  4. MRA CarPlay mit Remotek One
53 Posts 12 Posters 22.0k Views 7 Watching
  • Huibertus
    Huibertus
    Huibertus
    I'm still very interested in the Remotek 1 because of its price, size, and the fact that it's truly wireless (battery). However, I'm worried that there's no iPhone app for it and because of the text on the Remotek website that says, "Important: This (or any) remote controller does not work properly with most apps in CarPlay or Android Auto." Is it still true that Google Maps and Waze can't be controlled with the Remotek? Does your Remotek works still good with the MRA app?
    • Hubert Thoring
      So, my Remotek One still works perfectly with MRA, zoom +/-, and skipping WP, etc. There's also an app for Apple users, which is mentioned on the website, but this app is only for downloading a firmware update. All other information is also available in the manual on the website.
      A friend has confirmed it's available for CarPlay, User, "Papa" im GS-Forum.com
      Link zum GS-Forum.com Thema Remotek One
      Link zum GS-Forum.com Thema MyRouteApp
      Huibertus 2 Replies Last reply
      • Huibertus Huibertus
        @Huibertus, it ( like any other controller attached to your phone) will control your phone, not your Carplay device. Most functions however will be replicated by the app to your Carplay device. Like if you zoom on your phone, your carplays screen also zooms. However when your phone lays idle, or app is not in focus, nothing will happen on your carplay screen.
        • Huibertus
          Huibertus
          Huibertus
          Thanks, Con. I've tried to read up on the various options, and I'm aware that the MRA app needs to be open. I don't think it's a huge problem. For me, the advantages of the CP far outweigh this. However, there aren't many options that support iOS. I can only find the Barbuttons (a bit crude in design) and the Remotek 1. I want to compare the latter two again.
            Huibertus
            Huibertus
            Huibertus
            @Hubert-Thoring Thnx Hubert. I will visit the links you send me. I am very curious.
              Huibertus
              Huibertus
              Huibertus
              @Hubert-Thoring
              Hi Hubert,
              I've had a quick look but can't find "Papa's" entry. I can find your twin brother, "MS_MagnaR43." 😁
              • Hubert Thoring
                #21
                Zu Para, ich Chatte mit ihm weil er sich die Remotek One gekauft hat, er Testet viel, und nutzt intensiv die MyRouteApp.
                Er will am Montag das R7M testen im Zusammenspiel mit CarPlay und Remotek One, bei den anderen bekannten Displays geht +/- Zoomen und WP überspringen wie in meinem Test beschrieben…!
                To Para, I chat with him because he bought the Remotek One, he tests a lot, and uses the MyRouteApp intensively.
                He wants to test the R7M on Monday in combination with CarPlay and Remotek One, with the other well-known displays +/- zoom and skip WP as described in my test...!
                Huibertus 1 Reply Last reply
                • silberfuchs67
                  silberfuchs67
                  silberfuchs67
                  @Huibertus I think it‘s user „Para“
                    Huibertus
                    Huibertus
                    Huibertus
                    @Hubert-Thoring
                    Hallo, ich kann Para nicht finden, deshalb bitte ich Sie, die unten stehende Nachricht an ihn weiterzuleiten.
                    Im Supportbereich unter „Bluetooth-Controller“ habe ich auf der Remotek One-Website gelesen, dass in Firmware-Version 2.X mehrere Funktionen entfernt wurden. Konkret handelt es sich um „Menü öffnen“ (Code K) und „Angezeigte Ankunftszeit ändern (Ende, Via oder Formation)“ (Code N). Das würde bedeuten, dass diese Funktionen nicht mehr nutzbar sind. Dies wird auch auf der Remotek-Website mehr oder weniger bestätigt. Dort heißt es jedoch auch: „Neue Funktion in Version 2.1.0:
                    Doppelklick auf Pfeil nach oben = sendet den Tastendruck „N“. Doppelklick auf Pfeil nach unten = sendet den Tastendruck „K“.“ Dies dürften die fehlenden Codes sein, die nun anscheinend wieder enthalten sind. Bedeutet das, dass die Funktionen in der neuen Firmware-Version enthalten sind? Könnten Sie bitte überprüfen, ob diese Funktionen in der neuen Version funktionieren?
                    • silberfuchs67 silberfuchs67
                      Huibertus
                      Huibertus
                      Huibertus
                      @silberfuchs67 Thnx 👍
                      • Hubert Thoring
                        #25
                        User: Para - Link Klick hier
                        Und etwas nach unten scrollen …
                        Bitte schreibe ihn selbst an !
                          @Huibertus said in MRA CarPlay mit Remotek One:
                          Was genau heißt das jetzt, bitte etwas erklären 😉
                          • Hubert Thoring
                            #27
                            @Huibertus : kennst den Bericht schon über die Remotek One Erfahrungen, ich selbst nutze keine Bedienung des Menü, Untermenü da zu gefährlich bei der Fahrt.
                            Die allgemeine Info siehe hier Link zum Erfahrungsaustausch
                              Huibertus
                              Huibertus
                              Huibertus
                              @Hubert-Thoring This is about version V1.1.2 The latest version is V2.x
                                Huibertus
                                Huibertus
                                Huibertus
                                @Hubert-Thoring I will see if I can do that. I am not subscibed in that forum
                                  @Huibertus der @silberfuchs67 benutzt die neuste Version, vielleicht tauscht ihr euch mal aus ! VG Hubert
                                    @Huibertus, Controllers from Silverfox just work with iOS and need no software at all to work with MRA.
                                    https://www.silverfoxcontrollers.com/product-page/silverfox-h1-home-one-plus-navigation-controller
                                    BarButtons is really nice, but I believe the project is in slowmotion at the moment. I have been building multiple of these units. If you are interested in one of them, send me a DM.
                                    • Huibertus
                                      Huibertus
                                      Huibertus
                                      Dear Con,
                                      Thank you for your reply. I think the Silverfox is a very nice, but quite expensive device. However, if everything works well and it can handle the right apps, I'll make the switch. However, I'd already written it off because I can't find anywhere that it's compatible with iOS, not even on the Silverfox website.
                                      • Huibertus
                                        Huibertus
                                        Huibertus
                                        Dear Con,
                                        • Mopetenpit
                                          Mopetenpit
                                          Mopetenpit
                                          take a look here: click
                                          Stanisław
                                          Stanisław
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          Mopetenpit
                                          Mopetenpit
                                          DerRoteBlitz
                                          DerRoteBlitz
                                          • Kaart niet zichtbaar
                                            212
                                          • Xpert overlay not clear
                                            Bé Jeuring
                                            Bé Jeuring
                                            22
                                            41
                                            365
                                            Corrado Miniati 0
                                            Corrado Miniati 0
                                          • Google maps
                                            Ed Bos 0
                                            Ed Bos 0
                                            208
                                          • Trains like Ferries?
                                            Corrado Miniati 0
                                            Corrado Miniati 0
                                            289
