  4. Add existing POI to a route?
15 Posts 6 Posters 2.5k Views 4 Watching
  • infoevertkuiken.nl
    infoevertkuiken.nl
    infoevertkuiken.nl
    I searched for an answer but can't find it so here is my question:
    How can I add a POI that I added earlier into a route (after not chosing this when adding the POI...)
    Guzzist MotoCon MartinW 4 Replies Last reply
    • infoevertkuiken.nl infoevertkuiken.nl
      @infoevertkuiken.nl uh, I would like to help, but unfortunatelly I don't understand your question.
      You imported or created a route?
      And you selected a POI out of the big POI list and added it to the route?
      And what do you want to do next?
        @infoevertkuiken.nl, The formulation of your question is indeed not very clear. I hope to get you started here:
        Handleiding 'POIs'
        Considering your name I linked the Dutch support page 😉
          I think it's really simple.
          Create a waypoint somewhere along the route near the POI. It will automatically be assigned a number between the previous and next waypoints.
          Drag this newly created waypoint to the POI's location (assuming it's located along a road), and the route will adjust accordingly!
          So: First, add a new waypoint to the route (which will be point 7)!
          Now move waypoint 7 to the desired POI!
          And there you go—the POI has been added to the route!
            MartinW
            MartinW
            MartinW
            @infoevertkuiken.nl
            Maybe this is what you're looking for?
              infoevertkuiken.nl
              infoevertkuiken.nl
              Let me clarify: I have a route and some self created POI in it. I want to add the self created POI to a route. Like what you can do when creating the POI ("Add as waypoint"). When I created a POI just as POI and not (also) as a waypoint, there does not seem to be a way to add the created POI to the route. Of course I can add a waypoint on the position of the POI and call it the same.
              MartinW BertM 2 Replies Last reply
                MartinW
                MartinW
                MartinW
                @infoevertkuiken.nl said in Add existing POI to a route?:
                That's exactly what you can do following the steps shown in the screenshot above:
                (1) tap on the POI's icon
                (2) tap the crosshair
                (3) select "add as Waypoint" and accept
                infoevertkuiken.nl 1 Reply Last reply
                  That only works when you have the POI in your libary ( I think you want to add the POI to another route..)
                  changing a POI into a routepoint in the existing route seems odd.
                  you can export the POI of the route and then inport them to your libary to use.
                  • MartinW MartinW
                    infoevertkuiken.nl
                    infoevertkuiken.nl
                    infoevertkuiken.nl
                    @Martin-Wilcke But I already added the POI to the route but not as a waypoint. And then you get this menu. No option to add it as a waypoint.
                    MartinW 1 Reply Last reply
                    • BertM BertM
                      infoevertkuiken.nl
                      infoevertkuiken.nl
                      infoevertkuiken.nl
                      @BertM I want to add the POI in the route as a waypoint in the same route.
                      BertM 1 Reply Last reply
                        Add a waypoint and delete the POI is the only option
                        • BertM BertM
                          ( btw MRA calls it a shaping point, not a waypoint)
                            ...there is currently no way! If you have added a POI into a route - just as POI only - then there is afterwards no option to make it additionally as a route point too. This option is only available in the beginning of that procedure.
                            Now you can do only:
                            • goto section "Points Of Interest" / tab "Manage", tip your added POI
                            • or
                            • tip in the map with your route on your added POI
                            • to get the options menue to delete this POI - delete it
                            • then add this waypoint again - and be carfull to select now the right (or both) options to get it as POI (and) as route point
                              MartinW
                              MartinW
                              MartinW
                              Ahhh - you mean, you added the POI to your route so that it appears under "manage", right? I imagined you meant a POI that you added to a personal library.
                              Sorry for my misunderstanding - yes, I agree with @BertM : that doesn't work this way.
                                Just like I already have shown, follow the steps in the screenshots above. At the moment it's as far as I know, the only way!
                                MartinW
                                MartinW
                                infoevertkuiken.nl
                                infoevertkuiken.nl
                                • Online map settings
                                  MartinW
                                  MartinW
                                • Real-time traffic
                                  Òscar
                                  Òscar
                                  Andy Nicholson
                                  Andy Nicholson
                                • HERE map not calibrated
                                  MartinW
                                  MartinW
                                • Myrouteappstay
                                  Bé Jeuring
                                  Bé Jeuring
                                • Navigatie met DMD tablet
                                • Show on the maps's button
