great, thanks 🙂
                    • Floris J Floris J
                      @Floris-J done 🙂
                      4.3.1 will have it. Supported from Android 13 and higher.
                        @Floris-J done 🙂
                        Floris J
                        Floris J
                        Floris J
                        @Corjan-Meijerink Wow, dat is snel. Kan ik mss alvast helpen met testen?
                        • Floris J Floris J
                          @Floris-J zal eind deze week gereleased worden.
                          Begin vd week beta 🙂
                            Floris J
                            Floris J
                            Floris J
                            @Corjan-Meijerink ik wacht in spanning af 😉
                            • Floris J Floris J
                              @Floris-J iOS heeft de instelling wel gekregen - Android helaas nog niet 😞
                              Dirk Kevin K. Floris J 3 Replies Last reply
                                Dirk Kevin K.
                                Dirk Kevin K.
                                Dirk Kevin K.
                                Thanks and checked 🤡
                                  Floris J
                                  Floris J
                                  Floris J
                                  @Corjan-Meijerink 4.3.1 voor Android is volgens mij ook nog niet gereleased.
                                    Floris J
                                    Floris J
                                    Floris J
                                    @Corjan-Meijerink net 4.3.1 geïnstalleerd maar het zit er indd nog niet in.
                                    • Floris J Floris J
                                      @Floris-J Android heeft de instelling ook nog niet omdat daar wat beperkingen waren 😞
                                        Floris J
                                        Floris J
                                        Floris J
                                        @Corjan-Meijerink Maar het gaat nog wel spoedig komen? 😊
                                        Floris J 2 Replies Last reply
                                        • Floris J Floris J
                                          Floris J
                                          Floris J
                                          Floris J
                                          @Corjan-Meijerink komt de taal optie in de release van 17 oktober op Android?
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Floris J
                                          Floris J
                                            98
                                          • Route exporteren uit beta
                                            Rob Veerman
                                            Rob Veerman
                                            74
                                          • Startpunt wijzigen
                                            BMcG
                                            BMcG
                                          • V6 - Track Navigation
                                            Thomas Schäfer
                                            Thomas Schäfer
                                            1.7k
                                          • Info on MyRoute-app's POI
