  4. Saving shared route
Saving shared route
9 Posts 4 Posters 2.2k Views 2 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    How do you save a route that has been shared to you via a link?
    When you click on the route you get the option to Edit, Download, open route or navigate
    How do you save this to your own routes?
    Guzzist 1 Reply Last reply
    • Nick Carthew Nick Carthew moved this topic from [Web] Suggestions and Discussion on
      @stuart-marritt said in Saving shared route:
      • The owner, who shares a route via link to you, must keep his route in state "public"! Just then send the link.
      • If you have opened the route via received link, in MRA-Routeplanner - select in menu "+ Use route". This copies the route into your folder.
      • If the route is now in your folder, you can do everything: open, edit, save as...
      • If you also have MyRoute-App, and have synched this (or all routes) with MRA-Routeplanner, then you can simply open this route in MyRoute-App to navigate with.
      stuart marritt 1 Reply Last reply
      • Guzzist Guzzist
        stuart marritt
        stuart marritt
        stuart marritt
        @Guzzist thanks for the reply
        But that is for when you open it on the Web
        I need to be able to be sent a link and open it in the app and save it to my routes from there
        Especially when out and about and away from a pc
        Thanks
        Stu
        Nick Carthew Leike Lodiers Guzzist 3 Replies Last reply
          Thanks
          Stu
          @stuart-marritt
          Tap the edit button this takes you to the route planner, then tap Menu and then tap Route information. Change the title of the route, just a small change is required and then tap the X to close the Route information section. Tap Menu again and you should now see a Save option, tap Save, close the Route planner and the route will be in your library.
            Thanks
            Stu
            @stuart-marritt in the app you select:
            • select hamburger menu left topside
            • routes and tracklogs
            • select three point top right side
            • select sync all routes
              Now you`re routes will be synchronized from web to app and back.
              Thanks
              Stu
              Thanks
              Stu
              sorry, we don't understand completely.
              Who will generate a link of a route and how he will sent it?
              Who will receive a link of a route and will do what with it?
              • If someone is sending a route or track as gpx-file - my by mail - then you need to store this gpx-file on your smartphone.
              • by file browser, select this gpx-file and select "open by" - here select MyRoute-App.
              • you will be asked, if you want to store this file online in your MRA-Account. Select "Yes".
              • now you can navigate by this route or track. If you close navigation, you can find this route or track also in main menue -> routes / tracklogs and may open it again.
              • If someone is sending a route or track as link - may by mail or by chat - then check the link:
              • is it a link to a cloud storage, then you can download the gpx-file. Next steps see above -> open by
              • is it a web link like: https://www.myrouteapp.com/en/social/route/xxxxx?mode=share
                then you can tap this link at your smartphone, usually, this will open your standard browser and will show the route or track in MRA-Routeplanner
              • there you can download it and store locally. Next steps see above -> open by
              • alternatively, you don't need to download out of MRA-Routeplanner to local store. In MRA-Routeplanner, there is also the menue option "+use as route". This will copy this route into your folder in MRA-Account.
                ... if you have switched on, function "sync all" -> in MyRoute-App / main menue / 3-dot menue (top right corner) - this route is paralle to MRA-Routeplanner also in MyRoute-App available.
              It's not complicated! Try it at home until you are familiar with, Then you will not fall in troulble during your journey.
                @stuart-marritt
                stuart marritt
                stuart marritt
                stuart marritt
                @Nick-Carthew said in Saving shared route:
                @stuart-marritt
                This works although it would be ideal just to save it straight to your routes without having to edit them but its not a massive problem
                • Guzzist Guzzist
                  Thanks
                  Stu
                  stuart marritt
                  stuart marritt
                  stuart marritt
                  @Guzzist Someone has shared a route with me via the share option which produces a link to the route in his account
                  I want to save that route directly to my account so I have a copy
                  This is all done on mobile phone and not on a pc/laptop
                  Sync all is turned on already
                  All I want to do is easily save a route that has been shared with me by a link while using my mobile phone
                    @stuart-marritt ok - then it's the steps I described in second sektion. You can do this at your phone 😉
                    stuart marritt
                    stuart marritt
                    • New Zealand Routes
                      424
                    • Getal in begin logo
                    • Naar vorig routepunt
                    • IOS 27
                    • Opknippen route in etappes
                      Hans777
                      Hans777
                    • best format to download
                    • UNTITLED MAPS
                      1.5k
