  4. gpx not recognized problem
24 Posts 4 Posters 10.1k Views 2 Watching
    @King-06 as I wrote in the initial post, yes! I tried from the app and everything works fine! the file is correct!
    King 06
    King 06
    King 06
    @Aiello-antonino
    I can't reproduce your problem.
    Perhaps you could describe here what steps you follow to export or download the route.
    • King 06 King 06
      @Aiello-antonino
      @Re-Il tuo pop-up durante l'esportazione assomiglia al mio con .gpx.chart scritto?
      Can you post a screenshot please?
      King 06 1 Reply Last reply
        King 06
        King 06
        King 06
        @Aiello-antonino said in gpx not recognized problem:
        As I said, I have no problem and do not get a popup.
        So describe here what steps you follow to export or download the route. Or:
        • King 06 King 06
          @King-06
          https://youtu.be/5GrHx8_6MIQ?si=FGZ2B9b1mODsYJaT
          this is my workflow! but i always did it this way! i'm not that young on MRA, i never had this problem, it's only been happening for two days
          • Rolf Engelsman
            Rolf Engelsman
            Rolf Engelsman
            I can‘t reproduce your problem either. We have the same workflow. Make a support ticket and share the url of your route and make sure the settings are public.
              @King-06
              King 06
              King 06
              King 06
              @Aiello-antonino
              You can also share a link here before you create a support ticket.
              I don't see anything wrong with your workflow either.
              • King 06 King 06
                @Aiello-antonino
                @Re-06 questo è il file che viene scaricato, prova a caricarlo in MRA per vedere se funziona!
                https://drive.google.com/file/d/1oxiAimc9O9w0WejXZp64XzRqPF8OjMoM/view?usp=drivesdk
                • Aiello antonino
                  I know that there is nothing wrong in my workflow, but the file that is downloaded is not recognized even by MRA if I try to upload it, it is not recognized even by other platforms like Google or Mappite or Kurviger or others
                    King 06
                    King 06
                    King 06
                    @Aiello-antonino
                    The GPX file you shared has the extension '.gpx'. I can work with that. The problem you are asking for help with has an extra extension '.chart' and is therefore not recognized. The question is why that extra extension is added.
                    It would be nice if you share the link of the route in your MRA library.
                    • King 06 King 06
                      @Aiello-antonino
                      @King-06 sì! So che il problema è il grafico di scrittura, ma non so perché questo accada! anche se rinomino il file non viene letto correttamente da altre piattaforme, almeno questo succede a me
                      https://www.myrouteapp.com/it/social/route/10252905?mode=share
                      King 06 Rolf Engelsman 2 Replies Last reply
                        King 06
                        King 06
                        King 06
                        wrote on last edited by King 06
                        #21
                        I can work with the route you shared without any problems.
                        In your video I see that you have enabled several POI libraries. Does the problem also occur when you disable them?
                        You write that the problem only manifests on the iPhone and iPad. Have you recently installed a new app?
                        EDIT:
                        Is this the only route where this problem occurs?
                          Rolf Engelsman
                          Rolf Engelsman
                          Rolf Engelsman
                          It seems that I don‘t have the same problem with your route. I don‘t get the double extension.
                          • Rolf Engelsman
                            Rolf Engelsman
                            Rolf Engelsman
                            I can‘t use your generated .gpx file in MRA or TT GoRide.
                            MapsMe, Garmin Connect, BMW Motorrad do generate a usable route.
                            Make a support ticket and let the developers have a look at it.
                            • King 06 King 06
                              EDIT:
                              @King-06 yeahhhh
                              finally the right intuition! you're right, I had installed 2 apps to view the gpx, evidently one took over the file management, uninstalled and everything is fine! Thank you so much!
                              Rolf Engelsman
                              Rolf Engelsman
                              King 06
                              King 06
                              • Rangen
                                Pim van Dongen
                                Pim van Dongen
                              • Informatie Routeplanner Next
                              • F012 Tracklog folder / routes folder / how is it going right now?
                              • Positioning club Membership Locations every new planned route
                                OGRIII
                                OGRIII
                              • Can not move WP
                                13
                                27
                                359
                              • HELP! The Pyrenees Tour
                                Tony 13
                                Tony 13
