  4. Batterij verbruik
Batterij verbruik
31 Posts 18 Posters 17.9k Views 8 Watching
  • Cookie On Tour
    Cookie On Tour
    Cookie On Tour
    wrote on last edited by Cookie On Tour
    There are other threads where the power consumption is receiving complaints too. It looks like it independent from which mode or device you use, it looks like it is simply the mobile app is not power use optimized!?
    Joerg
    (Cookie-On-Tour.de)
    • Cookie On Tour Cookie On Tour
      @Cookie-On-Tour if you looked in those other treads you must have noticed that a lot has been said. In short, the problem is caused by the Here maps and MRA can’t do sh… about the fact that Here doesn’t solve the problem. Read the other treads and stop please starting new ones everytime
      Rob Veerman Cookie On Tour 2 Replies Last reply
        Rob Veerman
        Rob Veerman
        Rob Veerman
        @Marinus-van-Deudekom said in Batterij verbruik:
        @Cookie-On-Tour if you looked in those other treads you must have noticed that a lot has been said. In short, the problem is caused by the Here maps and MRA can’t do sh… about the fact that Here doesn’t solve the problem. Reda the other treads and stop please storting new ones everytime
        I can't agree more. This 'discussion' is like a spinning wheel that goes on and on.
          Cookie On Tour
          Cookie On Tour
          Cookie On Tour
          @Marinus-van-Deudekom my question then would be, are there other nav app solutions also based on the HERE map, that I can check with and see if the power consumption is the same.
          Joerg
          (Cookie-On-Tour.de)
          Nick Carthew Corjan Meijerink 2 Replies Last reply
            @Cookie-On-Tour HERE’s own navigation app - HERE WeGo. https://www.herewego.info/en/here-wego/navigation-devices/mobile-phone/
              @Cookie-On-Tour we did, it is 😉
                @Corjan-Meijerink and on top of that the Here we Go app is not to my taste so quickly back to MRA. In the end the problem will be solved. Still trying to find out where that is 🙂
                  @AlexvLeeuwen Is vol op de radar van de ontwikkelaars en kan je alleen oplossen door een batterypack mee te nemen of toch een laadfunctie te realiseren. Overigens gaat een batterij met gebruik van navigatie apps toch hard achteruit, hoewel het met MRA wel heel snel gaat.
                  Bynens Daniel
                  Bynens Daniel
                  Bynens Daniel
                  @Rob-Verhoeff ikzelf ben een 10 daagse aan doen in Frankrijk en door het regenweer kan ik
                  laadinfrastruktuur niet gebruiken. Heb het is bijgehouden 1% per km batterij verlies. Met een samsung s22 met een batterij in goede conditie
                  • Bynens Daniel Bynens Daniel
                    @Bynens-Daniel, het punt is dat sommige andere S22 gebruikers dat probleem helemaal niet ervaren. Dat maakt diagnostiseren erg lastig. Het lijkt dus niet puur van de hardware af te hangen. Met mijn CAT kan ik bijna de hele dag rijden overigens.
                    Bynens Daniel 1 Reply Last reply
                    • RetiredWingMan
                      One other point about battery consumption. It is well know fact that in areas of poor or no celular reception, the phone can use heavy amounts of battery attempting to locate a cellular connection. A recommendation is to go into "airplane mode" to stop the phone from searching. This won't fix the Here battery usage but it certainly could help reduce usage in poor reception areas. Navigation offline does not require a cellular connection.
                        Bynens Daniel
                        Bynens Daniel
                        Bynens Daniel
                        heb de S21 enkel als back up. Navigeer met een Ulefone tablet 8". Deze is gemonteerd op een cradle van BMW met rechtstreeks
                        stroomvoorziening in de cradle met een kabel. Bij een volledig opgeladen tablet en een ganse dag gebruik meer dan 10uur is de tablet leeg. Dus meer verbruik dan dat de cradle kan bijladen.
                        Dit duid toch op een hoog stroomverbruik.
                          #21
                          @Bynens-Daniel said in Batterij verbruik:
                          Dit heeft toch ook helemaal niemand op dit forum ontkent? Het probleem ligt bij HERE, is bekend bij HERE, is erkend door HERE en aan de oplossing wordt gewerkt, door HERE. Dat de snelheid waarop aan dat probleem wordt gewerkt in vele ogen te wensen overlaat is een andere kwestie.
