  3. [App] Announcements
  4. Update 5.0.3 - Device management
55 Posts 25 Posters 15.8k Views 8 Watching
    Hi everyone! 👋
    It is time for a new update!
    Device management
    This is the core aspect of this update.
    Unfortunately we are seeing a massive amount of account sharing going on.
    At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.
    As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can deregister another device. After doing so, you can use your current phone again 😃
    Some important notes:
    • Excessively switching between multiple phones will lead to an automatic warning
    • Attempts to use way too many devices (4) at once will lead to an automatic block
    Our terms & conditions will be updated appropriately.
    Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.
    A full announcement can be read here: https://info.myrouteapp.com/limit-of-2-devices/
    SSO fixed
    Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed! 🎉
    Link and file opening
    Opening links and files with the app has always been possible.
    In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).
    Audio stability Android
    In some rare cases a clean install of the app would not output any audio while navigating - this now seems fixed.
    Minor fixes and stability improvements
    Many small issues that are not relevant to mention here have been fixed.
    Also we fixed a few errors that would result in route calculations failing.
    Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.
    What's next
    Slowly but surely we are transitioning to a more focused dedication on the website.
    In the next update 5.1 we will:
    • Aim for solving all stability issues CarPlay and Android Auto
    • Add highly requested features to CarPlay and Android Auto
    • Major technical internal updates
    Cheers,
    Corjan
    Peter Zehentreiter peha 2 Replies Last reply
      Hi everyone! 👋
      Device management
      SSO fixed
      What's next
      Cheers,
      Corjan
      wrote on last edited by Peter Zehentreiter
      @Corjan-Meijerink said in Update 5.0.3 - Device management:
      I have a question about that!
      I have the app running on four devices.
      1 Pixel 9 online (used for navigation)
      1 Motorola Edge 40 offline (used in parallel with navigation
      Then I have another Pixel 9 that I use as my everyday device and use in case of changes during the tour (so I can leave the other device in the navigation holder) and make changes via synchronization!
      Last but not least, I also have the app installed on an iPad....
      These 4 devices are used exclusively by ME ONLY.
      What do I need to do to continue using these 4 devices?
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • AWDC LAO
        AWDC LAO
        AWDC LAO
        wrote on last edited by AWDC LAO
        Ik heb ook MRA en NN op verschillende toestellen staan, MacBook Pro, een MacBook Air, 3 iPhones, en één Carpe Iter 4, gelukkig heb ik nu 2 full abonnementen,* maar dan moet ik vriend van mezelf zijn in beide <> richtingen.
        Tijdens de reizen zelf, kan ik op de goedkopere MacBook de routes nog bijsturen. Zelf rij ik altijd met 2 NN actief omdat er toch verschillen zijn en ik een detailkaart op het ene toestel en een grotere kaart op het andere kan gadeslaan zonder mijn handen van het stuur te halen .
        Soms bij offroad of tracks komt er nog de XT2 bij !
        Ik begrijp het gebruik op maximaal 2 toestellen gelijktijdig, maar hebt het wat moeilijk met de beperking van het installeren op maximaal 2 toestellen.
        Lluis Arasanz Rob Veerman 2 Replies Last reply
        • Lechfelder
          Lechfelder
          Lechfelder
          Betrifft die Limitierung auf 2 Geräte nur die Funktion "Navigation Next"?
          Habe diese zwar, benötige die App nur zur Routenübertragung auf ein anderes System, allerdings auf mehreren Geräten. Würde, sofern dies zutrifft, dann Navigation Next deaktivieren bzw. löschen lassen.
          • AWDC LAO AWDC LAO
            @AWDC-LAO
            HI,
            Can you use the same language that thread creator of this post used?
            Switching languange on web with online translator is no efective.
            Thank's.
            • BMW F750GS
            • AWDC LAO AWDC LAO
              @AWDC-LAO Quote: "As of this update we allow a maximum of 2 devices to be used at the same time." Unquote
              You can still have it installed at al your devices, only the simultaneous use is limited (which I find understandable).
                When significantly exceeding the limit it's best to contact our support department.
                We simply cannot support unlimited devices per account anymore. A custom solution will be found per account.
                We do not block the installations but monitor usage of your subscription and limit that.
