  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 12.5k Views 3 Watching
  • Reinhard-32 Reinhard-32
    @FRANCISCO-BARRENA said in Move routes of position:
    I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
    thanks!
    You can add a number at first as beginning of the route name.
    TomOnTour
    TomOnTour
    TomOnTour
    @Reinhard-32 said in Move routes of position:
    thanks!
    That is exactly how I do it with my routes. 🙂
    Works perfect for me.
    Greetings
    Thomas
    MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
    MRA Navigation Next (Lifetime Gold)
    MRA Routeplanner NEXT beta (Lifetime early access)
    Erdna 1 Reply Last reply
    • TomOnTour TomOnTour
      thanks!
      Greetings
      Thomas
      Erdna
      Erdna
      Erdna
      @TomOnTour said in Move routes of position:
      thanks!
      Greetings
      Thomas
      Same here.
        thanks!
        fbarr47gmail.com
        fbarr47gmail.com
        fbarr47gmail.com
        @Reinhard-32 yes, like this I have done in my routes and not work properly. The route num 3 not in position
        • fbarr47gmail.com fbarr47gmail.com
          @FRANCISCO-BARRENA That is strange. I can see there are dots in your route names and after the route numbers. Remove them could be helpful. It is often not a good idea use special characters in file names.
          Kindly regards
          Reinhard
          Montana 700i and Mac
          GT JWR 1 Reply Last reply
            @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
            • GT JWR GT JWR
              #14
              @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
              Kindly regards
              Reinhard
              fbarr47gmail.com 1 Reply Last reply
                fbarr47gmail.com
                fbarr47gmail.com
                fbarr47gmail.com
                I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
                  @FRANCISCO-BARRENA
                  No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
                  You could temporarily rename route no. 3 to something like 15 or so.
                  BTW: The sort order goes from left to right and from numbers to letters.
                  If you have more than 9 routes it is recommended to use 2 digits like this:
                  01
                  02
                  09
                  Otherwise you will get:
                  21
                  Kindly regards
                  Reinhard
                    @FRANCISCO-BARRENA
                    01
                    02
                    09
                    21
                    @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
                    Herko ter Horst MotoCon 2 Replies Last reply
                      @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
                        @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                          @Marinus-van-Deudekom said in Move routes of position:
                          In that case Route 8 would be sticking out 😉
                          But no, the name column is selected.
                            thanks!
                            thanks!
                            Is your problem solved now or does it still exist?
                            Kindly regards
                            Reinhard
                            • BFG
                              BFG
                              BFG
                              wrote on last edited by BFG
                              #22
                              There is a space at the beginning of the route name. The interface ignores the space, so you can't see it in the listing, but if you edit you will see that it's there.
                              " "3. BISCARROSSE. Camping....
                              Remove the space and it will work
                              • BFG BFG
                                fbarr47gmail.com
                                fbarr47gmail.com
                                fbarr47gmail.com
                                @BFG said in Move routes of position:
                                OK, you´re right, there was a space in the 3 route. Solutioned!
                                thanks a lot!
                                Rob Veerman
                                Rob Veerman
                                TomOnTour
                                TomOnTour
                                Erdna
                                Erdna
                                BFG
                                BFG
                                fbarr47gmail.com
                                fbarr47gmail.com
                                  Jacob Waterweg
                                  Jacob Waterweg
                                  96
                                  Edwin van Klink 6
                                  Edwin van Klink 6
                                • Startpunt wijzigen
                                  Ad V
                                  Ad V
                                  Giancarlo e
                                  Giancarlo e
                                • Route exporteren uit beta
                                  Johan 5q
                                  Johan 5q
                                • PDF export: suggested additional options
                                  Emanuele 5
                                  Emanuele 5
