  4. How to reverse route?
14 Posts 10 Posters 2.7k Views 5 Watching
  • guenniguenzelsenundefined Offline
    guenniguenzelsen
    Hi
    I'm planning a route via the roundtrip option.
    The route itself is good, but I need to reverse it (some of the mates want to exit after 3/4, because they are close to home then).
    I'm struggeling with this task actually and maybe somebody can point me into the right direction.
    1. I save the route, but am not asked to set an individual route name.
      How do I do that?
    2. In the App I cannot find the option to reverse the route.
      Where can I do that?
    3. I tried the route lab and found an option to reverse the route.
      After that the route was totally shot. The distance increased from 176km to 220km and the route contains turnarounds and stupid circles.
      No chance to anyhow correct this 80 waypoints.
      What did I do wrong here?
    4. I tried several times to change the route in route lab.
      Before editing, I had to give a route name.
      I used the same name every time.
      In my route folder I now have several different routes with the same name.
      No chance to differentiate. If using an existing name, the normal expectation is to be asked, if I want to replace the existing file.
      What am I doing wrong here?
    Sorry for so many questions.
    Right now I seem not to be able to just automatically create a round tour with the direction I need.
    Cheers
    Thomas
    • guenniguenzelsenundefined guenniguenzelsen
      Hi
        How do I do that?
      Cheers
      Thomas
      Rob Verhoeffundefined Offline
      @guenniguenzelsen You need at least a Gold subscription in Routelab for the functionality to reverse a created route. First, save the roundtrip you've generated. Then, I would copy the original and subsequently select 'Reverse' in the toolkit menu.
      After that, you will need to check all route points to ensure they are on the correct side of the road. If a route point is on a road with split lanes and it's on the wrong side of the road, you'll get a very strange route. By the way, you'll find this in the help files too!
        guenniguenzelsen
        Hi Rob
        Thanks for your reply.
        I have the Gold subscription and followed the way you described.
        But the result is unusable. I would need to check and correct 80 waypoints.
        But if the App can calculate a route in one direction correctly, it shall be able to calculate the other way round without screwing totally up, or am I getting this wrong?
        Nick Carthewundefined Travellexxieundefined richtea999undefined 3 Replies Last reply
          Hi Rob
          Nick Carthewundefined Offline
          @guenniguenzelsen said in How to reverse route?:
          I think that I am correct when I say that both the website and mobile app roundtrip generators always generate routes in a clockwise direction.
            guenniguenzelsen
            Yes, but for this tour I need the route counterclockwise, which seems not to be possible
              @guenniguenzelsen Yes, it is not possible to simply change the direction, but with relatively little effort, it is possible to reverse the route.
              Create a circular route in the app, then edit the route track (assigning a name at the same time).
              Then change the direction in the toolkit.
              Of course, you'll need to quickly check the points which the system has set, but you'll quickly see if there are any unnecessary detours. If so, simply delete the unwanted points and within 5 minutes you'll have a fun tour πŸ˜‰
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Motorola Edge 40 "offline"
              Sena SLR 3
              Sena 50 R
                Hi Rob
                Travellexxieundefined Offline
                @guenniguenzelsen you only have to check, where the route has other directions. If you insert the original route in the map, so that you see them both, you can directly see where it differs.
                Ducati Monster 1200 met Garmin ZΓΌmo XT
                MRA Lifetime Gold
                  Of course tracks cannot be simply reversed. On the Motorbeurs in Utrecht I spoke to a customer with a similar question. His reason for wanting to reverse a roundtrip was to choose a way to avoid as much direct sunlight in the face as possible. I am not sure many people have the same wish, but a toggle (sorry @Corjan-Meijerink 🀣 ) for clockwise or counterclockwise in the roundtrip generator might make sense to many people.
                  martin-phogel.deundefined Guzzistundefined 2 Replies Last reply
                    Hi Rob
                    richtea999undefined Offline
                    Hi Rob
                    You should definitely check every point after using Reverse. It doesn't take long - you won't need to correct all of them.
                    Here's one good reason why:
                    • if one of your waypoints is on a dual carriageway (or other one-way road system), the router will not magically move your waypoint to the other side of the dual carriageway. It will route you up the (now) wrong side and back down again. That doubling back could make quite a long route!
                    And another:
                    • good practice for positioning waypoints is to place them after junctions rather than before (so the vital junction announcement isn't lost by the waypoint being announced). When you reverse a route all those carefully placed waypoints are now before the junctions. Arghh!
                      martin-phogel.deundefined Offline
                      martin-phogel.de
                      @Con-Hennekens said in How to reverse route?:
                        Guzzistundefined Offline
                        ... reason for wanting to reverse a roundtrip was to choose a way to avoid as much direct sunlight in the face as possible...
                        Yes, it may depend at the region you are driving. I have the same issue: the problem arises when cycling uphill and downhill in early spring and late autumn in my beloved Bavarian Forest region in Germany.
                        To solve this, I have devised routes that run clockwise and counter-clockwise...
                          The simplest way to check the route points is to zoom in as far as possible and then click on each point in the route points list (on the left side of the screen). You will then immediately see which points are next to the road or route and which ones may be positioned on the wrong side of the road.
                          And yes, for 80 points, that means clicking 80 times, but it works!
                          It is a good idea to do this for every route to prevent problems. This way, you can be sure that all route points are correctly positioned on the road.
                          • Guzzistundefined Offline
                            ...I believe, it may not be needed to check each and every rootpoint. There would be no problem after change of root direction at 2nd or 3rd street level; only at highways and 1st level roads with track separation. On the map this must be clearly visible. Also, you would see turnarounds of the root line. In my opinion at this points, the root line is darker...
                            • Guzzistundefined Guzzist
                              @Guzzist said in How to reverse route?:
                              It does, only when you have set a transparency to the line πŸ˜‰
                              richtea999undefined
                              guenniguenzelsen
                              martin-phogel.de
                              • Mi spiegate che problemi ha ???
                                Aiello antoninoundefined
                                256
                              • Can't get MRA to use a ection of N20 road near Merens-les-Vals, France to Andorra
                                Steve Kelly 0undefined
                                Steve Kelly 0
                              • Add screen lock to free drive
                                maurizio 0undefined
                                maurizio 0
                              • Starting navigation to favorite via CarPlay always fails first time
                                John S Parryundefined
                              • Most basic introduction for a newbie group
                                435
                              • Which is the best GPX version to send to a TomTom Go user?
                                Adrian Avramundefined
                              • BMW Wonderwheel Android Auto zoom
