  4. MRA CarPlay mit Remotek One
55 Posts 12 Posters 23.6k Views 7 Watching
  • Hubert Thoring
    @Dave-J-0
    😎 Genau so habe ich mir das gedacht mit der Handy - CarPlay Kopplung, habe zwar kein CarPlay, konnte es somit auch nicht rundum testen, aber das Erlebnis habe ich 1:1 an meinem iPhone Xr Display am Motorrad. Also auch so mit CarPlay eine gute einfache Lösung.
    😎 That's exactly what I thought with the mobile phone - CarPlay coupling, I don't have CarPlay, so I couldn't test it all around, but I have the experience 1:1 on my iPhone Xr display on the motorcycle. So also with CarPlay a good simple solution.
    • Huibertus
      Huibertus
      Huibertus
      Thank You for your information.
      • Huibertus
        Huibertus
        Huibertus
        I'm still very interested in the Remotek 1 because of its price, size, and the fact that it's truly wireless (battery). However, I'm worried that there's no iPhone app for it and because of the text on the Remotek website that says, "Important: This (or any) remote controller does not work properly with most apps in CarPlay or Android Auto." Is it still true that Google Maps and Waze can't be controlled with the Remotek? Does your Remotek works still good with the MRA app?
        • Hubert Thoring
          So, my Remotek One still works perfectly with MRA, zoom +/-, and skipping WP, etc. There's also an app for Apple users, which is mentioned on the website, but this app is only for downloading a firmware update. All other information is also available in the manual on the website.
          A friend has confirmed it's available for CarPlay, User, "Papa" im GS-Forum.com
          Link zum GS-Forum.com Thema Remotek One
          Link zum GS-Forum.com Thema MyRouteApp
          Huibertus 2 Replies Last reply
          • Huibertus Huibertus
            @Huibertus, it ( like any other controller attached to your phone) will control your phone, not your Carplay device. Most functions however will be replicated by the app to your Carplay device. Like if you zoom on your phone, your carplays screen also zooms. However when your phone lays idle, or app is not in focus, nothing will happen on your carplay screen.
            • Huibertus
              Huibertus
              Huibertus
              Thanks, Con. I've tried to read up on the various options, and I'm aware that the MRA app needs to be open. I don't think it's a huge problem. For me, the advantages of the CP far outweigh this. However, there aren't many options that support iOS. I can only find the Barbuttons (a bit crude in design) and the Remotek 1. I want to compare the latter two again.
                Huibertus
                Huibertus
                Huibertus
                @Hubert-Thoring Thnx Hubert. I will visit the links you send me. I am very curious.
                  Huibertus
                  Huibertus
                  Huibertus
                  @Hubert-Thoring
                  Hi Hubert,
                  I've had a quick look but can't find "Papa's" entry. I can find your twin brother, "MS_MagnaR43." 😁
                  • Hubert Thoring
                    #21
                    Zu Para, ich Chatte mit ihm weil er sich die Remotek One gekauft hat, er Testet viel, und nutzt intensiv die MyRouteApp.
                    Er will am Montag das R7M testen im Zusammenspiel mit CarPlay und Remotek One, bei den anderen bekannten Displays geht +/- Zoomen und WP überspringen wie in meinem Test beschrieben…!
                    To Para, I chat with him because he bought the Remotek One, he tests a lot, and uses the MyRouteApp intensively.
                    He wants to test the R7M on Monday in combination with CarPlay and Remotek One, with the other well-known displays +/- zoom and skip WP as described in my test...!
                    Huibertus 1 Reply Last reply
                    • silberfuchs67
                      silberfuchs67
                      silberfuchs67
                      @Huibertus I think it‘s user „Para“
                        Huibertus
                        Huibertus
                        Huibertus
                        @Hubert-Thoring
                        Hallo, ich kann Para nicht finden, deshalb bitte ich Sie, die unten stehende Nachricht an ihn weiterzuleiten.
                        Im Supportbereich unter „Bluetooth-Controller“ habe ich auf der Remotek One-Website gelesen, dass in Firmware-Version 2.X mehrere Funktionen entfernt wurden. Konkret handelt es sich um „Menü öffnen“ (Code K) und „Angezeigte Ankunftszeit ändern (Ende, Via oder Formation)“ (Code N). Das würde bedeuten, dass diese Funktionen nicht mehr nutzbar sind. Dies wird auch auf der Remotek-Website mehr oder weniger bestätigt. Dort heißt es jedoch auch: „Neue Funktion in Version 2.1.0:
                        Doppelklick auf Pfeil nach oben = sendet den Tastendruck „N“. Doppelklick auf Pfeil nach unten = sendet den Tastendruck „K“.“ Dies dürften die fehlenden Codes sein, die nun anscheinend wieder enthalten sind. Bedeutet das, dass die Funktionen in der neuen Firmware-Version enthalten sind? Könnten Sie bitte überprüfen, ob diese Funktionen in der neuen Version funktionieren?
                        • silberfuchs67 silberfuchs67
                          Huibertus
                          Huibertus
                          Huibertus
                          @silberfuchs67 Thnx 👍
                          • Hubert Thoring
                            #25
                            User: Para - Link Klick hier
                            Und etwas nach unten scrollen …
                            Bitte schreibe ihn selbst an !
                              @Huibertus said in MRA CarPlay mit Remotek One:
                              Was genau heißt das jetzt, bitte etwas erklären 😉
                              • Hubert Thoring
                                #27
                                @Huibertus : kennst den Bericht schon über die Remotek One Erfahrungen, ich selbst nutze keine Bedienung des Menü, Untermenü da zu gefährlich bei der Fahrt.
                                Die allgemeine Info siehe hier Link zum Erfahrungsaustausch
                                  Huibertus
                                  Huibertus
                                  Huibertus
                                  @Hubert-Thoring This is about version V1.1.2 The latest version is V2.x
                                    Huibertus
                                    Huibertus
                                    Huibertus
                                    @Hubert-Thoring I will see if I can do that. I am not subscibed in that forum
                                      @Huibertus der @silberfuchs67 benutzt die neuste Version, vielleicht tauscht ihr euch mal aus ! VG Hubert
                                        @Huibertus, Controllers from Silverfox just work with iOS and need no software at all to work with MRA.
                                        https://www.silverfoxcontrollers.com/product-page/silverfox-h1-home-one-plus-navigation-controller
                                        BarButtons is really nice, but I believe the project is in slowmotion at the moment. I have been building multiple of these units. If you are interested in one of them, send me a DM.
                                        • Huibertus
                                          Huibertus
                                          Huibertus
                                          Dear Con,
                                          Thank you for your reply. I think the Silverfox is a very nice, but quite expensive device. However, if everything works well and it can handle the right apps, I'll make the switch. However, I'd already written it off because I can't find anywhere that it's compatible with iOS, not even on the Silverfox website.
                                          Stanisław
                                          Stanisław
                                          Mopetenpit
                                          Mopetenpit
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          DerRoteBlitz
                                          DerRoteBlitz
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            104
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                          • Map Layers
                                            Don Stauffer
                                            Don Stauffer
                                            Andy Smith 5
                                            Andy Smith 5