                          • richard 3v
                            richard 3v
                            richard 3v
                            I have been reading these posts with interest.
                            I am a new user of MRA Navigation having given up on the BMW Connected App.
                            Today I went for a 240 mile round trip, by the time I had travelled around 200 miles my phone was dead, despite being on the wireless charger the whole journey.
                            Would I have had a better experience if I had used Offline navigation??
                            This could be a deal breaker for me because if I happened to have had a breakdown or other problem I would have had no phone to summon assistance.
                            • AlexvLeeuwen AlexvLeeuwen
                              Wellicht al eerder besproken maar ik kan geen oplossing vinden. Vandaag aan het rijden geweest met de app, met 1.5 uur is mijn iPhone 15promax leeg. Weet iemand hoe dat op te lossen is? En ja aan de lader doen, maar die zit niet op mijn motor 😉
                              Didier 5
                              Didier 5
                              Didier 5
                              @AlexvLeeuwen ik gebruik de carpuride om mijn carplay te zien zo moet het scherm van mijn iphone ook niet de hele tijd aanstaan. Mijn telefoon zit in een tankpad verbonden met een powerbank van 10000 mah rijd een hele dag rond en op het einde van de rit is mijn telefoon nog steeds vol geladen
                              • richard 3v richard 3v
                                @richard-3v Offline navigation certainly helps with power consumption. But not all users suffer with this problem. For instance, I can navigate all day (offline) with my phone on a QuadLock wireless charger and when I take the phone off of the charger it’ll be at 100% charged.
                                  @richard-3v said in Batterij verbruik:
                                  Probably, but not unless you set your phone to flightmode as well. It's the GSM radio using power, not the data itself.
                                  Another thing that will probably help you (A LOT!) is using a decent charger with a decent cable. Wireless charging has (low) limits.
                                  richard 3v 1 Reply Last reply
                                    richard 3v
                                    richard 3v
                                    richard 3v
                                    @Con-Hennekens @Nick Carthew
                                    Thank you both for your replies, much appreciated.
                                    I will try a decent length route using a cable charge and also using offline mapping.
                                    I am reluctant to go down the "flightmode" path as I like the option of being able to make or receive calls (although these are very rare, and didn't apply when I had the issue).
                                    Thanks again, I will keep you updated. Hopefully this may help others 😊
                                    • De Ploey Georges
                                      De Ploey Georges
                                      De Ploey Georges
                                      Ik heb SP connect voorzien:
                                      Oplader 12V:https://sp-connect.eu/collections/motorcycle/products/anti-vibration-module?variant=40315912290413
                                      en beugel: https://sp-connect.eu/collections/motorcycle/products/bar-clamp-mount-pro
                                      werkt prima met gps en IPHONE blijft vol
                                      • Dirk Kevin K.
                                        Dirk Kevin K.
                                        Dirk Kevin K.
                                        wrote on last edited by Dirk Kevin K.
                                        #28
                                        This post is deleted!
                                        • richard 3v
                                          richard 3v
                                          richard 3v
                                          Further to my post of earlier this week, today I went out and did a 148 mile route over a period of 5 hours.
                                          I started the route with 80% battery power, I had the phone plugged in with a cable and offline navigation set.
                                          I received one phone call during my trip.
                                          When I finished the route I checked my phone and I had 79% battery. 👍
                                          A definite result, next time I may try without using offline maps but at least I know that there is a solution.
                                          Thanks to everyone for their input and assistance.
                                          Rob Veerman
                                          Rob Veerman
                                          Cookie On Tour
                                          Cookie On Tour
                                          De Ploey Georges
                                          De Ploey Georges
                                          richard 3v
                                          richard 3v
                                          Bynens Daniel
                                          Bynens Daniel
                                          erik b
                                          erik b
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Didier 5
                                          Didier 5
                                          AlexvLeeuwen
                                          AlexvLeeuwen
                                          • Route Opacity Viewing Existing Routes in Library
                                          • Move a GPS point on the map
                                          • Guida Libera
                                          • Route leads straight to endpoint
                                            Rolf Engelsman
                                            Rolf Engelsman
                                          • Trip summary view
                                          • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
