  4. Joining a planned route from a differant position.
38 Posts 10 Posters 6.2k Views 7 Watching
  • coupe_vs
    coupe_vs
    coupe_vs
    Here are photos from today showing that I've passed point 5 and am heading for point 6, but it sends me back to point 5 instead of the next point 6... Next navigation on iOS 2.6. I've tried both online and offline with downloaded maps and the same error occurs.
    • Herman Veldhuizen
      i see the same as @Jose-antonio-marin-segura . The app sends me back. I suspect that the app skips a point when you are very close to it and that this is why it works in @Nick-Carthew case (point 3 very close)
      • Makro Makro
        @Nick-Carthew said in Joining a planned route from a differant position.:
        If you open a route the app will guide you to the start from your location. If you do not want to join at the start, long press any waypoint to skip all previous waypoints and you’ll be directed from your location to your chosen waypoint.
        Yes absolutely.
        What annoys me: If I start riding a route, passing the start waypoint before the navigation starts, the app keeps directing me back to the starting point. This happens even if I pass the second, third, fourth shaping points etc, at which point it would be nice if the app would starts realizing, that this guy is actually following the route, so no need to go back and start over.
        coupe_vs
        coupe_vs
        coupe_vs
        @Makro
        That's right, exactly what you're describing is happening to me, and I've been asking about it these past few days... obviously, the solution other users have suggested is manually re-entering points already passed (we all know that). The idea is to suggest in the forum that it be implemented automatically so the navigator knows you're following the route correctly and automatically guides you to the next point (without having to manually re-enter previous points).
        • Herman Veldhuizen
          the other thing I noticed is that the app never sends you to the last point, which I find confusing. In @Nick-Carthew case : if point 4 was the last point the app would send you to 3.
            @Herman-Veldhuizen said in Joining a planned route from a differant position.:
            Waypoint 4 is not the last waypoint and even if it was the app would not send me to waypoint 3. My example shows that I have decided to start this route from somewhere that is not the start point. I have selected Start from nearest waypoint in Routing settings. Waypoint 3 is behind my location, this can be seen by the white line, if the app sent me to waypoint 3 I would have to travel back on the same road to reach the next waypoint number 4.
            • coupe_vs
              coupe_vs
              coupe_vs
              Nick Carthew, that's right, I totally agree with what you've described as help, but it simply doesn't work for me and several others like it does for you. It sends me back to the previous point (which we've already passed), and we don't know why. That's why we're asking here, since it should work for us like it does for you, Nick, but it doesn't! Is it something in our configuration? Or is it a bug in the app? That's the question...
              Nick Carthew Marinus van Deudekom 2 Replies Last reply
              • coupe_vs coupe_vs
                #20
                @Jose-antonio-marin-segura It may be because I am using the new 5.1.0 updated version from BETA testing. I will ask and come back to this topic with the answer.
                  That is exactly the case 🙂
                  It works because when you are very close to the nearest waypoint, it will go to the next nearest.
                  When the real nearest waypoint is slightly further, it will just use that one. If it it might be slightly behind you.
                    @Corjan-Meijerink Thanks for the confirmation of how the algorithm works 👍
                    • coupe_vs coupe_vs
                      @Jose-antonio-marin-segura Now that Corjan has explained how the algorithm works, in the situation that you described, long press on waypoint 6 is the best option for you.
                      • Herman Veldhuizen
                        #24
                        This is my example. Straight line distance is smallest to point 4 but it would send me back when entering the route. Point 5 should be the nearest point. This is with the latest version 5.0.4 on Android.
                        • coupe_vs coupe_vs
                          @Jose-antonio-marin-segura of you keep following the route the shaping points that you've already passed will be skipped, just keep following the route. The system must try to get you back 3 times and then will finally give in
                          • coupe_vs
                            coupe_vs
                            coupe_vs
                            Ah, okay, that's possible. We'll wait here with your answer... Greetings and thanks.
                              @Jose-antonio-marin-segura You’re not correct with your scenario. If you start a route and you are not at the beginning, the app knows your location and will therefore start from the nearest location that is in front of you not behind you. My two screenshots demonstrate this. The first screenshot is an overview of the whole route. The second screenshot shows my location, the white line and waypoints 4 and 5 are behind me, the app will start navigation from waypoint 6.
                              @Nick-Carthew so now we know where your house lives 🤣
                              MRA Lifetime Gold
                              • Travellexxie Travellexxie
                                @Lex.Kloet.RX It has never been a secret, ask any policeman 😁
                                  @Marinus-van-Deudekom said in Joining a planned route from a differant position.:
                                  Only if you have selected Automatically skip waypoints
                                  coupe_vs Marinus van Deudekom 2 Replies Last reply
                                    coupe_vs
                                    coupe_vs
                                    coupe_vs
                                    @Nick-Carthew
                                    No, I have "skip automatic points" ON and pressing it three times or even more keeps sending me back to the previous point (which I've already passed)... I'm using iOS 26, the latest version, and also the latest version of the official app (NOT BETA
                                    • coupe_vs
                                      coupe_vs
                                      coupe_vs
                                      • Simon James Hancock
                                        Simon James Hancock
                                        Simon James Hancock
                                        Ok I think I have grasped the gist of it.
                                        I can do a long press of my arrival waypoint and it will resume the correct direction.
                                        Some of my routes do not have intermediate waypoints.
                                        On the practical side of it, It is not easy to zoom out of the map view of the route and scroll to another waypoint to select it whilst riding.
                                        It could be me being too lazy to stop and re configure.
                                        Thanks for the help.
                                          @Nick-Carthew of course Nick but would one complain that MRA is not skipping waypoints automaticly if you’ve Turner that of. Beats me
                                          Simon James Hancock
                                          Simon James Hancock
                                          Makro
                                          Makro
                                          coupe_vs
                                          coupe_vs
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
