  4. How to reverse route?
14 Posts 10 Posters 4.0k Views 5 Watching
  • guenniguenzelsen
    guenniguenzelsen
    guenniguenzelsen
    Hi Rob
    Thanks for your reply.
    I have the Gold subscription and followed the way you described.
    But the result is unusable. I would need to check and correct 80 waypoints.
    But if the App can calculate a route in one direction correctly, it shall be able to calculate the other way round without screwing totally up, or am I getting this wrong?
    Nick Carthew Travellexxie richtea999 3 Replies Last reply
    • guenniguenzelsen guenniguenzelsen
      Hi Rob
      @guenniguenzelsen said in How to reverse route?:
      I think that I am correct when I say that both the website and mobile app roundtrip generators always generate routes in a clockwise direction.
      • guenniguenzelsen
        guenniguenzelsen
        guenniguenzelsen
        Yes, but for this tour I need the route counterclockwise, which seems not to be possible
          @guenniguenzelsen Yes, it is not possible to simply change the direction, but with relatively little effort, it is possible to reverse the route.
          Create a circular route in the app, then edit the route track (assigning a name at the same time).
          Then change the direction in the toolkit.
          Of course, you'll need to quickly check the points which the system has set, but you'll quickly see if there are any unnecessary detours. If so, simply delete the unwanted points and within 5 minutes you'll have a fun tour 😉
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
            Hi Rob
            @guenniguenzelsen you only have to check, where the route has other directions. If you insert the original route in the map, so that you see them both, you can directly see where it differs.
            MRA Lifetime Gold
              Of course tracks cannot be simply reversed. On the Motorbeurs in Utrecht I spoke to a customer with a similar question. His reason for wanting to reverse a roundtrip was to choose a way to avoid as much direct sunlight in the face as possible. I am not sure many people have the same wish, but a toggle (sorry @Corjan-Meijerink 🤣 ) for clockwise or counterclockwise in the roundtrip generator might make sense to many people.
              martin-phogel.de Guzzist 2 Replies Last reply
                Hi Rob
                Hi Rob
                You should definitely check every point after using Reverse. It doesn't take long - you won't need to correct all of them.
                Here's one good reason why:
                • if one of your waypoints is on a dual carriageway (or other one-way road system), the router will not magically move your waypoint to the other side of the dual carriageway. It will route you up the (now) wrong side and back down again. That doubling back could make quite a long route!
                And another:
                • good practice for positioning waypoints is to place them after junctions rather than before (so the vital junction announcement isn't lost by the waypoint being announced). When you reverse a route all those carefully placed waypoints are now before the junctions. Arghh!
                  martin-phogel.de
                  martin-phogel.de
                  martin-phogel.de
                  @Con-Hennekens said in How to reverse route?:
                    ... reason for wanting to reverse a roundtrip was to choose a way to avoid as much direct sunlight in the face as possible...
                    Yes, it may depend at the region you are driving. I have the same issue: the problem arises when cycling uphill and downhill in early spring and late autumn in my beloved Bavarian Forest region in Germany.
                    To solve this, I have devised routes that run clockwise and counter-clockwise...
                      The simplest way to check the route points is to zoom in as far as possible and then click on each point in the route points list (on the left side of the screen). You will then immediately see which points are next to the road or route and which ones may be positioned on the wrong side of the road.
                      And yes, for 80 points, that means clicking 80 times, but it works!
                      It is a good idea to do this for every route to prevent problems. This way, you can be sure that all route points are correctly positioned on the road.
                      • Guzzist
                        ...I believe, it may not be needed to check each and every rootpoint. There would be no problem after change of root direction at 2nd or 3rd street level; only at highways and 1st level roads with track separation. On the map this must be clearly visible. Also, you would see turnarounds of the root line. In my opinion at this points, the root line is darker...
                        • Guzzist Guzzist
                          @Guzzist said in How to reverse route?:
                          It does, only when you have set a transparency to the line 😉
                          martin-phogel.de
                          martin-phogel.de
                          guenniguenzelsen
                          guenniguenzelsen
                            Captain Haddock
                            Captain Haddock
                            21
                            36
                            257
                          • Kaart niet zichtbaar
                            Nico Beerepoot
                            Nico Beerepoot
                            176
                          • Google maps
                            Stanisław
                            Stanisław
                            162
                          • RouteXpert display on the map
                            Corrado Miniati 0
                            Corrado Miniati 0
                            Tim Verhaaf
                            Tim Verhaaf
                          • Disabling Waypoints?
                            Jannes van Dijken
                            Jannes van Dijken
                          • Map viewing options
                            180
                          • Discrepancy between Planner and NavigationApp
                            Reinhard Grossmann h 0
