  4. Map "spinning" when standing still
110 Posts 33 Posters 52.7k Views 10 Watching
    Wanneer ongeveer komt deze Beta (5.0.2) beschikbaar zodat ik eventueel wat kan plannen om te testen; Ik heb ook last van dit "spinning" als ik bij verkeerslichten of een kruising stil sta!
      Expecting after the weekend but maybe I'll submit it tomorrow 😉
      Depending on the platform you are using it will also take another day or two before it's available.
      • peha
        peha
        peha
        wrote on last edited by peha
        #37
        @Corjan-Meijerink Are more beta testers needed? I'd be willing to test a little, if it helps (my setup is noted in the footer: Android with two AA-devices).
        BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
        VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
        Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
          I did see it on my normal navigation phone on a few trips. Today i use my daily phone, which i only use in the car for navigation (not on my bike). On this phone i saw the behaviour also
          Both were running Android Auto.
          On the bike it spins more than once on the same spot (but not constant) mostly back and forth. In the car mostly it spins only once. Just as soon as i stopped.
          Let's what the new version brings
          • Albert van den Elsen
            This issue may simply be due to a weak GPS signal. I don’t think it’s related to MRA.
            iPhone 15,
            Garmin Zumo XT3
            Carpuride W702 Pro
            Sena 20S EVO headset
            Harley Davidson Road King M8
              @Albert-van-den-Elsen my Guess is that it's the combination of some type of phones, mostly Android based and some AA/CP devices. I havent seen the issue at all.
                Yeah, that’s the annoying thing of these issues. It’s definitely device related so some have it, others do not. GPS positioning and especially on Android devices is not always as accurate as you’d hope.
                • peha
                  peha
                  peha
                  #42
                  With my Samsung S22 Ultra, it is reproducibly a problem that occurs with MyRouteApp, but not with Google Maps: Sitting on my couch at home, phone laying on a table (i.e., not moving at all, not being touched), after I have opened MRA on the phone, the "view direction" (map orientation) changes several times for about 90 or 180 degrees, the movement pauses some seconds and then moves again. When it finally settles, it doesn't point in the actual direction the phone faces. Moving the phone after it has "settled", the map doesn't react any longer (map not moving). The compass needle symbol changes from "triangle shape" (map rotation follows phone) to a "strike-through compass needle" (?). No AA device involved at this point. This happens only with MRA, Google Maps doesn't show any problems, and another navigation app I had (but have uninstalled a few days ago), Magic Earth, didn't either show this problem. For me, it's clearly isolated with MRA, and while I may have seen an occasional map spin in earlier versions, it is now a constant problem (as soon as the device doesn't move) and, unfortunately, dramatically reduces the actual usefulness of the app for navigation. Phone is the same; the only thing that has changed is, there have been security/firmware updates by Samsung over the years.
                    It is also MRA related. Why?
                    At least on my phones, only MRA has this problem. Maybe Here is the cause. I don't know
                    But just like i wrote in other topics. There are other GPS related things which only occur in MRA and not in other navigation apps
                      Some phone have not only GPS but also a hardware compass. These are able to "see" in which direction they are held. Phones that don't have a compass, extrapolate direction from movement. That gets very inaccurate while standing still. Then there are apps that that rely on location services only (I don't know if direction is taken from compass if available), and there are apps that have different methods of approaching hardware. It all is a little more complicated then one might think...
                      • Donovan Smith
                        Donovan Smith
                        Donovan Smith
                        same with me on i phone. not touching phone or anything. It flips and then flips back. doesn't happen every time but sometimes even when riding
                        • peha
                          peha
                          peha
                          I don't doubt that it's complicated. I also didn't mean to "blame", should it have come across like this, stating that Google Maps doesn't show this phenomenon, but rather point out that it is possible to somehow avoid this problem (i.e., there's hope). I do, however, wonder why (for my setup at least) the severity/frequency of the spinning has increased to a level where it occurs at practically every stop. 🙁 Something must have changed.
                            @Con-Hennekens said in Map "spinning" when standing still:
                            It is true what you say but when you have multiple navigation apps on your phone and use all of them also. And only one app have issues. Than it is pretty obvious that this app is the one which needs to fix it.
                            I know it not easy to fix this. As @Corjan-Meijerink wrote. There so many different phones and not all have these issues.
                              @M.-Schrijver When version 5.0.2 is released you may see an improvement.
                              • LE DIZES Freddy
                                LE DIZES Freddy
                                LE DIZES Freddy
                                I just tried version 5.02 and the problem with the map spinning while stopped is still there.
                                Happy holidays to everyone!
                                Nick Carthew Corjan Meijerink 2 Replies Last reply
                                • LE DIZES Freddy LE DIZES Freddy
                                  @LE-DIZES-Freddy said in Map "spinning" when standing still:
                                  Are you one of the BETA testers?
                                  LE DIZES Freddy 1 Reply Last reply
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    @Nick-Carthew oui
                                      @LE-DIZES-Freddy is that on Android itself or in Android Auto?
                                      A big part of my fix for the map spinning caused a major issue on some Android Auto devices leading to the position not updating al all 🙂
                                        LE DIZES Freddy
                                        LE DIZES Freddy
                                        LE DIZES Freddy
                                        @Corjan-Meijerink bonsoir Cojan
                                        sur Android , Crossacall Action X5 MRA 5.0.2-441
                                          I won't make any further changes regarding this issue for now.
                                          To resolve the true core of the issue - which I attempted - another solution needs to be designed. My fix resulted in major Android Auto issues.
                                          In short: some GPS information (regarding accuracy) is missing on certain devices causing the spinning. However some Android Auto devices never report this information as the GPS is often very cheap (no offence). So I simply cannot say something like "if accuracy is missing, ignore the position update" which in reality is exactly what we'd need to do. When I tested this with simulations the spinning was indeed completely gone while when driving everything still worked as designed. But because those Android Auto devices never report certain GPS metadata, this solution cannot be used.
                                          Now why do other apps possibly not show this issue? We completely rely on GPS data and their accuracy while other apps (especially native ones) might use extra device information from internal accelerometers etc.
                                          Erik Plaggenborg 1 Reply Last reply
                                          • 4
                                          • 5
                                          • 6
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          TomOnTour
                                          TomOnTour
                                          Paul Steinberg
                                          Paul Steinberg
                                          peha
                                          peha
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
