  2. Announcements
  3. LAUNCH: upgrade waypoint menu
46 Posts 15 Posters 31.5k Views 5 Watching
  • HABVEN aka MrMRA
    Working fine here, with old routes`and new routes
      Hello everyone,
      We're trying to replicate the issue but are unable to do so. Could you try to share some links to those routes so that I can try to open it on my end, see if there's something going wrong there? Because as far as we can see everything is working as intended. Which means something somewhere went wrong.
      kind regards,
      Timo
      Pierre c
      Pierre c
      Pierre c
      @Timo-Martosatiman-MRA In fact, it all starts with an interruption in the line between two points. The route was missing but the waypoints were not. When I close and restart the route, it remains on standby and no longer opens.
        Hello everyone,
        kind regards,
        Timo
        https://www.myrouteapp.com/nl/social/route/5327654?mode=share
        MyRoute-app community 1 Reply Last reply
        • Reinhard-32
          The same problem here. When I use the Openstreet map, then it works. I think the problem is related to the map which is used for calculation. And / or to the account.
          Kindly regards
          Reinhard
          Montana 700i and Mac
          • TorqueRider TorqueRider
            Administrator
            @Jack-van-Tilburg
            Tested your route both on MS Edge and Google Chrome, both load the routeplanner correctly and show the route. On chrome the loading took a little longer (a little strange, but nothing otherworldly) but the route loaded. How long have you waited? Do you see the blue web-loading bar on the top of your browser move at all?
            @Reinhard-32 thank you very much for this info. While I can't reproduce this myself this will help our developers in the search for a solution.
            Kind regards,
            Timo
            TorqueRider Pierre c Steve Lynch 5 Replies Last reply
              @Jack-van-Tilburg
              Kind regards,
              Timo
              @Timo-Martosatiman-MRA said in LAUNCH: upgrade waypoint menu:
              Yep I see the blue web-loading bar on the top and it goes smoothly all the way to the right. But after that nothing happens.
              So that's also the answer to your question how long do I wait.
              So it doesn't matter, nothing happens.
                @Jack-van-Tilburg
                Kind regards,
                Timo
                Also tested on my iPhone, with only 4G.
                The routes don't load there either.
                  @Jack-van-Tilburg
                  Kind regards,
                  Timo
                  Are you testing on a "stand-alone" computer?
                  Or is that computer connected in any way to a "MyRoute" (management) network?
                    @Jack-van-Tilburg
                    Kind regards,
                    Timo
                    Pierre c
                    Pierre c
                    Pierre c
                    @Timo-Martosatiman-MRA For my part, the problem arose during the calculation at waypoint n ° 8. The road between points 4 and 5 has disappeared and nothing more happens. If I reload the page, no route appears anymore but the points are displayed ... If I open another normally calculated route, the route also does not appear as if the previous failure blocked any loading
                    • David Bonner
                      David Bonner
                      David Bonner
                      Neither Routes or Tracks load.... I have tried on computer (iMac) and phone (iPhone7), neither work.
                      • TorqueRider
                        I have now installed Google Chrome on my MacBook. With that browser I can open existing routes. But that is very slow.
                        • Reinhard-32
                          At my I-Mac with Big sur and the safari browser I can't load routes. With the crome browser I can plan a route at the here map but the response is very slow. I think there is a big bug in the MRA System.
                          Kindly regards
                          Reinhard
                          • Reinhard-32 Reinhard-32
                            @Reinhard-32
                            I wonder if there is a connection between the malfunction and the upgrade of the waypoint menu. 😞
                            Reinhard-32 Steve 25 2 Replies Last reply
                              @Reinhard-32
                              @Jack-van-Tilburg MRA has added the new waypoints and I guess some other updates either.
                              Kindly regards
                              Reinhard
                              • Tony 13
                                Tony 13
                                Tony 13
                                Hi
                                I am getting the same problem on Firefox, but on Android is OK. any old route more than two waypoints long is not loading or failing.
                                Tony
                                • Reinhard-32
                                  I have tested MRA in at a Windows 10 computer with the chrome browser. I works but not smooth.
                                  Kindly regards
                                  Reinhard
                                    @Jack-van-Tilburg
                                    Kind regards,
                                    Timo
                                    Steve Lynch
                                    Steve Lynch
                                    Steve Lynch
                                    Tested on iOS iPAD Pro using Chrome and Safari.
                                    Existing Routes are not loading for Here Map.
                                    “RS6 Rykas Loop” is a Public Route
                                    https://www.myrouteapp.com/en/social/route/3937795?mode=share
                                    “RS6 Waterfall Walk Safe Route” is a Public Route.
                                    This is set to OpenStreetMap uses the Offroad mode
                                    Transport Mode is “by foot”
                                    This route does open immediately.
                                    https://www.myrouteapp.com/en/social/route/5224950?mode=share
                                    Same as above using the iOS MyRoute Application
                                    Samsung S10 5G using the App
                                    “RS6 Rykas Loop” opens in about 7 Seconds
                                    “RS6 Waterfall Walk Safe Route” opens instantly.
                                    MS Surface Pro 4
                                    “RS6 Rykas Loop” opens in about 7 Seconds.
                                    • MotorradTeam Mannheim
                                      I have tested MRA with WIN 10 and edge browser (version 94.0.992.38 (official build) (64-bit)). it works. Even the favorites are there.
                                      Tested with an "old" route with 143 waypoints over 3120km.
                                      (https://www.myrouteapp.com/de/social/route/4825168?mode=share)
                                      it works smooth
                                      It doesn't work with Firefox 92.01
                                      Markus
                                        @Reinhard-32
                                        Steve 25
                                        Steve 25
                                        Steve 25
                                        @Jack-van-Tilburg said in LAUNCH: upgrade waypoint menu:
                                        @Reinhard-32
                                        I'm also unable to load any existing routes since this upgrade. I run MacBook Pro and Safari.
                                        • Steve Lynch
                                          Steve Lynch
                                          Steve Lynch
                                          #26
                                          Maybe this is Mac/iOS specific?
                                          That’s what my tests indicate?
                                          Update:
                                          Doesn’t affect MRA Navigation on iOS or Android for me.
                                          Steve 25 Reinhard-32 2 Replies Last reply
                                          Pierre c
                                          Pierre c
                                          Tony 13
                                          Tony 13
                                          Martin White
                                          Martin White
                                          Steve 25
                                          Steve 25
                                          Steve Lynch
                                          Steve Lynch
                                          David Bonner
                                          David Bonner
                                          Richard Ward
                                          Richard Ward
                                          Jd Price
                                          Jd Price
                                          Emily 3
                                          Emily 3
                                          Lemons
                                          Lemons
                                          • Elektrisch rijden
                                            John mq
                                            John mq
                                          • Reizen delen met NIET MRA gebruikers
                                            Albert van den Elsen
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.4k
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
                                          • MRA V6.0.0 (531) Download offline maps ?
                                          • Statement on Commercial Clubs
