  4. Joining a planned route from a differant position.
38 Posts 10 Posters 6.2k Views 7 Watching
    @Simon-James-Hancock said in Joining a planned route from a differant position.:
    Is it possible to join a planned route from a position that is not on the route?
    Thanks.
    If you open a route the app will guide you to the start from your location. If you do not want to join at the start, long press any waypoint to skip all previous waypoints and you’ll be directed from your location to your chosen waypoint.
    So in short, the answer is yes.
    Makro
    Makro
    Makro
    @Nick-Carthew said in Joining a planned route from a differant position.:
    Yes absolutely.
    What annoys me: If I start riding a route, passing the start waypoint before the navigation starts, the app keeps directing me back to the starting point. This happens even if I pass the second, third, fourth shaping points etc, at which point it would be nice if the app would starts realizing, that this guy is actually following the route, so no need to go back and start over.
    Best regards, Makro
    Nick Carthew coupe_vs 2 Replies Last reply
    • Makro Makro
      Yes absolutely.
      @Makro The first waypoint is always a via point, hand shape. Via points are never automatically skipped. To avoid what you described, always position the first waypoint 100+ metres from the actual start point. The app will always guide you to the start point.
      Guzzist 1 Reply Last reply
        @Nick-Carthew that's not the point Nick. Just if we do like you suggested - if there is a need of restart the navigation for a route - MyRoute-App doesn't realise we are just on the route and there is no need to start with route point 1 again.
        • Guzzist Guzzist
          @Guzzist Neither the original poster or Marko mentioned restarting the route, so I’m not sure why you say that but even if you do need to restart the route a long press on any waypoint will still work or if you have Start from nearest waypoint selected.
          • coupe_vs
            coupe_vs
            coupe_vs
            Thank you for your response. In your case, it's because your location (halfway) is very close to waypoint number 6. If your location (red dot) is slightly ahead of point 5 and therefore far from point 6, navigation starts from point 5 even though that point is behind you. I've attached my screenshots. I'm talking about Next on iOS 26... In my example screenshots from today, I start the route when I'm already between points 2 and 3 (see screenshots). I select the "Start from current location" option and it recalculates the route to go to point 2 (which I've already passed). I'm between points 2 and 3... Then, since I see that's not what I want, I select the "Start from home" option and it sends me to point 1 (as expected). Finally, in screenshot 3, I disable both options ("Start from home" and "Use current location") and once again it sends me to point 1.
            In short, it never sends me to start at point 3, which is what it should do (like what happens to you in your post above).
            • Simon James Hancock
              Simon James Hancock
              Simon James Hancock
              Or Just use more waypoints when planning a route to cater for this type of eventuality.
              If you keep pressing does go through all the waypoints, Or only the nearest one?
              • Simon James Hancock Simon James Hancock
                The amount of waypoints makes no difference to the original scenario, my first answer still stands if there are 15 waypoints or 150 waypoints.
                Not sure that you fully understood my reply. Long press on any Waypoint will skip all previous waypoints and then navigation starts from the waypoint that you long pressed.
                • coupe_vs coupe_vs
                  @Jose-antonio-marin-segura
                  I’m sorry, I’ll say it again, you are incorrect.
                  When you select Start from nearest waypoint, the app will choose the waypoint that is in front of you not behind. I have changed the example route to prove this.
                  Screenshot 1 shows the entire route.
                  Screenshot 2 shows the start point as waypoint 4 which is in front of my current location.
                  See the next waypoint icon top right of the navigation screen. Waypoint 3 is nearest but behind me on the route, waypoint 4 is further away than waypoint 3 but it is in front of my location.
                  • coupe_vs
                    coupe_vs
                    coupe_vs
                    Here are photos from today showing that I've passed point 5 and am heading for point 6, but it sends me back to point 5 instead of the next point 6... Next navigation on iOS 2.6. I've tried both online and offline with downloaded maps and the same error occurs.
                    • Herman Veldhuizen
                      i see the same as @Jose-antonio-marin-segura . The app sends me back. I suspect that the app skips a point when you are very close to it and that this is why it works in @Nick-Carthew case (point 3 very close)
                      • Makro Makro
                        Yes absolutely.
                        coupe_vs
                        coupe_vs
                        coupe_vs
                        @Makro
                        That's right, exactly what you're describing is happening to me, and I've been asking about it these past few days... obviously, the solution other users have suggested is manually re-entering points already passed (we all know that). The idea is to suggest in the forum that it be implemented automatically so the navigator knows you're following the route correctly and automatically guides you to the next point (without having to manually re-enter previous points).
                        • Herman Veldhuizen
                          the other thing I noticed is that the app never sends you to the last point, which I find confusing. In @Nick-Carthew case : if point 4 was the last point the app would send you to 3.
                            @Herman-Veldhuizen said in Joining a planned route from a differant position.:
                            Waypoint 4 is not the last waypoint and even if it was the app would not send me to waypoint 3. My example shows that I have decided to start this route from somewhere that is not the start point. I have selected Start from nearest waypoint in Routing settings. Waypoint 3 is behind my location, this can be seen by the white line, if the app sent me to waypoint 3 I would have to travel back on the same road to reach the next waypoint number 4.
                            • coupe_vs
                              coupe_vs
                              coupe_vs
                              Nick Carthew, that's right, I totally agree with what you've described as help, but it simply doesn't work for me and several others like it does for you. It sends me back to the previous point (which we've already passed), and we don't know why. That's why we're asking here, since it should work for us like it does for you, Nick, but it doesn't! Is it something in our configuration? Or is it a bug in the app? That's the question...
                              Nick Carthew Marinus van Deudekom 2 Replies Last reply
                              • coupe_vs coupe_vs
                                #20
                                @Jose-antonio-marin-segura It may be because I am using the new 5.1.0 updated version from BETA testing. I will ask and come back to this topic with the answer.
                                  That is exactly the case 🙂
                                  It works because when you are very close to the nearest waypoint, it will go to the next nearest.
                                  When the real nearest waypoint is slightly further, it will just use that one. If it it might be slightly behind you.
                                    @Corjan-Meijerink Thanks for the confirmation of how the algorithm works 👍
                                    • coupe_vs coupe_vs
                                      @Jose-antonio-marin-segura Now that Corjan has explained how the algorithm works, in the situation that you described, long press on waypoint 6 is the best option for you.
                                      • Herman Veldhuizen
                                        #24
                                        This is my example. Straight line distance is smallest to point 4 but it would send me back when entering the route. Point 5 should be the nearest point. This is with the latest version 5.0.4 on Android.
                                        • coupe_vs coupe_vs
                                          @Jose-antonio-marin-segura of you keep following the route the shaping points that you've already passed will be skipped, just keep following the route. The system must try to get you back 3 times and then will finally give in
                                          Simon James Hancock
                                          Simon James Hancock
                                          Makro
                                          Makro
                                          coupe_vs
                                          coupe_vs
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
