  3. Time Zones
Time Zones
11 Posts 8 Posters 2.7k Views 1 Watching
  • glherongmail.com
    glherongmail.com
    glherongmail.com
    Is there a way to capture the time zone changes while making a map? When I'm traveling in the direction where I gain an hour due to time zone change it's easy to just add a hour with insert pause but going in the other direction it will not accept a negative number.
    HABVEN aka MrMRA Nick Carthew 2 Replies Last reply
    • glherongmail.com glherongmail.com
      @glen-heron
      Go to your account, right upper corner, there you can set your timezone
      glherongmail.com 1 Reply Last reply
        @glen-heron
        glherongmail.com
        glherongmail.com
        glherongmail.com
        @hans-van-de-ven-mra-master Thanks I have that, what I'm talking about is when you are planning a trip going through several different time zones. I was wanting to account for gaining or loosing hours on those days where the time change occurs.
        • Herko ter Horst
          Herko ter Horst
          Herko ter Horst
          I'm not sure it makes sense to put this into your route. Durations do not have timezones. What MRA shows is how long the trip is expected to take, this does not change due to time zone differences, it will still take x hours to get from A to B, wether you cross 0, 1 or 10 time zone boundaries. The fact that your watch should be adjusted when crossing into a different time zone, doesn't influence the duration of the trip.
          sudolea 1 Reply Last reply
            sudolea
            sudolea
            sudolea
            wrote on last edited by sudolea
            @herko-ter-horst said in Time Zones:
            Don't you think the poster has his reason to ask this ? I think he is better placed to judge how much sense this makes according to his way of working (he wouldn't have asked his question otherwise, would he). On the other hand, just saying : if you take the ferry from the continent to the UK, the duration stays the same too, regardless of the timezone you cross. Yet, the ferry operator times are mentioned in local times. If it's not possible in MRA, it's not possible, so be it. But then again, I wouldn't make too much assumptions in his place...
              @glen-heron The short answer to your question is no, there isn’t an option for time zones. I agree with @Herko-ter-Horst adding an hour in a pause break will just adjust the calculated journey time.
              Drabslab 1 Reply Last reply
                Drabslab
                Drabslab
                Drabslab
                @nick-carthew said in Time Zones:
                Only in one direction.
                And this is only a hack, not a solution.
                I find it a good question, don't understand why it received negatively
                TorqueRider Nick Carthew 2 Replies Last reply
                • Drabslab Drabslab
                  This post is deleted!
                  • Drabslab Drabslab
                    @drabslab said in Time Zones:
                    Who is being negative?
                    • Paul Johnson 5
                      Paul Johnson 5
                      Paul Johnson 5
                      Hi.
                      I was wondering the very same thing -did you ever find a fix?
                      • Paul Johnson 5 Paul Johnson 5
                        Hi.
                        @Paul-Johnson-5 There is no fix required for the reason @Herko-ter-Horst mentioned some time ago in this thread. See above
                        Drabslab
                        Drabslab
                        Herko ter Horst
                        Herko ter Horst
                        Paul Johnson 5
                        Paul Johnson 5
                        sudolea
                        sudolea
                        glherongmail.com
                        glherongmail.com
                          Bouke Ent
                          Bouke Ent
                        • test Myroute APP
                          1.9k
                          Jörg Neudert
                          Jörg Neudert
                          690
                          8.1k
                        • F001 POIs Adding from selection is not possible
                          Hubert Thori
                          Hubert Thori
