  4. gpx not recognized problem
24 Posts 4 Posters 9.5k Views 2 Watching
  • Aiello antonino
    no solution? does this happen to anyone else?
    Nick Carthew King 06 2 Replies Last reply
      @Aiello-antonino I do not recognise the message in the screenshot and I cannot translate what it says.
        @Nick-Carthew the writing is only the name of the file and the extension of the file itself to note, that is .GPX.CHART
          @Aiello-antonino What is .GPX.Chart and what are you attempting to do.
          Sorry but your question is not very clear.
          Are you saying that there is a problem with a route that is in MRA?
          If you are, then sharing the route to this forum might help find the answer.
            King 06
            King 06
            King 06
            @Aiello-antonino
            I assume you are trying to import the route into MRA and it is not working
            Change the extension of the downloaded file.
            It now says name.gpx.chart
            Remove .chart
            Maybe it will work then.
            • Aiello antonino
              I AM EXPORTING IT and NOT importing it…can you try to export a file from your collection and check if the extension of your file is like the one in the photo? because I export the file but then when I import it for example in Google mymaps it tells me that the file is not supported, when instead it has always worked…the same thing happens on other platforms too
              King 06 1 Reply Last reply
                King 06
                King 06
                King 06
                @Aiello-antonino
                Have you tried the export function of the MRA app when using the iPhone or iPad?
                • King 06 King 06
                  @Aiello-antonino
                  @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
                    King 06
                    King 06
                    King 06
                    @Aiello-antonino
                    I can't reproduce your problem.
                    Perhaps you could describe here what steps you follow to export or download the route.
                    • King 06 King 06
                      @Aiello-antonino
                      @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
                      Can you post a screenshot please?
                        King 06
                        King 06
                        King 06
                        @Aiello-antonino said in gpx not recognized problem:
                        As I said, I have no problem and do not get a popup.
                        So describe here what steps you follow to export or download the route. Or:
                        • King 06 King 06
                          @King-06
                          https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
                          this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
                          • Rolf Engelsman
                            Rolf Engelsman
                            Rolf Engelsman
                            I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
                              @King-06
                              King 06
                              King 06
                              King 06
                              @Aiello-antonino
                              You can also share a link here before you create a support ticket.
                              I don't see anything wrong with your workflow either.
                              • King 06 King 06
                                @Aiello-antonino
                                @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                                https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                                • Aiello antonino
                                  I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                                    King 06
                                    King 06
                                    King 06
                                    @Aiello-antonino
                                    The GPX file you shared has the extension '.gpx'. I can work with that. The problem you are asking for help with has an extra extension '.chart' and is therefore not recognized. The question is why that extra extension is added.
                                    It would be nice if you share the link of the route in your MRA library.
                                    • King 06 King 06
                                      @Aiello-antonino
                                      @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                                      https://www.myrouteapp.com/it/social/route/10252905?mode=share
                                      King 06 Rolf Engelsman 2 Replies Last reply
                                        King 06
                                        King 06
                                        King 06
                                        wrote on last edited by King 06
                                        #21
                                        I can work with the route you shared without any problems.
                                        In your video I see that you have enabled several POI libraries. Does the problem also occur when you disable them?
                                        You write that the problem only manifests on the iPhone and iPad. Have you recently installed a new app?
                                        EDIT:
                                        Is this the only route where this problem occurs?
                                          Rolf Engelsman
                                          Rolf Engelsman
                                          Rolf Engelsman
                                          It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                                          Rolf Engelsman
                                          Rolf Engelsman
                                          King 06
                                          King 06
                                            1.1k
                                            1.1k
                                          • prestaties en badges
                                            De Keyser
                                            De Keyser
                                            2.2k
                                            705
