  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 12.5k Views 3 Watching
  • fbarr47gmail.com fbarr47gmail.com
    I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
    thanks!
    @FRANCISCO-BARRENA said in Move routes of position:
    thanks!
    You can add a number at first as beginning of the route name.
    Kindly regards
    Reinhard
    Montana 700i and Mac
    TomOnTour fbarr47gmail.com 2 Replies Last reply
    • Reinhard-32 Reinhard-32
      thanks!
      TomOnTour
      TomOnTour
      TomOnTour
      @Reinhard-32 said in Move routes of position:
      thanks!
      That is exactly how I do it with my routes. 🙂
      Works perfect for me.
      Greetings
      Thomas
      MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
      MRA Navigation Next (Lifetime Gold)
      MRA Routeplanner NEXT beta (Lifetime early access)
      Erdna 1 Reply Last reply
      • TomOnTour TomOnTour
        thanks!
        Greetings
        Thomas
        Erdna
        Erdna
        Erdna
        @TomOnTour said in Move routes of position:
        thanks!
        Greetings
        Thomas
        Same here.
          thanks!
          fbarr47gmail.com
          fbarr47gmail.com
          fbarr47gmail.com
          @Reinhard-32 yes, like this I have done in my routes and not work properly. The route num 3 not in position
            @FRANCISCO-BARRENA That is strange. I can see there are dots in your route names and after the route numbers. Remove them could be helpful. It is often not a good idea use special characters in file names.
            Kindly regards
            Reinhard
            GT JWR 1 Reply Last reply
              @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
              • GT JWR GT JWR
                #14
                @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
                Kindly regards
                Reinhard
                fbarr47gmail.com 1 Reply Last reply
                  fbarr47gmail.com
                  fbarr47gmail.com
                  fbarr47gmail.com
                  I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
                    @FRANCISCO-BARRENA
                    No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
                    You could temporarily rename route no. 3 to something like 15 or so.
                    BTW: The sort order goes from left to right and from numbers to letters.
                    If you have more than 9 routes it is recommended to use 2 digits like this:
                    01
                    02
                    09
                    Otherwise you will get:
                    21
                    Kindly regards
                    Reinhard
                      @FRANCISCO-BARRENA
                      01
                      02
                      09
                      21
                      @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
                      Herko ter Horst MotoCon 2 Replies Last reply
                        @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
                          @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                            @Marinus-van-Deudekom said in Move routes of position:
                            In that case Route 8 would be sticking out 😉
                            But no, the name column is selected.
                              thanks!
                              thanks!
                              Is your problem solved now or does it still exist?
                              Kindly regards
                              Reinhard
                              • BFG
                                BFG
                                BFG
                                wrote on last edited by BFG
                                #22
                                There is a space at the beginning of the route name. The interface ignores the space, so you can't see it in the listing, but if you edit you will see that it's there.
                                " "3. BISCARROSSE. Camping....
                                Remove the space and it will work
                                • BFG BFG
                                  fbarr47gmail.com
                                  fbarr47gmail.com
                                  fbarr47gmail.com
                                  @BFG said in Move routes of position:
                                  OK, you´re right, there was a space in the 3 route. Solutioned!
                                  thanks a lot!
                                  Rob Veerman
                                  Rob Veerman
                                  TomOnTour
                                  TomOnTour
                                  Erdna
                                  Erdna
                                  BFG
                                  BFG
                                  fbarr47gmail.com
                                  fbarr47gmail.com
                                    Jacob Waterweg
                                    Jacob Waterweg
                                    96
                                    Edwin van Klink 6
                                    Edwin van Klink 6
                                  • Startpunt wijzigen
                                    Ad V
                                    Ad V
                                    Giancarlo e
                                    Giancarlo e
                                  • Route exporteren uit beta
                                    Johan 5q
                                    Johan 5q
                                  • PDF export: suggested additional options
                                    Emanuele 5
                                    Emanuele 5
