  4. Add existing POI to a route?
15 Posts 6 Posters 1.9k Views 4 Watching
  • infoevertkuiken.nl infoevertkuiken.nl
    I searched for an answer but can't find it so here is my question:
    How can I add a POI that I added earlier into a route (after not chosing this when adding the POI...)
    martin-phogel.de Offline
    martin-phogel.de
    @infoevertkuiken.nl
    Maybe this is what you're looking for?
    • infoevertkuiken.nl Offline
      infoevertkuiken.nl
      Let me clarify: I have a route and some self created POI in it. I want to add the self created POI to a route. Like what you can do when creating the POI ("Add as waypoint"). When I created a POI just as POI and not (also) as a waypoint, there does not seem to be a way to add the created POI to the route. Of course I can add a waypoint on the position of the POI and call it the same.
      martin-phogel.de BertM 2 Replies Last reply
        martin-phogel.de
        @infoevertkuiken.nl said in Add existing POI to a route?:
        That's exactly what you can do following the steps shown in the screenshot above:
        (1) tap on the POI's icon
        (2) tap the crosshair
        (3) select "add as Waypoint" and accept
        infoevertkuiken.nl 1 Reply Last reply
          BertM Offline
          BertM Offline
          That only works when you have the POI in your libary ( I think you want to add the POI to another route..)
          changing a POI into a routepoint in the existing route seems odd.
          you can export the POI of the route and then inport them to your libary to use.
            infoevertkuiken.nl
            @Martin-Wilcke But I already added the POI to the route but not as a waypoint. And then you get this menu. No option to add it as a waypoint.
            • BertM BertM
              infoevertkuiken.nl
              @BertM I want to add the POI in the route as a waypoint in the same route.
              BertM 1 Reply Last reply
                BertM Offline
                BertM Offline
                Add a waypoint and delete the POI is the only option
                • BertM BertM
                  BertM Offline
                  BertM Offline
                  ( btw MRA calls it a shaping point, not a waypoint)
                    Guzzist Offline
                    Guzzist Offline
                    ...there is currently no way! If you have added a POI into a route - just as POI only - then there is afterwards no option to make it additionally as a route point too. This option is only available in the beginning of that procedure.
                    Now you can do only:
                    • goto section "Points Of Interest" / tab "Manage", tip your added POI
                    • or
                    • tip in the map with your route on your added POI
                    • to get the options menue to delete this POI - delete it
                    • then add this waypoint again - and be carfull to select now the right (or both) options to get it as POI (and) as route point
                      martin-phogel.de
                      Ahhh - you mean, you added the POI to your route so that it appears under "manage", right? I imagined you meant a POI that you added to a personal library.
                      Sorry for my misunderstanding - yes, I agree with @BertM : that doesn't work this way.
                      • white.mouse Offline
                        white.mouse Offline
                        wrote on last edited by white.mouse
                        Just like I already have shown, follow the steps in the screenshots above. At the moment it's as far as I know, the only way!
                        martin-phogel.de
                        martin-phogel.de
                        infoevertkuiken.nl
                        infoevertkuiken.nl
                        • Export to BMW CRN
                        • Rondrit genereren
                        • Hiding home address / waypoint for shared routes
                          Pim van Dongen
                          Pim van Dongen
                        • NC500 glitch
                        • Gidday from New Zealand.
                          Bull Tahr
                          Bull Tahr
                        • Berekende route tijd