                Example of a recent support ticket:
                • One account with 4 devices
                • 2 for husband, 2 for wife
                • Offered to upgrade account to 4 devices for another purchase
                • Means they can continue to share the account
                • Customer happy and we've covered the costs of all their devices so our prices can remain low
                Note: the device limit only concerns the app for Navigation Next users. Not the website or other users using the app.
                  @Corjan-Meijerink The following scenario...
                  The iPad is at home, ‘switched off’.
                  I am riding my motorbike and have the Pixel 9 online navigation mobile phone and MRA active, and my everyday Pixel 9 mobile phone is also online, but the MRA app is NOT active. The Motorola Edge 40 is also being used in parallel with the navigation system and is ‘completely OFFLINE’. MRA is also active.
                  What happens if I start the MRA app on my everyday mobile phone and want to make a correction to the route?
                  From this point on, three devices would be active with MRA (BUT ONLY TWO DEVICES ARE ONLINE).
                  Please reply.
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                  • Hagedorn Hans-Jürgen
                    Hello,
                    I don't think this rule is right because I use one phone for motorcycle navigation, another for CarPlay, and an iPad for route planning on the go. Why can't it be like Spotify, where only one device can be logged in at a time? It's a shame; this makes the app unusable for many of my acquaintances, and I certainly can't recommend it anymore.
                    Peter Zehentreiter Corjan Meijerink 2 Replies Last reply
                    • Hagedorn Hans-Jürgen Hagedorn Hans-Jürgen
                      Hello,
                      @Hagedorn-Hans-Jürgen As far as I understand...you can have 2 devices parallel online, as soon as you start a 3rd device online, you have to close one Application of one of the running devices.
                      So planning on the go should work as long as only two devices are online.
                      Please enlighten me if this is not correct
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      • Lluis Arasanz
                        Hi all,
                        I found that device limit is something good to left no one abuse this application.
                        I know also that more and more people installs in 2 phones (primary and backup) and uses a bigger screen, like a tablet, to route edit.
                        Perhaps, the device limit can be "launch" when user tries to "Navigate" a route? This allow use more devices for planning scenarios with no limits , but only a max of 2 to navigate.
                        Regards
                        • BMW F750GS
                          Hello,
                          @Hagedorn-Hans-Jürgen You won't even have an issue 🙂
                          You are using 2 devices as intended and sometimes a third.
                          When using the third you will be asked to unlist one of the other active devices which is a very smooth action with no impact at all.
                            Please reply.
                            @Peter-Zehentreiter You would indeed be using too many devices.
                            Contacting customer support is the way.
                              Also when one of these 3 devices is completely offline?
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Sena SLR 3
                              Sena 50 R
                                @Peter-Zehentreiter At one point you will be online and that's the point where we know what devices you used. In theory if you would never use internet we indeed cannot track the device 😉
                                • BMcG
                                  BMcG
                                  BMcG
                                  is there a way to access the page that shows which devices I have registered or do I need to exceed the limit before this information is available?
                                  BlackView BV7100, Android 12
                                  • BMcG BMcG
                                    @Brian-McG from the account page in the app. There is a button to view your devices (near the bottom)
                                      Hi everyone! 👋
                                      Device management
                                      SSO fixed
                                      What's next
                                      Cheers,
                                      Corjan
                                      peha
                                      peha
                                      peha
                                      Is the "map spinning when stopped" issue also adressed (maybe even fixed) here?
                                      BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
                                      VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
                                      Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
                                      • peha peha
                                        @peha haven’t worked on this explicitly
                                        5.1 is fully dedicated to AA / CP
                                        peha 1 Reply Last reply
                                          peha
                                          peha
                                          peha
                                          @Corjan-Meijerink Thanks for your reply. I will contact support via e-mail rather than discuss this further here, then, regarding this.
                                          BMcG
                                          BMcG
                                          Adrian Avram
                                          Adrian Avram
                                          AWDC LAO
                                          AWDC LAO
                                          RainerT
                                          RainerT
                                          Lechfelder
                                          Lechfelder
                                          peha
                                          peha
                                          silberfuchs67
                                          silberfuchs67
                                          ginogino
                                          ginogino
                                          richard 3v
                                          richard 3v
                                          Charles Rijken 0
                                          Charles Rijken 0
                                          dungbeetle
                                          dungbeetle
                                          Steve 2t
                                          Steve 2t
                                          • Newsletter optimisation
                                            Kudee
                                            Kudee
                                          • Walking route options
