  4. gpx not recognized problem
24 Posts 4 Posters 8.7k Views 2 Watching
  • King 06 King 06
    @Aiello-antonino
    Have you tried the export function of the MRA app when using the iPhone or iPad?
    Aiello antonino Offline
    @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
    King 06 1 Reply Last reply
      King 06 Offline
      King 06 Offline
      King 06
      @Aiello-antonino
      I can't reproduce your problem.
      Perhaps you could describe here what steps you follow to export or download the route.
      • King 06 King 06
        @Aiello-antonino
        @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
        Can you post a screenshot please?
          King 06 Offline
          King 06 Offline
          King 06
          @Aiello-antonino said in gpx not recognized problem:
          As I said, I have no problem and do not get a popup.
          So describe here what steps you follow to export or download the route. Or:
          • King 06 King 06
            @King-06
            https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
            this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
            • Rolf Engelsman Offline
              Rolf Engelsman
              I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
                @King-06
                King 06 Offline
                King 06 Offline
                King 06
                @Aiello-antonino
                You can also share a link here before you create a support ticket.
                I don't see anything wrong with your workflow either.
                • King 06 King 06
                  @Aiello-antonino
                  @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                  https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                  • Aiello antonino Offline
                    I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                      King 06 Offline
                      King 06 Offline
                      King 06
                      @Aiello-antonino
                      The GPX file you shared has the extension '.gpx'. I can work with that. The problem you are asking for help with has an extra extension '.chart' and is therefore not recognized. The question is why that extra extension is added.
                      It would be nice if you share the link of the route in your MRA library.
                      • King 06 King 06
                        @Aiello-antonino
                        @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                        https://www.myrouteapp.com/it/social/route/10252905?mode=share
                        King 06 Rolf Engelsman 2 Replies Last reply
                          King 06 Offline
                          King 06 Offline
                          King 06
                          wrote on last edited by King 06
                          #21
                          I can work with the route you shared without any problems.
                          In your video I see that you have enabled several POI libraries. Does the problem also occur when you disable them?
                          You write that the problem only manifests on the iPhone and iPad. Have you recently installed a new app?
                          EDIT:
                          Is this the only route where this problem occurs?
                            Rolf Engelsman
                            It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                              Rolf Engelsman
                              I can‘t use your generated .gpx file in MRA or TT GoRide.
                              MapsMe, Garmin Connect, BMW Motorrad do generate a usable route.
                              Make a support ticket and let the developers have a look at it.
                              • King 06 King 06
                                EDIT:
                                @King-06 yeahhhh
                                finally the right intuition! you're right, I had installed 2 apps to view the gpx, evidently one took over the file management, uninstalled and everything is fine! Thank you so much!
                                Rolf Engelsman
                                Rolf Engelsman
                                King 06
                                King 06
                                • HERE maps updates
                                  12.3k
                                  Alfred Schrittwieser
                                  714
                                  1.4k
                                  Bruno 7
                                  Bruno 7
