  4. gpx not recognized problem
17 Posts 3 Posters 10.4k Views 2 Watching
    no solution? does this happen to anyone else?
    @Aiello-antonino I do not recognise the message in the screenshot and I cannot translate what it says.
      @Nick-Carthew the writing is only the name of the file and the extension of the file itself to note, that is .GPX.CHART
        @Aiello-antonino What is .GPX.Chart and what are you attempting to do.
        Sorry but your question is not very clear.
        Are you saying that there is a problem with a route that is in MRA?
        If you are, then sharing the route to this forum might help find the answer.
        • Aiello antonino
          I AM EXPORTING IT and NOT importing it…can you try to export a file from your collection and check if the extension of your file is like the one in the photo? because I export the file but then when I import it for example in Google mymaps it tells me that the file is not supported, when instead it has always worked…the same thing happens on other platforms too
          • Aiello antonino
            @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
            • Aiello antonino
              @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
              Can you post a screenshot please?
              • Aiello antonino
                @King-06
                https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
                this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
                • Rolf Engelsman
                  Rolf Engelsman
                  Rolf Engelsman
                  I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
                  • Aiello antonino
                    @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                    https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                    • Aiello antonino
                      I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                      • Aiello antonino
                        @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                        https://www.myrouteapp.com/it/social/route/10252905?mode=share
                        Rolf Engelsman 1 Reply Last reply
                          Rolf Engelsman
                          Rolf Engelsman
                          Rolf Engelsman
                          It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                          • Rolf Engelsman
                            Rolf Engelsman
                            Rolf Engelsman
                            I can‘t use your generated .gpx file in MRA or TT GoRide.
                            MapsMe, Garmin Connect, BMW Motorrad do generate a usable route.
                            Make a support ticket and let the developers have a look at it.
                            • Aiello antonino
                              @King-06 yeahhhh
                              finally the right intuition! you're right, I had installed 2 apps to view the gpx, evidently one took over the file management, uninstalled and everything is fine! Thank you so much!
                              Rolf Engelsman
                              Rolf Engelsman
                                148
                              • Route exporteren uit beta
                                Johan 5q
                                Johan 5q
                                124
                              • SilverFox Controller C2
                                Hans Lamers
                                Hans Lamers
                              • "Please verify your email" display
                              • Layers menu: option to permanently display Favorite labels
