  4. Add existing POI to a route?
15 Posts 6 Posters 2.5k Views 4 Watching
    I think it's really simple.
    Create a waypoint somewhere along the route near the POI. It will automatically be assigned a number between the previous and next waypoints.
    Drag this newly created waypoint to the POI's location (assuming it's located along a road), and the route will adjust accordingly!
    So: First, add a new waypoint to the route (which will be point 7)!
    Now move waypoint 7 to the desired POI!
    And there you go—the POI has been added to the route!
    • infoevertkuiken.nl infoevertkuiken.nl
      I searched for an answer but can't find it so here is my question:
      How can I add a POI that I added earlier into a route (after not chosing this when adding the POI...)
      MartinW
      MartinW
      MartinW
      @infoevertkuiken.nl
      Maybe this is what you're looking for?
        infoevertkuiken.nl
        infoevertkuiken.nl
        Let me clarify: I have a route and some self created POI in it. I want to add the self created POI to a route. Like what you can do when creating the POI ("Add as waypoint"). When I created a POI just as POI and not (also) as a waypoint, there does not seem to be a way to add the created POI to the route. Of course I can add a waypoint on the position of the POI and call it the same.
        MartinW BertM 2 Replies Last reply
          MartinW
          MartinW
          MartinW
          @infoevertkuiken.nl said in Add existing POI to a route?:
          That's exactly what you can do following the steps shown in the screenshot above:
          (1) tap on the POI's icon
          (2) tap the crosshair
          (3) select "add as Waypoint" and accept
          infoevertkuiken.nl 1 Reply Last reply
            That only works when you have the POI in your libary ( I think you want to add the POI to another route..)
            changing a POI into a routepoint in the existing route seems odd.
            you can export the POI of the route and then inport them to your libary to use.
            • MartinW MartinW
              infoevertkuiken.nl
              infoevertkuiken.nl
              infoevertkuiken.nl
              @Martin-Wilcke But I already added the POI to the route but not as a waypoint. And then you get this menu. No option to add it as a waypoint.
              MartinW 1 Reply Last reply
              • BertM BertM
                infoevertkuiken.nl
                infoevertkuiken.nl
                infoevertkuiken.nl
                @BertM I want to add the POI in the route as a waypoint in the same route.
                BertM 1 Reply Last reply
                  Add a waypoint and delete the POI is the only option
                  • BertM BertM
                    ( btw MRA calls it a shaping point, not a waypoint)
                      ...there is currently no way! If you have added a POI into a route - just as POI only - then there is afterwards no option to make it additionally as a route point too. This option is only available in the beginning of that procedure.
                      Now you can do only:
                      • goto section "Points Of Interest" / tab "Manage", tip your added POI
                      • or
                      • tip in the map with your route on your added POI
                      • to get the options menue to delete this POI - delete it
                      • then add this waypoint again - and be carfull to select now the right (or both) options to get it as POI (and) as route point
                        MartinW
                        MartinW
                        MartinW
                        Ahhh - you mean, you added the POI to your route so that it appears under "manage", right? I imagined you meant a POI that you added to a personal library.
                        Sorry for my misunderstanding - yes, I agree with @BertM : that doesn't work this way.
                          Just like I already have shown, follow the steps in the screenshots above. At the moment it's as far as I know, the only way!
                          MartinW
                          MartinW
                          infoevertkuiken.nl
                          infoevertkuiken.nl
                          • Online map settings
                            MartinW
                            MartinW
                          • Real-time traffic
                            Òscar
                            Òscar
                            Andy Nicholson
                            Andy Nicholson
                          • HERE map not calibrated
                            MartinW
                            MartinW
                          • Myrouteappstay
                            Bé Jeuring
                            Bé Jeuring
                          • Navigatie met DMD tablet
                          • Show on the maps's button
